Old 01-14-2012, 07:50 AM
brettnyc brettnyc is offline
Mein Auto: 2012 x5 sav
Lug nut torque spec?
Changing out the 20's tomorrow for my winter 18's. Anyone know the proper torque specs for the lugs?
Old 01-14-2012, 08:34 AM
ard ard is offline
Resident Curmudgeon
I use 140 N-m or 103 ft-lbs for the E70.
No luck with search? or owners manual?
Old 01-14-2012, 08:53 AM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 535i; 428 GC; Twin X1's
Proper torque values are shown on page 270 of the owner's manual (at least the PDF version. May be different int he paper manual). Is ard right? Well, yes ... and no.
Current BMW's:
2016 428 GC MSport
2014 535i MSport
2015 X1 28i xDrive
2015 X1 35i xDrive
Prior BMW's
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 01-14-2012, 12:07 PM
Thanks guys. I did do a a search but most hits were about engine torque specs. I live NYC and didn't feel like walking 5 blocks to my garage just to get my owners manual.
Old 01-14-2012, 01:20 PM
quackbury's Avatar
///Monkeyazz Duck
No need to walk anywhere. Go to www.bmwusa.com, log into My BMW and download the PDF version. Much simpler, and also much faster to search.
Current BMW's:
2016 428 GC MSport
2014 535i MSport
2015 X1 28i xDrive
2015 X1 35i xDrive
Prior BMW's
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
Old 01-14-2012, 01:24 PM
Old 01-14-2012, 01:28 PM
quackbury's Avatar
///Monkeyazz Duck
You're welcome.
Current BMW's:
2016 428 GC MSport
2014 535i MSport
2015 X1 28i xDrive
2015 X1 35i xDrive
Prior BMW's
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
Old 06-11-2014, 01:52 PM
rh71 rh71 is offline
Among the Proud
Mein Auto: X5 3.0si
It's not that easy to find the answer to this online - I needed to find out just now and the PDF manual pg 252 says: 101 lb ft / 140 Nm. I'm sure this will help others.
'08 X5 3.0si - Alpine White / Saddle Brown interior
Specs: Sport Pkg, Premium Pkg, Tech Pkg, Comfort Access, Aero Kit, Style 433 staggered 20s on Conti DWS
Mods: Carbon 35 tint, LED angel eyes, GP Thunder 7500k fogs, H&R 20mm/25mm spacers, clear reflectors, gunsmoke-tinted taillights
Coded: Digital speedo, windows/sunroof/tailgate close via keyfob
X5 pics at Flickr
Old 06-11-2014, 04:09 PM
ptabaco ptabaco is offline
Mein Auto: 2013 X5 xDrive35i
Page 303 on the 2013 X5 OM
2016 F15 - X5 sDrive35i
2013 E70 - X5 xDrive35i - Gone
2010 E60 - 528i - Gone
1998 E39 - 528i - Gone
1991 E30 - 325i - Gone
Old 06-11-2014, 06:34 PM
PAX5 PAX5 is online now
Freude am Fahren
Mein Auto: X5 50i
I better re-torque mine ... I've always torqued them to 95 ft-lbs ...
PAX5
BMWCCA #20645
Old 06-12-2014, 04:42 AM
Among the Proud
Mein Auto: X5 3.0si
btw, I know it's the conventional size, but what specifically is the socket size for the 120mm bolts? Also, is either the 1/2" or 3/8" drive wrench better generally speaking?
X5 pics at Flickr
Old 06-12-2014, 05:07 AM
Freude am Fahren
Mein Auto: X5 50i
What do you mean by 120mm bolts?
Anyway, I don't know about anybody else, but I use only 17mm, 6 point, 1/2 inch drive, deep socket.
I am also looking for a 6 point, deep socket that has a magnetic insert, because I hate it when the wheel bolt drops out of the socket and permanently nicks the wheel face ...
Anybody know where to find one?
PAX5
BMWCCA #20645
Old 06-12-2014, 05:27 AM
tlm999 tlm999 is online now
Mein Auto: '15 Macan
http://www.toolbarn.com/grey-pneumat...kkJg8e8hPD_BwE
If you don't like that one try a Google search as there are others.
Old 06-12-2014, 06:17 AM
Freude am Fahren
Mein Auto: X5 50i
Perfect! Just what I'm looking for. Thanks!
PAX5
BMWCCA #20645
Old 06-12-2014, 07:53 AM
Glad I could help. I'm thinking of getting a complete set for those other jobs where my fingers just aren't long or slender enough.
http://www.toolbarn.com/factfinder/?...omSuggest=true
Old 06-19-2014, 04:47 PM
Hd2000fxdl Hd2000fxdl is offline
Mein Auto: 2011 X5
In regards to the 3/8 or 1/2 drive,, normally you have a larger and longer make it easier to TQ to spec and the TQ wrench I use depends on application, I have 1/4 3/8 and 1/2 as well as a 3/4 drive TQ wrenches, it makes life a lot easier to use the right tool for the job, also rest them to ZERO to avoind having to get them recalibrated all the time.
Harry
Old 06-19-2014, 06:17 PM
ard ard is offline
Resident Curmudgeon
nobody picked up on quacks' comment so long ago....'yes, ...and no'
Is 140nm=?
103.3 ft-lbs (ie converting 140 using a conversion factor)
or
101 ft-lba (Based on the manual)
Unless those wily german engineers have different torque specs depending on which unit of measure one is using...
Old 06-19-2014, 09:00 PM
Among the Proud
Mein Auto: X5 3.0si
^ well you're right, 140nm converts to 103ft-lbs. So once again I'm not sure what to use 101 or 103.
X5 pics at Flickr
Old 06-19-2014, 10:44 PM
Nube1kenobi's Avatar
Nube1kenobi Nube1kenobi is offline
U of Dawgs
Mein Auto: 08 535iA Spt/11 X5 35i
Either one should be fine. I have a feeling your torque wrench has not been certified annually like it should be either.
Nube1Kenobi
2011 X5 35i Sport Activity|Plat Gray/Beige/Dk Poplar|Conv Pkg|Cold WX Pkg|Tech Pkg|Prem Sound|Comfort Seats|Hitch|
2008 535i Mon Blue/Dakota Blk/Dk Poplar|Sports Pkg|Prem Pkg|Cold WX Pkg|Nav|RTTI|PDC|L7|HD|I-Pod/USB|PWR Rr shade|Sports Auto - paddles|Active Stg|Comfort Access|F/D R/seats|Rr DMS Airbags|Adaptive Xenons
Do not argue with an idiot else he lowers you to his level and beat you down with experience..
