Old 01-12-2012, 01:10 PM
Tlon Tlon is offline
Mein Auto: 2015 BMW X5 35i
Snap In Adaptor with case?
Hi,
Just curious if anyone knows if the snap-in adapter for BMW Apps (84-21-2-218-390) will fit an iPhone with a thin case. Or does the case need to be removed before installing?
Old 01-12-2012, 01:34 PM
ccieurzo ccieurzo is offline
Mein Auto: 2013 328i M Sport
The case will need to come off, it is a very tight fit.
Chris
2013 328i MSport
2012 X5 50i (returned due to PCS move)
2003 K1200RS
2008 M5 (traded for X5)
2004 330ix (former winter beater)
2003 M5 (traded with 103k, still working fine)
Old 01-12-2012, 03:06 PM
wmcilwain wmcilwain is offline
Mein Auto: 328i x-drive
Not to mention, there is a fan in the snap-in adaptor which would be blocked by the case.
Old 01-12-2012, 09:53 PM
cocosw cocosw is offline
Mein Auto: BMW
Good cases on http://www.chingtown.com/3d-phoenix-...e-4g-4s-4.html
Old 01-12-2012, 10:42 PM
apw2607 apw2607 is offline
Mein Auto: 2009 X5 35d
You don't need to use the cradle unless you want to display video out from the iPhone or use the native iPod interface on the BMW screen. Everything else is supported by the cable. Yes the cradle can use the external antenna for phone reception but it uses inductive coupling for that which doesn't seem to improve much on the iPhone 4s. The cradles are basically a waste of money.
Old 01-14-2012, 10:35 AM
Well, that's a real bummer. Thanks.
