2009 Z4 sdrive35i 18K miles and clutch is gone, dealer wants $3200 pls help.. - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 01-05-2012, 01:03 PM
nir_bs nir_bs is offline
Mein Auto: 2009 Bmw z4 sDrive35i E89
2009 Z4 sdrive35i 18K miles and clutch is gone pls help
took over lease two months ago and drove it 2300 miles,
than the clutch start smelling this burned stinky smell
towed it to the dealer and thay says it smells bad and they need $1050 just to take the tranny apart to check if it was abuse..
pls helppppppp
also looking for used BMS-JB4 i u can help..(lost my jb3-$479 Retail)
pls look at my flywheel pictures and advice if should replace ($1144.00) at the BMW shop
flywheel feels tight, mover only 3 tooth clockwise only bad thing it smells a bit burned and had bluewish color on the disc...
ID:	307259   Click image for larger version
ID:	307260   Click image for larger version
ID:	307261   Click image for larger version
ID:	307342   Click image for larger version
ID:	312534   Click image for larger version
ID:	312535   Click image for larger version
Old 02-16-2012, 03:00 PM
i drove the car 2000 miles since purchased and fly wheel has blue discoloration should i replace it?
Old 02-16-2012, 04:20 PM
GaryRudolph's Avatar
GaryRudolph GaryRudolph is offline
Mein Auto: Z4 35is, X5 50i
How much do they want for a flywheel? That would drive my decision vs. how much I'm already spending on the repair... For a 2009 car I'd probably just be replacing it if it was myself.
Is it warped at all (i.e. measuring it with a dial indicator on a lathe or similar)?
If you can't tell... Find out or replace it.
If it's not warped you can probably just rough it up with some sand paper to seat the new clutch.
Current: 2012 X5 xDrive50i, 2012 Z4 sDrive35is
Previous: 2011 X5 xDrive35d, 2008 M5, 2006 M Roadster, 2005 645Ci Convertible, 2002 X5 3.0i Sport
Old 02-16-2012, 08:36 PM
bayoucity's Avatar
bayoucity bayoucity is offline
Mein Auto: 2011 335d & 2014 535i
Why isn't it covered under 4 years/50k miles warranty?
Old 02-16-2012, 11:00 PM
Andrew*Debbie's Avatar
Andrew*Debbie Andrew*Debbie is offline
resU deretsigeR
Mein Auto: Leaf Tekna
The Limited Warranty covers defects in materials or workmanship.
http://www.bmwusa.com/Standard/Conte.../Warranty.aspx
BMW Ultimate Service includes factory maintenance, brake pads, brake disks, wiper blades and drive belts. It does not include clutch parts.
http://www.bmwusa.com/Standard/Conte...intenance.aspx
Clutch is only covered by warranty. Dealer probably decided the previous owner abused the car. Easy enough to burn up a clutch on a 35i.
Abuse isn't covered. Worn out clutch isn't covered. Dealers have some discretion on using 'customer loyalty' to pay for part of all of a repair that isn't covered.
The models and equipment (standard and optional) illustrated in this post reflect my misunderstanding of vehicles supplied by BMW AG to the German market. In other EU member states, the truthyness of my posts may vary. Please ignore this post. Subject to change.
Old 02-17-2012, 10:11 PM
OEM dual mass flywheel is manufactured by LUK and it cost $1144 +tax
The clutch was badly abused by last owner..
New one cost me $375 the whole clutch kit..
sent the flywheel for resurface in San Diego for $80 hope this will save the trouble..
Sent from my SGH-T989 using Bimmer App
Old 02-17-2012, 10:15 PM
Dealer want Me to sign a form says I will need to pay $1050 just to open and see if it's covered in the warranty..if it is then I'm OK and BMW pays the dealership all costs, if clutch is abused then total cost is $3200+$1144 for flywheel..
Took it to my amazing mechanic total labor is $450
and the clutch was not abused, it was Raped..
Never believed to my own eyes guys..
Old 02-17-2012, 10:16 PM
Hope the flywheel can be resurfaced the all costs is less then $1000..if not, I need a flywheel.. add $1200..
Old 02-20-2012, 04:55 AM
GnattheCat GnattheCat is offline
Mein Auto: 2008 Z4 3.0i
Cpo
What is it about being a certified preowned unit that the dealer does not acknowlwdge. If you've abused the car, that's what you get but there should be other signs to reflect abuse, like no tread left on the tires etc. I had a simular problem but it truned out that the flywheel had excessive play in it. Dealer replaced flywheel and clutch components under warrenty. Enjoy your day-Gnatthecat
Old 02-20-2012, 02:45 PM
resU deretsigeR
It isn't a certified preowned.. Nir_bs took over the lease -- that means it has the new car warranty but no extended CPO coverage. Even if it was a CPO, the Z4 is new enough that it would still be on the 4 year warranty.
Previous owner probably had to buy new tires. Either that or he really didn't know how to drive. The flywheel looks like the clutch overheated.
I do feel for nir_bs. Not much he can do except pay to have the car repaired. I'd be upset with the previous owner.
BMW UK offer an extended service package that covers clutch parts, but it costs almost as much as a clutch and flywheel.
Old 02-25-2012, 03:35 PM
i got it done for less then $70
flywheel is resurfaced in standard flywheel in vista california
they did amazing job and saved me $1100
lets hope its running smooth
tnx for all replies guys appreciate the help
and the car is not certified i took over lease...
Old 02-25-2012, 03:38 PM
total cost so far $980 and a month and a half with no car...
miss my baby bimmer...
just see if u can find BMS JB4 Chip for me...
never pay retail ($500)..
Old 02-25-2012, 08:27 PM
thayden thayden is offline
Mein Auto: '11 Z4 35is
I assume this is a manual trans instead of the DCT? I read somewhere that the engineers off the record felt the clutchs in the DCT should last 200,000 miles..
'11 Z4 35is
'09 Audi Q5
'07Lamborghini Gallardo
Old 02-28-2012, 01:30 PM
it is the manual tranny.. only mine last 18,000 miles...
crappy last owner what can i say.. looks like resurfaced worked..
HTML code is Off
