Old 01-13-2012, 09:59 PM
Sandesh Sandesh is offline
Mein Auto: 525i
Check Engine - BMW 525i 2004
This morning, when I started my BMW (525i - 2004) the check engine sign came on!! The car also started vibrating. The exhaust seems intermittent. The exact message is - Engine Check. Drive moderately. engine High load may damage catalytic convertor. Drive at reduced engine load. Any ideas what this might be? I am afraid to drive the car. Mechanic says it is fine to drive it to his garage - approx 10 kms...
The shaking is quite pronounced. any suggestions?
Edit/Delete Message
Old 01-14-2012, 05:46 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
Without reading diagnostic codes, it'll just be a guessing game.
I'd guess one of the ignition coil is the culprit.
Old 01-14-2012, 09:33 PM
hawk2100n's Avatar
hawk2100n hawk2100n is offline
Save the Males!
Mein Auto: Der Reihensechszylinder
Could be a Vanos problem where the valve timing is stuck all the way advanced or retarded. Gives the exact symptoms, rough idle, difficult starting, high fuel consumption, possible smokey exhaust. A quick scan from the loaner code reader at a local parts store will give you a much better idea of what is going on.
'06 530iA, iDrive/Nav
Dead: 92 325i
Dead: 97 528i
Old 01-15-2012, 10:16 PM
Mein Auto: 525i
Just got confirmation - It was a bad coil. Replaced, now all is well... Thanks
Old 01-16-2012, 06:03 AM
pcy pcy is offline
Glad to hear your car is fixed.
Thanks for posting the update.
