Old 02-04-2012, 09:24 AM
fb88 fb88 is offline
Mein Auto: 2014 X1 xDrive28i
Any differenence with stop distance between 335 and 328?
Also I assume F30 still doesn't display the psi per tire?
Old 02-04-2012, 09:28 AM
justinnum1's Avatar
justinnum1 justinnum1 is offline
Mein Auto: F30 335i mSport
I would imagine similar distances...good question.
Old 02-04-2012, 10:42 AM
calmwinds calmwinds is offline
Mein Auto: maybe F30 328/335
I thought I read somewhere that the 335i has bigger brakes. Could be wrong
Old 02-04-2012, 10:59 AM
david in german david in german is offline
Mein Auto: BMW
335 has larger brakes, the advantage is not stopping distance but more brake cooling under harder braking conditions.
Old 02-04-2012, 11:15 AM
Mein Auto: BMW
http://www.edmunds.com/bmw/3-series/2008/road-test.html
If you read, the 328 is actually better at braking.
Old 02-04-2012, 12:03 PM
justinnum1's Avatar
Nice!
Old 02-04-2012, 12:09 PM
jwac's Avatar
jwac jwac is offline
Mein Auto: '14 335i 6MT
The F30 335i not only has larger rotors but also larger fixed calipers versus the sliding ones on the 328i. This wasn't the case on the E9x (the '35 just had larger rotors), so I'd expect the braking performance differences to be more pronounced between the two F30's.
2014 335i Sedan 6MT
Estoril Blue | Black leather | Dark Burl Walnut
M Sport | Premium | Driver Assistance Plus | Technology | Dynamic Handling | Cold Weather | 19" 403M Wheels | M Sport Brakes | Harman Kardon | Rear Window Shades | Auto High Beams
09.16.13 European Delivery
Past:
2011 335i Coupe 6MT (ED)
2010 135i Vert 6MT (ED)
2007 335i Coupe 6MT (ED)
2006 325i Sedan 6MT
Old 02-04-2012, 12:14 PM
jwac's Avatar
Probably not. BMW and many other manufacturers don't do this on purpose because the measured tire pressure of course varies based on temperature. If the software doesn't display a corrected baseline cold inflation pressure which is what you reference on the door post, the driver/user could misinterpret the readings if if they don't understand how it works.
Therefore, a lot of companies like BMW choose to only display a low warning instead of the actual psi.
2014 335i Sedan 6MT
Past:
2006 325i Sedan 6MT
Old 02-05-2012, 11:46 PM
westwest888's Avatar
westwest888 westwest888 is offline
Banned
Mein Auto: 2010 Audi S4
By the physics, the 328i is going to stop sooner (lower mass and constant braking power applied up to but before ABS limits you). The test doesn't get interesting until you repeat it 30 times and put heat into the system. The 335i has better braking equipment for dissipating heat and stopping the heavier car. At that point the stopping distances could increase by 50%.
Old 02-05-2012, 11:59 PM
Emission's Avatar
Emission Emission is offline
Automotive Monomaniac
Mein Auto: Schnelle Autos
I bet it is more dependant on tires than anything else.
The car with the stickier rubber will stop faster, and BMW is supplying All-Season and Summer rubber on the F30...
- Mike
I am fortunate to have unique press cars delivered weekly, but I own:
'16 BMW X5 xDrive35i M Sport 8AT
'15 Volkswagen Golf TDI 6MT
'86 Porsche 911 Turbo 4MT
Gone, but never forgotten... my E70 X5 35d, E90 335i, E46 330i, E36 328i, E70 X5 3.0si, E53 X5 3.0i.
Read my work as Editor-in-Chief for Autoweb and Autobytel!
Old 02-06-2012, 12:30 AM
Mein Auto: BMW
So, as long as I am not on the track I can consider my 328 the better stopper.
My normal commute is 50 miles one way on the autobahn. I can actually get on the bahn at times and not even touch my brakes till I get ready to exit at the 49 mile point of my drive.
I normally commute in my 118i though, I can see on it the brakes are not the issue but tire traction when it comes to stopping.
This thread actually changed my mind about upgrading to the BMW Performance brakes on my 3 series. I went throught the same thought process when I was thinking about upgrading my Mini Cooper S brakes to the JCW brakes.. I didn't upgrade them either. I did change to TSW rotors and EBC pads. That car would cause your breakfast from the day before to come up if you hit the brakes hard enough.
