Old 01-15-2012, 11:19 AM
dbs600 dbs600 is offline
Mein Auto: 2011 750LXi Individual
Key and Seat Programming
How do I program my key, so that if I use Key 1 and another person uses Key 2, that when I get into the car, the seat is automatically adjusted to my seat position stored as Memory 1? Thanks!
Old 01-15-2012, 11:48 AM
eLECTRO eDITION's Avatar
eLECTRO eDITION eLECTRO eDITION is offline
Mein Auto: BMC TMR01 di2
BMW driver profile eliminates confusion with specific program KEY for each user. With a fleet, specific car key would be a problem, USB user profile is smart choice for multi user.
Driver profile saves via glove box USB. Three user profiles available. Save your personal profile to first blank USER PROFILE and then change the other profiles to other drivers.
The driver profile function is a basic multi button process, check the owner's manual.
Old 01-15-2012, 02:28 PM
Correct me if I am wrong, but I don't believe you can select different user profiles that have been saved by use of the key as you walk up to the car, as you would have to get into the car and then select from same from the display. Isn't there a way I can associate a certain seat / steering wheel / mirror configuration with a key, so when I use the key to unlock the car, the seat / steering wheel / mirror positions all change before I get into the car? Thanks for your prompt reply!
Old 07-06-2012, 03:17 PM
Before I begin, please note I'm very concerned with the potential to lose my seat/wheel/mirror adjustments, radio presets and other vehicle settings, BUT THIS IS DRIVING ME NUTS:
There are two drivers with two keys with both Memory 1 and Memory 2 for the driver's seat programmed. HOW DO I program the car so that when I use my key to unlock the car, Memory 1 for the driver's seat is pulled up, while when the other key is used to unlock the car, Memory 2 for the driver's seat is pulled up!?
Otherwise, why is "Parked-Car Ventilation" greyed-out and I'm not able to select from same? What does the feature do anyway; the car can turn on its HVAC fans at a preset time (i.e.: for morning and evening commutes at 8:30 AM and 5:30 AM, respectively)?
Please advise.
ID:	331885   Click image for larger version
ID:	331886   Click image for larger version
Old 07-07-2012, 07:23 AM
BaranE BaranE is offline
Mein Auto: '10 740Li
You can only select Parked-Car Ventilation when Engine is OFF and Ignition ON.
Old 07-07-2012, 11:28 AM
kpumroy kpumroy is offline
Mein Auto: 2014 Audi A6
I believe momory one correspnds to key one and memory two corresponds to key two. A little trial and error should show you which key is which. Save profile to USB lets you save settings to a USB thumbdrive and transfer them to say another vehicle or if the battery is disconnected you can restore the settings from the thumbdrive. You dont have to save your profile to the key as it happens automatically.
Old 07-07-2012, 11:43 AM
Thanks.
Thanks, but I don't believe so, as I use Key 1, another driver uses Key 2 and Memory 1 and Memory 2 are the same (remained programmed) whether Key 1 or Key 2 are used. Also, when I use Key 1 to enter the car after Key 2 and Memory 2 had been used and selected, the seat does not automatically move to the Memory 1 position when I unlock and enter the car...
Old 07-07-2012, 11:51 AM
Well that is certainly strange. Both my 750 and X5 work as I described. Maybe someone else has an idea?
Old 09-05-2012, 10:50 PM
750Rick 750Rick is offline
Mein Auto: 2015 750i
Have you tried pressing the unlock button on the key fob to enter the car? I think that is what it takes to let the car know which setting to use.
Old 09-06-2012, 05:56 PM
wjhughes420384's Avatar
wjhughes420384 wjhughes420384 is offline
2009 F02
Mein Auto: 750li, XJ8
when you set the seats and mirrors with key 1 those settings are locked to key 1
take key 1 away from the car, get in the car with key 2 and let that driver set the seats and mirror to their liking.
when you walk up and open the car with key 1 the seats and mirror go to those settings
when you walk up and open the car with key 2 the seats and mirrors go to those settings
2009 750Li - Space Grau Metallic, Camera pkg, Conv pkg, Driver Asst pkg, Lux Seat pkg, Lux rear seat pkg, Prem sound pkg, Sport pkg, HUD, Massaging rear seats, Smartphone integration, Sat radio, MTEC H8 4750K Halo lights
