Refinishing Style 5's - Bimmerfest - BMW Forums
Old 01-11-2012, 05:06 AM
XUMERX XUMERX is offline
JK3R
Mein Auto: 2015 BMW X5 35D
Smile Refinishing Style 5's
Okay so I have been doing some research ( alot ) and I came across this.
http://stanceworks.com/forums/showthread.php?t=2597
AND!!! I really want to do it but the thing is that I am not going to paint my wheels white. Im going to polish the lip just like it come from the factory and also keep the hyper silver color. Ive decided to take on this task because everone here in my area is trying to charge me 140+ to refinish it wheel. So 140 x 4 = 560 = I have been dieing for a perfect set of style 5's So after seeing this and knowing that im very good in these types of things IM READY! I just thought I should share and yess I will be posting pictures as I go along for my bimmerfest bros. For now though I have attached some of the before pictures! As you can see I have clear coat coming off and also in some areas on the lip when I try to wash it the brake dust just does not come off its like absorbed or something into the fading clear. I am one if those people that if im doing something it has to be PERFECT! So lets see the results in a few days.
I would love any feedback or ideas.
ID:	307848   Click image for larger version
ID:	307849   Click image for larger version
1999 BMW 528I (Sold)
2006 BMW 530i (Sold)
2015 X5 35d M-Line
Old 01-11-2012, 05:37 AM
BentValve's Avatar
BentValve BentValve is offline
Mein Auto: 00 528i 3 pedals
Please keep us posted. I plan on tackling this task as well as soon as I get some new wheels.
Old 01-11-2012, 05:45 AM
JK3R
Ofcourse bro And btw heres a good thread to get the motivation started!
http://www.stanceworks.com/forums/showthread.php?t=4899
2015 X5 35d M-Line
Old 01-11-2012, 05:50 AM
BentValve's Avatar
I really want some 18" 5's.
Old 01-11-2012, 06:12 AM
JK3R
The 18s are really nice but I remember reading somewhere that the 17s just give the best ride for the e39 so I just put some good shoes on them and kept it now I want them to be perfect
2015 X5 35d M-Line
Old 01-11-2012, 06:25 AM
BentValve's Avatar
I plan on slamming the car so I've already decided to compromise ride quality for looks.
Old 01-11-2012, 06:45 AM
JK3R
In that case in my opinion on your car that would look really good
2015 X5 35d M-Line
Old 01-11-2012, 12:42 PM
Joe__Sterling's Avatar
Joe__Sterling Joe__Sterling is offline
Fast Cars Suck!
Send a message via AIM to Joe__Sterling
Mein Auto: '13 FIAT 500 '68 BMW 1602
i have my 5's upstairs, just need the motivation to get started on em
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
@Joe__Sterling on twitter & instagram (two underscores)
Old 01-11-2012, 03:37 PM
JK3R
Check out the link I posted above about the motivation
2015 X5 35d M-Line
Old 01-11-2012, 03:45 PM
JK3R
Day 1: Clean and prepare materials
So today I went out and bought all the thing I needed.
The list as follows:
- 3 cans of titanium silver (Paint and Primer)
- 1 cans of highgloss black for the bolts
- 2 cans of clear protective enamel or what ever its called
- Remover for the clear coat and old paint
- Sandpaper that are I think 400, 600, 800, 1500, 2000
- 2 brushes just incase
- 1 bottle of vinegar
- Maybe some other things that I forgot I bought and maybe not
So after I brought all the stuff home I put my baby on bricks and two stands and then I took the wheels off and gave them a good 3000psi wash Now for tonight Im letting them sit and dry so tomorrow I will get the tires dismounted! then comes DAY 2!
ID:	307920   Click image for larger version
ID:	307921   Click image for larger version
ID:	307922   Click image for larger version
ID:	307923   Click image for larger version
ID:	307925   Click image for larger version
ID:	307926   Click image for larger version
2015 X5 35d M-Line
Old 11-03-2013, 09:50 PM
Dakkota Dakkota is offline
Mein Auto: 1994 BMW 325is
So.. You didn't keep posting?
Old 11-04-2013, 04:35 AM
dnbigdog dnbigdog is offline
Mein Auto: 5281
Here are some things I learned when refinishing style 5's:
1. It helps to slightly heat the nuts before trying to remove them. They are held on by thread locker and about 10 seconds with a propane torch will go a long ways toward breaking their grip. You can do it without the heat but it takes quite a bit of torque to break them loose.
2. Get the proper size nail set to remove the bolts. The end of the bolts have a little dimple in the end which will hold the punch square to the bolt. If the tool slips it will damage the threads which then have to be repaired in order to use that bolt again. If you "booger" the threads it's not a big deal but it will have to be fixed with a thread chaser before being re installed.
3. Mark the barrels and "waffles" with numbers so the same center goes back into the same barrel. Again not a big deal but it's always smart to use the same parts the factory used when you reassemble them.
4. Look at the hole for the valve stem and notice it is directly opposite the indexing mark for the center cap. This is the correct way to reinsert the center piece to make sure you're using the same holes as factory assembly.
5. Don't expect even the best paint stripper to work in only one coat, it will take at least two and maybe three applications.
6. Don't allow the pain stripper to dry on the wheel, remove while still a little wet or it's a pain to get off.
7. A wire wheel on a bench grinder is great for cleaning the bolts.
8. Metal valve stems look great on these wheels, the rubber kind look out of place.
Good luck and keep us posted.
diy, refinishing, rims, style 5
