The X5 SAV Forum
Old 01-08-2012, 03:03 AM
Tim28366 Tim28366 is offline
Mein Auto: X5
Exclamation Error code P0102 & fail safe programme.
Hi all,
Got error code p0102 MAF also the fail safe programme error code is on. X5 drives with no problems other than on a few occasions when you go to take off there is no power for a few seconds? Car drives ok when you drive the auto box in manual. What I am hoping is the MAF is the cause of the fail safe light comming on! X5 is now 8 years old with 28k on the clock. Wife only takes it to work and back.
Any help would be good.
Kindest regards
Old 01-14-2012, 12:32 PM
Mein Auto: X5
All sorted,needed a new mass air flow sensor.
Old 01-15-2012, 01:00 AM
OzzyX5 OzzyX5 is offline
Mein Auto: 2006 X5 3.0d
Hi Tim,
My 2006 3.0d had the MAF sensor die, it put the engine into limp mode,
it was still drivable but gutless if you put the foot dowwn.
Read the fault code and replaces the MAF sensor and goes grate.
Old 01-15-2012, 04:28 AM
Mein Auto: X5
Thanks Ozzy, changed the MAF and car driving perfect,can't believe such a small part caused so many problems.
Cheers
Old 01-16-2012, 11:56 AM
iramada iramada is offline
Mein Auto: 2006 x5
i had sort of the same problem
i took mine to bmw and i had a pinched wire and a bad computer module and its all under warranty
Old 01-16-2012, 02:33 PM
sunny5280 sunny5280 is offline
Mein Auto: 2007 X5 4.8i
Originally Posted by Tim28366 View Post
Hi all,
Kindest regards
Disconnect the wire to the MAF. Doing so causes the computer to use a default set of parameters for the air / fuel mixture. If the hesitation goes away it's likely the MAF needs replacing.
Old 06-21-2012, 02:05 PM
hadsade hadsade is offline
Mein Auto: 2002 bmw 330ci
I have a 2002 bmw 330ci, what can I do for following problem, P0102 MAF or VAF coruit low in put?
Old 06-21-2012, 02:09 PM
Hello
Old 06-22-2012, 03:19 AM
Mein Auto: X5
I would change the mass air flow sensor,buy one from eBay in the uk cost me £25.00 so worth a gamble. It sorted my x5 out. I am sure some BMW experts will soon post a answer to your problem. Good luck.
