AE Side by Side Comparison... and finally found a good one!! - Page 4 - Bimmerfest - BMW Forums
Old 03-04-2012, 06:22 AM
gassy gassy is offline
BMW 7 Series Obsessed
Mein Auto: 2016 M4 Champagne Quartz
If I'm not mistaken, the 2012s come with factory white AEs. How hard could it have possibly been to retrofit THAT bulb to earlier models? Is the bulb and housing design so radically different that plugging the new model bulb into an older model vehicle will not work?
Old 03-04-2012, 06:45 AM
haastx10 haastx10 is offline
RocknDoc
Mein Auto: 2015 M5 DINAN
The 2012 uses the same set up as the priors... regular H8 bulb which lights very yellow! New headlights are slated for the 2013 model I believe!
________________________________________
2015 BMW F10 M5, Space Gray, Dinan Stage 1 Engine, Exhaust, Coil Over Suspension, Sway Bars, Vorsteiner Staggered 9 /10.5 '20's, Custom Coded.
Old 03-04-2012, 08:09 AM
FalconFlyer FalconFlyer is offline
Mein Auto: Tampa
That is correct... The 2013 will come with all LeD headlights....
2017 BMW 750i M Sport
2017 Mercedes Benz AMG SL 63
2016 BMW 750i M Sport (Sold)
2015 BMW M6 Grand Coupe (Sold)
2015 BMW M4 Convertible (Sold)
2015 BMW X6M (Sold)
2015 BMW X5M (Sold)
2015 BMW 750Li M Sport (Sold)
Old 03-04-2012, 07:21 PM
Tdrag97 Tdrag97 is offline
Send a message via AIM to Tdrag97 Send a message via Yahoo to Tdrag97
Mein Auto: 09' E70 , 06 IS350
Originally Posted by FalconFlyer View Post
TDrag 97... nope.. I have not noticed the ballasts that hot.. no issues at all.... but I will keep a eye one it.... also the installation was a breeze... the only issue I had with my Z4 was the fact that you are supposed to remove the plastic spacer ring around the bulb... it took me 30 minutes to realize there was a issue... so I called Alex.. .and found out what I did wrong....
Thx guys. So for our f01. Do we need to remove the plastic spacer?
[SIZE=2]a.k.a. Tommy T
Old 03-04-2012, 07:41 PM
SAMLAMBO SAMLAMBO is offline
Mein Auto: BMW, Mercedes, Ford
and it will probably cost a bomb to have it replaced to our cars
2012 BMW 740i
2011 Mercedes E250
2007 Lamborghini LP670-4 SV
Old 03-04-2012, 09:02 PM
Mein Auto: Tampa
Samlambo... well I know that on the X5... to go with the OEM LED lights cost 4k per light.. so 8k... lol
Tdrag97... for the F01.. no, you don't remove the spacer.... I think :-)
2015 BMW X6M (Sold)
2015 BMW X5M (Sold)
Old 03-04-2012, 09:11 PM
Holycow!
2012 BMW 740i
2011 Mercedes E250
Old 03-05-2012, 09:18 AM
ok.. and how about for the X5.. remove or leave it on..
Old 03-06-2012, 06:55 AM
Mein Auto: Tampa
I don't know about the X5 yet.... Alex is supposed to be sending that unit to me this week.... so I will have a report. Right now the only time you remove the spacer is on the Z4...
2015 BMW X6M (Sold)
2015 BMW X5M (Sold)
Old 03-06-2012, 09:29 AM
sweet.. ..
I found this picture on another board..
Name:	white spacer.JPG
Old 03-06-2012, 12:28 PM
Alex reply and said for the F01/F02 we would remove the White spacer. He also said the will have a install video for the 7-series up soon.
Old 03-07-2012, 05:38 AM
RocknDoc
Tdrag97... That's correct. NO white spacer needed on the 7's.
Just an FYI on the pic you posted and to avoid any additional confusion since the "white spacer" has already caused so much discussion and misinformation...
Whoever took the pic also left on the clear plastic base cap with the "8000K" on it in place. This holds the bulb securely in the shipping container and also must be removed PRIOR to installation by sliding it over the rubber grommet BEFORE you put the grommet through the hole in the light box cap. Otherwise you wind up with too much "stuff" in the light housing.
Old 03-08-2012, 09:08 PM
Thx haastx10. Just got my
Light in from alex and finish the install on the X5. Also had to remove the white spacer. But look like I will have to remove the driver side to remove the plastic shipping base protector. Lol. Try to get the install in before dark.
Old 03-08-2012, 09:13 PM
Oh btw Alex got F01/f02 install video up on YouTube. "Alpine HID f01 install" But question. Not really liking where they put the ballast for the 7 series... Where did you guys install the ballast?
As for the X5. There is a perfect spot , just on top the light housing (signal light)
Old 03-15-2012, 09:32 AM
I will have mine installed tomorrow and post pics, can't wait!
2012 BMW 740i
2011 Mercedes E250
Old 03-16-2012, 04:56 AM
Finally had the alpine hid's from Alex installed today. Mine are the 8000k which I feel is perfect. Attached below are two photos. One under the shade and the other under bright sunlight. We didn't have any problems with the installation, no flickering of lights whatsoever. Got to admit, it looks way better than stock. Yes it has a slight blue tint to it but it's very slight. Thanks to all over here who have contributed to this post and thank you Falcon.
Under the shade in workshop
Under bright sunlight
2012 BMW 740i
2011 Mercedes E250
Old 03-16-2012, 05:28 AM
bruno787 bruno787 is offline
Mein Auto: 740Li (F02)
@sam
under the sun pics seem to show only the inner rings are illuminated??? how much whiter is it compared to the philips 6000k h8 bulbs???
15 Maserati Quattroporte GTS
10 740Li (gone)
11 Mini John Cooper Works
12 Range Rover Evoque Dynamic Si4
Old 03-16-2012, 06:01 AM
Originally Posted by bruno787 View Post
@sam
Dear Bruno,
it's way brighter than the philip bulbs I had. Again it depends from which camera and angle your taking the photos. I belief a lot of those installed and posted here have done justice to this product. Also to add here, there still was some daylight in the workshop in the first photo.
2012 BMW 740i
2011 Mercedes E250
Old 03-16-2012, 09:06 PM
Samlambo. You don't find it too blue? Give it a few days and let me know. I'll be installing the new 7k bulbs and ballast on out 7 this weekend.
Old 03-16-2012, 09:56 PM
Honestly it looks more blue in the photos than seeing it in person. It's looks like Falcons photos in his first post in this thread.
2012 BMW 740i
2011 Mercedes E250
Old 03-17-2012, 09:48 AM
petercnj petercnj is offline
Mein Auto: BMW 335xi
Does anyone have any warranty concerns with installing the aftermarket AE?
Old 03-17-2012, 02:20 PM
Mein Auto: Tampa
No... other than the $8 dollar cap you are drilling into... and the wire going to the hot battery pickup... there is zero that is affecting the car...
2015 BMW X6M (Sold)
2015 BMW X5M (Sold)
Old 03-17-2012, 03:21 PM
Old 03-21-2012, 12:36 AM
vinnyraj vinnyraj is offline
Mein Auto: 2010 335d
FalconFlyer, have you had any experience with the MTEC AE's?
Old 03-21-2012, 04:55 AM
Mein Auto: Tampa
Yep.... I tried them.... they are not that bright.... nothing close to the Alpine MSS lights...
2015 BMW X6M (Sold)
2015 BMW X5M (Sold)
