Old 04-25-2012, 05:50 PM
Swif Swif is offline
Mein Auto: 04 745Li
Installed IPSM and took apart the old module. I found on fuse with a over heated blade. Fuse was good, but one leg was over heated. I check the circuit board for burn marks and nothing. Not burnt smell ether. I did how ever notice what looked to be water marks like water ingress had taken place at some time. No mold or corrosion though.
I am working on running the car at idle for 20 min and then let it sit for some time then firing it up again. see if the no start is still present.
Old 04-29-2012, 09:00 PM
Mein Auto: 04 745Li
So after letting the car run off and on for about 2 hours no problems.
I have driving the car this past weekend and not problems. It has been worm out side and car has started right up with no problems.
Old 04-30-2012, 11:12 AM
PeteyPablo PeteyPablo is offline
Mein Auto: 2004 745Li
Integrated Supply Module
I am sure that you have already fixed this issue but I had the same problem. I tried a number of fixes before I replaced the integrated supply module. Once I did that I haven't had a problem since.
Old 05-05-2012, 08:54 PM
Mein Auto: 04 745Li
After a week of driving not issues with the car . Shifting seems to have improved as well. Going to try and have the software in all modules updated next week.
Old 05-06-2012, 10:38 AM
dingxhng dingxhng is offline
Mein Auto: 2008 750Li
I had my car with dealer 3 times for totally 17 days in April. Posted couple of weeks ago to share experience and resolution.
Old 05-05-2013, 09:24 PM
JUBMW JUBMW is offline
Mein Auto: 2003 BMW 745LI
Have your problem been solved bcz I am having the same symptoms that you have stated.
Old 05-06-2013, 10:54 AM
Albi45 Albi45 is offline
Mein Auto: Bmw 745li
Car shuts off
It's some kind of module that needs to be replaced. The price goes from 120 for the part. That happened to me as we'll.
Old 05-07-2013, 07:09 AM
Jahlive Jahlive is offline
Yup just changed mines last week and all is well.
Old 06-21-2013, 11:57 PM
BraveHelios BraveHelios is offline
Mein Auto: 545i
Originally Posted by DFEL750I View Post
If the car is not cranking at all then I would looking into the integrated power supply module. Seach for it on here and you will find some answers.
For those that have changed the IVM (Integrated Supply Module); did you disconnect the battery first? Going to be doing this very soon and don't want to kill anything! Thank you!
Old 06-22-2013, 09:46 AM
No just swap out
Old 06-22-2013, 04:38 PM
Mein Auto: 545i
Confirmed; unit swapped out with battery connected. No issues before, during and after installation. Now I hope that it takes care of the no crank issue!
Old 06-25-2013, 12:00 PM
Btw my issue was the Crank sensor.
