6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations. |
I believe that I have a very slow leak in one of my tires. I've read that you can't repair a run flat tire but I was wondering if a slow leak could be repaired. I wouldn't want to buy a new tire due to a slow leak.
2008 650i Sport Convertible Monaco Blue | Saddle BrownLeather | Comfort Access | Cold Weather Package | Park Distance Control | Heads Up Display | Navigation | Sirius | Logic 7 Premium Sound HD Radio |
usually a slow leak is at the rim vs the tread or at the valve...
I'd bring it to a tire shop so they can dunk it in water to see if the leak can be found... if none are seen, I'd leave it be and top it off, consider nitrogen fill (they claim it minimizes leaks - but I don't know) or have it unmounted and remounted and the rim cleaned.. if the leak is at the tread through a hole, you can repair it... since it's never been driven with extremely low pressure (or has it)...
07 650i Cabrio CPO, Titanium Silver Black Matte Grill Dark Birch Wood Interior and Shifter HUD, Cold Weather and Sports Package Logic 7 Sound Aluminum Racing Pedals K&N Air Filters Rays Master Piece REM 20" Forged wheels w/ Conti Extreme DWS |
Thanks for the info. I've never driven it with extremely low pressure. I've only owned it for a little over a month so I'm not sure what was done before I owned it. I'll take it to a tire shop soon.
+1 - as long as it's not in the sidewall. When the tire comes off to be repaired, be sure there is NO crease in the inside of the sidewall (this would indicate the RFT has been used), in which case, I'd suggest getting a new tire.
Nick / TopDownInFL (sans the "top down") 2012 650 Coupe - Alpine White / Black Interior / M Package / Premium Sound Previous Bimmers: 2008 650i Convertible - Monaco Blue / Saddle Brown Pearl Leather / Premium Sound / Sport / Cold / Comfort Access / Lane Departure / HD Radio / Sat Radio 2004 645Ci Convertible - Reverse Sensors / Reverse Camera / Retro iPod 2005 545i Sedan 2003 330Ci Convertible 2001 330Ci Coupe 1998 323i Convertible 1995 318i Sedan |
I agree with all here. A slow leak could be nothing more than a bad seal (I experienced that with a SC430 once) and remounting the tyre will fix it. Personally, I do not recommend plugging a run flat (this is where raod hazard insurance for wheels and tyres pays off).
Good luck!
2012 Mini CooperS convertible 2008 135i Convertible - Sparkling Graphite Metallic Prior BMWs: `05 645CiC; `07 650i; `08 M6 convertible; `11 750ix MSport 2004 GX470 |
i once plugged a runflat tire while on a roadtrip. I was going to replace it once i returned home but got curious as to how long it would last. 23,000 miles later i replaced it!
Never once had any indication that it was a plugged tire. *it was hell getting the plug in it though, that's one stiff Mother!!!*
![]() 2010 335i dressed in all black, 2004 645ci dressed in all black as well.....ok, i like black! ![]()
it all has to do with sidewall damage when the tire is driven with no pressure... since the manufacturer can't tell if the tire was driven in this condition or not, they (for liability purposes) recommend against plugging (also increases sales of a low volume tire)...
but if you are 100% sure it was never driven without pressure, then plugging a hole in the tread area should be no different than non RFT... a tire wall puncture is a different issue... But I have hazard insurance so I for one will be getting a new tire if I get a hole...
yes it can, i just had mine plugged 2 days ago.
Patch mine good hear for a year
Mods Rpi scoops and filters with block off plates Vorsteiner carbon lip,Deck wing and Rear diffuser Black mantle grill H&R 15mm spacers for front and back Go Wide Painted front and rear brake calibers with M logo Exhuast rensinator delete with cats removed Lexus L 460 touring package Family car Svt mustang Cobra racer Lexus Gs Modded Daily Bmw 650i Cabrio Sold Saleen s 351 |
Better off patching. Plugs are not an acceptable repair for run flats as per my tire dealer.
I'd suggest you first get the tire and the wheel it's mounted on tested in a dunk tub. I had a similar problem last summer and made the assumption it was the tire. Nobody here would accept patching it, so I could either get a new RFT tire (approx $500 for the tire and mounting) or I could buy all new non-RFTs all around (the RFTs looked like they only had about 10,000 miles left on them). So I replaced all the tires with non-RFTs (cost me $1100). A week later one of those new tires was low on pressure. Turned out my rim had a small little crack all along that was causing slow pressure loss. It took $50 and a couple of days for a local shop to have the rim repaired. No issues since.
----------------------- ![]() 2006 BMW 650i |
i get punctures every month & just take it to the tyre shop to get it fixed. Of course if there is any damage to the tyre wall then it's a new tyre.
With regards to filling it with nitrogen it does reduce road noise and I noticed a slight improvement in mpg. But I still got punctures though. |
Had a slow leak that I filled two times in the past three weeks. went and got it patched for free today at Discount Tire
2008 BMW 335i Retired 2009 BMW 535i Retired 2012 F30 335i sportline (Black Sapphire/Black Leatherette/Black High gloss trim, Technology, Sport Auto, Premium Sound, BMW Apps.) |
I had a 545i sport with 18" runflats years before I knew about this forum or the differences in runflats other than that they ran flat. I had my tpms light come on and had the tire plugged for $10 at a gas station. I must have put at least 10k more on those tires before I sold the car.
Would I do it again? No, but I didn't have any problems with mine and I drove that thing like I stole it daily. Now I would probably just use it as an excuse to upgrade to some nice non runflats.
![]() 2008 E63 M6 - Black Sapphire - Sepang Bronze Full Merino - Carbon Fiber Trim - Alcantera Headliner - SMG - HUD - Soft Close Doors - Comfort Access - Individual Audio w/Sat and HD Radio 2009 E92 335i - Black Sapphire - Black Dakota - Burl Walnut - Sport - Premium - Cold Weather - Navigation - L7 - Comfort Access - Smoker's Package Member: BMWCCA #471614 |
