Old 01-21-2012, 09:29 AM
Phil Mayer Phil Mayer is offline
Mein Auto: 2007 X3 and 2000 528i
running rough, no power
Looking for info on testing ignition coils , getting miss fire faults on cyclinder 3 of my 2000 e39.
Old 01-21-2012, 07:56 PM
mkmichalek mkmichalek is offline
Mein Auto: 528i & 750i
Try swapping the coil with a different cyclinder and see if the misfire follows it.
Old 01-22-2012, 10:12 AM
I swapped one with three. Checked ohms on both at .05 The manual says .08 Also changed fuel filter and cleared faults. Seems to run ok now. Maybe a bad connection. Computer faults will run you in circles sometimes
Old 01-22-2012, 03:49 PM
If the misfire returns to #3. Start looking at the injector. Also do a compression check on all cyl. to see if #3 is a little low.
Old 01-22-2012, 08:46 PM
it came back, Will check injector next. the plug looks ok but I haven't tried a plug swap.
Old 01-22-2012, 08:47 PM
also have a fault 21 bank two O2 sensor slow to respond. Sensors are relatively new.
