Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 01-08-2012, 07:09 PM
hillbillybimmer hillbillybimmer is offline
Mein Auto: 84 528e
Question 84'-86' instrument cluster swap
Have 84' 528e speedometer and odometer not working, bought complete instument cluster from 86' 528e. Installed in car and speedo and odo worked fine but nothing else! No tach, no fuel, no mpg, no temp and lights above fuel ga were on regaurdless of switch position. Being the ingenious sort I decided to install the 86' speedo in 84' cluster. well this didn't fare any better as speedo and odo didn't work. I spent 40$ and i'm back at square one, should I buy odo gears for my old speedo, will this fix my problems?
Old 01-09-2012, 10:48 AM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
Yes, your old speedometer has the broken gears. Just replace those and you should be fine. Your new cluster probably has bad SI batteries that have leaked and destroyed the board with the acid. When I bought my car only the speedometer worked (or was it the tachometer?) and nothing else. Bought a good condition SI board, replaced it and everything works since then.
Jimmy Moreno
1995 530i
1986 535i
Old 01-09-2012, 07:46 PM
IEbimmerguy's Avatar
IEbimmerguy IEbimmerguy is offline
Mein Auto: E38, e23, e3
I had same issue with nothing but the speedometer working, and gears didn't fix the problem.
My issue was the SI board to get the tach and gauges going, and the little motor to turn the gears on the odometer. I used a "parts cluster" to repair mine. Took a little while but it all worked out.
Old 01-10-2012, 07:13 PM
Mein Auto: 84 528e
just soldered wires onto 86' SI board (to mount batteries in remote location)going to install in car and see if it works. Volt meter showed dead battery but no leaks, looked new.
Old 01-13-2012, 01:57 PM
Mein Auto: 84 528e
Smile
Thanks Jim, installed 86' cluster in car with remote batteries and all works well.
Old 01-16-2012, 05:35 AM
Mein Auto: 2006 X3
That's great!
Jimmy Moreno
1995 530i
1986 535i
84' 528e, odometer, speedometer
HTML code is Off
