Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here.
Old 01-04-2012, 10:50 AM
Cscott Cscott is offline
Mein Auto: BMW 535i on order
Harsh ride on x5 any way to soften it?
I'm considering a new x5 i was lucky to have a loaner for about 6 days it was a 2012 35d with the normal suspension.
The at first seemed firm but tolerable the tire pressure was set at 34 psi front and back.
I looked in the door jam and the recommended tire pressure was 34 front and 42 or 43 rear i can't remember exactly.
So after adjusting the to proper inflation the ride got pretty harsh and i did not get a chance to lower the rear tire pressure i would love to get one but it was way to harsh
Maybe changing the run flats to regular tires might help i would love to hear your comments
Thank you
Old 01-04-2012, 11:04 AM
m3the01 m3the01 is offline
Mein Auto: '12 X5-35d AW-CI
I hear these comments a lot, however i have driven a wide range of vehicles and luv the ride of the x5 even on the RFTs. If u want the ride of a cadillac then buy a cadillac, changing the tires will help a little.
The suspension is stiffer, this is how BMW has been able to destroy every competitor on the skid tests.
Good luck,
Test out a few vehicles and buy what feels the best for you,
cheers,
Old 01-04-2012, 11:05 AM
Jim E.'s Avatar
Jim E. Jim E. is offline
Mein Auto: 1999 M3 Coupe & 2009 335d
Thank you
Options:
1. Ditch the runflats;
2. Order Adaptive Drive
3. Ditch the runflats and order Adaptive Drive.
Old 01-04-2012, 11:14 AM
ductman's Avatar
ductman ductman is offline
Mein Auto: 2011 X5 35D /2011 M37X
Thank you
Inflation pressures are 32 front and 36 rear, pressures would only be increased if driving
at high speeds over 100 mph ( not likely around here ) or 3 passengers in rear and a full load of cargo.
Old 01-04-2012, 11:15 AM
ard ard is offline
Resident Curmudgeon
1. RFTs will be harser
2. What size rims???larger rims/lower sidewalls generally increase harshness. This can be significant.
3. The max rear pressure is only to achieve maximum loading...I always titrate tire pressures to achieve best handling and tire wear based on how I am using the car. Definitely not 42.
A
Old 01-04-2012, 11:42 AM
Matt_UKTX Matt_UKTX is offline
Mein Auto: 2012 X5 35d
Originally Posted by Jim E. View Post
Options:
I agree with Jim's comments... Additionally, look at wheel sizes. If "harsh" ride bothers you, avoid the 20-inch rims, and maybe even the 19-inch rims too. Stick with the 18's, order the Space Saver Spare, and switch out the tires for non RFT.
Current:
2012 E70 X5 35d (Alpine White / Oyster)
Gone but not forgotten:
2008 E60 535i (Black Sapphire / Natural Brown)
2006 E90 330i (Jet Black / Sand Beige)
2003 E46 325i (Black Sapphire / Natural Brown)
Old 01-04-2012, 12:08 PM
Jim E.'s Avatar
I should have also mentioned different size tires too.
I have the OE Dunlop 20's and AD. The ride is not harsh for me but it is sporty. When I switch out to the 19" Pirelli Scorpion RFT snow tire, I do notice a softer (more compliant) ride. So there is a difference just going down one rim size. When my Dunlops wear out, I will probably go to Continental standard (not RFT) so I can't comment on that but based on some reviews, they are softer yet not to mention the reduction of a total of 30lbs of unsprung and rotating mass.
Just an additional point of reference for you.
Old 01-04-2012, 12:15 PM
Be careful with the Conti DWS. I had them for a couple of weeks and they caused my car to pull to the right. A few other forum members complained about the same thing - could be a bad batch. Anyway, I went with the Michelin Latitude Tour HP's. They are great, and closer to OEM style.
Current:
Old 01-04-2012, 12:20 PM
Jim E.'s Avatar
Be careful with the Conti DWS. I had them for a couple of weeks and they caused my car to pull to the right. A few other forum members complained about the same thing - could be a bad batch. Anyway, I went with the Micheline Latitude Tour HP's. They are great, and closer to OEM style.
thanks for the heads up!
Old 01-04-2012, 01:41 PM
Thanks Guys i will probably go for another test drive and i also heard in spring you can get a good deal on x5's
Old 01-04-2012, 01:48 PM
icuc's Avatar
icuc icuc is offline
Mein Auto: 2012 X5, 2012 MINI ALL4
They will be running deals now and then but if you like it then just buy it... I got my X5 below $8K from MSRP.
Old 01-04-2012, 02:44 PM
Standard pricing is $500 to $1000 over invoice as shown on www.bmwconfig.com. This is BEFORE any rebates/incentives (such as Eco Credit, Nav Credit, Owner Loyalty, etc.) are applied. So, when all said and done, you can be below invoice factoring in the incentives.
Don't be confused into negotiating off MSRP. The formula should always be:
BMWConfig.com Invoice Price + Dealer Profit ($500 to $1000) - Incentives/Rebates = Purchase Price.
Good luck
Current:
Old 01-10-2012, 03:02 PM
Collie1 Collie1 is offline
Mein Auto: x5d
If we decide to change to a regular tire and ditch the run flats...where do we put a spare? It has a storage compartment under the rear cargo area, but that does not look large enough to store a spare tire. Can a compact donut be used on an X5? Seems like the vehicle would be too large for a donut.
Old 01-10-2012, 05:57 PM
AKX3 AKX3 is offline
Stigs Trainer
Mein Auto: X5, X3, C4S
They do have a Compact Spare available for the X5... E-bay would be your best bet.
Good luck,
ak
11 e90 Msport, X5 4.8i, 08 335i Coupe, 10 C4S NIB, 06 X3 Sport, 08 550 CLS, 01 CLK 55, 04 Saab 93 forgotten, 06 Crossfire?, 96 M3, 94 968 cab, 99 C43 AMG, nice, 96 C280, 89 325is drifter, 93 190e 2.6, 95 Jetta VR6, 91 Corrado G60, 90 BMW 740il, 88 Accord Coupe Lxi, 87 Mazda 323 GT and first was a 84 Mercury Lynx Rs.
Old 01-10-2012, 10:16 PM
Sethrad Sethrad is offline
Mein Auto: X5M
Instead of a spare...
Do what BMW does on the M3..***** a small compressor and get a couple of bottles of Slime. Make sure you size the Slime for your tire sizes. Stick that in your storage box...and you're done. I've heard nothing but success stories with Slime. I carry it in my X5M. Ive done so in previous vehicles.
Old 01-11-2012, 03:22 AM
btadlock btadlock is offline
Mein Auto: 2012 X5, 2011 328i
I think the BMW ride is sporty and controlled, not harsh. If you want soft, buy american but it won't be as fun to drive.
2012 X5
2011 328i
Old 01-11-2012, 05:53 PM
jerryjash jerryjash is offline
Mein Auto: jetta tdi
X5 Ride
2012 with 20 inch ...Changed to Vredestein With compact spare.. Ride is very much improved and handling is like a sports car... this tire is amazing. Have a set ordered for my 2011 Vette...Don't know about wear. I have almost 6000 miles and they still look new....
