Help!! My 2003 745i Wont Start. - Bimmerfest - BMW Forums
Old 01-15-2012, 09:30 AM
KingAlex KingAlex is offline
Mein Auto: 745i
Question Help!! My 2003 745i Wont Start.
One morning i heard a clicking noise under the hood but it went away after a couple minutes. Later that day on my way from work it did the same thing, this time when i got home it was louder When i turned the car off i try'd to crank it again and it only got weaker and weaker, and then it died. I also smelled a burning smell under the hood when it died. Now when i try to start i can only hear a clicking noise under the hood. Could the motor be locked or the starter? No codes popped up or warnings?!
Old 01-15-2012, 09:40 AM
Black_on_black Black_on_black is offline
Banned
Mein Auto: 745i
Sounds like a starter motor
Old 01-15-2012, 09:52 AM
Mein Auto: 745i
Yeah that sounds good, any idea of the cost on it?
Old 01-15-2012, 06:38 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Pop off the main belt and make sure you can still spin all the pulleys by hand. A few of us have had our alternators seize up (mine has) or come close. Regardless, you'll likely find something acting a little funny, and if not, try to start it with no belts on. If it starts while being jumped, but not without, then you have a dying battery. If if does not start while being jumped with the belt off, then you have a bad starter (fairly unlikely). If it starts just fine without the belt on and without being jumped, then it's being dragged down by something that the belt wraps around. Hope this helps!
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 01-15-2012, 06:48 PM
Mein Auto: 745i
Thanks sooo much but as far as the noise i heard any idea of what that may have been?
Old 01-15-2012, 07:29 PM
Master Tinkerer
The noise before the car died? I'd suspect the alternator bearings going out, especially if it was more of a dull knock than a high ticking sound.
Old 01-16-2012, 04:51 AM
Mein Auto: 745i
Can that even happen in that case, the alternator and starter go out at once?
car wont start, motorlock, starter
