Old 01-05-2012, 08:03 PM
brodyjones1 brodyjones1 is offline
Mein Auto: X3
2004 X3 2.5L Im told I need a DME? Codes28B2,29B5,27A1,2796
My X3 is turning over only to stall. It seems like cold weather might play a part. It will do this over and over and then will go into a "safe mode? rough idle where pressing the gas pedal doesn't work and the car idles at 10,000rpms. If I disconnect the battery and keep re starting it, it may go back into a regular run condition where there are no problems. This will last the wole day until the next frigid morning, when it won't stay running again...
I took it to a shop that advertises a BMW certified mechanic and got Drivability codes above. They say I need a new DME(Computer) at $1500. with only an hours labor. Does anyone know? I am scheduled to go to the local dealer for his diagnostics, because the Service manager there said that he has never had to replace a DME, that it's probably something else.
Old 11-28-2012, 12:59 PM
wulverine2 wulverine2 is offline
Mein Auto: X3
Did you resolve this problem? I am having same issue with my 2005 X3 3.0i and am told I need a new DME.
Old 11-28-2012, 01:09 PM
jdauria jdauria is offline
Mein Auto: 323Ci & X3 3.0i M-Sport
whoa whoa whoa, before you start dropping $1500, have you had a second opinion anywhere else? Is your DME 413 red label? I've seen a few floating around for like $100...
#465420 National Capital Chapter
My Progress Thread
2000 323Ci | TiAg | Gray | ZSP | ZPP | AFE | UUC | Eisenmann | Koni | ACS Type III | Coby Wheel | 330 Brake Swap w/ BMW Performance Rotors
2006 X3 3.0i M-Sport | Silver Grey | Terracotta | Navigation | Premium Pkg | Cold Weather Pkg | AFE |
Old 11-28-2012, 01:31 PM
Mein Auto: X3
Thanks for replying, jdauria.
I haven't had a look at the part myself yet, just took it to an indie mechanic for inspection. He read the codes, found me a "service bulletin" published by BWM - 12-49-06, and asked me to go to the dealership for replacing the DME. He also said, they might give some discount on the part because of the bulletin.
I am not very fond of driving to my local dealership having read the countless bad reviews online.
Do you think I should buy the part online and replace it myself? I heard there is some programming involved which only BMW Dealerships can do, is that true?
