6 Series DIY
6 Series Do It Yourself (DIY) forum. |
DIY Paddle shift? No retrokit
Hi,
I am looking at these padde shift retrofit kits on the web and I can't believe how much money they're asking for it. ~ $1300 for some flappy paddles (+wheel and harness) seems like a steal! What I'm thinking is that it should be fairly simple to skip the kit and build it myself. My thoughts: I buy the paddle shift separately. I wire up the paddles to the gearbox stick with some home made wiring harness (shouldn't be too difficult once you find where to put the cables in the gearbox console) I remove the steering wheel and cut out holes for the paddles and install the paddles. Am I missing something here or should this work? This way it should not cost more than a couple of hundred bucks + a couple of hours of DIY-labor
'09 740i (Black sapphire metallic) Last edited by jacobsweden; 01-18-2012 at 07:24 AM. |
Anyone?
'09 740i (Black sapphire metallic) |
I have an SMG e63 but for my e39 I did exactly what you are thinking of doing.
My e39 Paddleshift retrofit: I bought an e46 SMG steering wheel with paddles, I also got an e46 SMG Switch unit steering column. The only difference between the SMG "Switch unit steering column" slip ring & the regular one is the additonal 2 connectors on it for the paddles. From here you just need to run wiires to near the gear shifter & connect up the + & - wires as appropriate. It is a bit disappointing in the auto having the paddles, especially when you drive a real SMG, the shifts are just not quick enough. If you need a VIN number of a car with SMG fitted to determine what slip ring you need just PM me for mine. |
Yes I understand that the shifting will not be as quick as the SMG box but I think it works (If it works as "quick" as using the manual mode on the gearstick I'm happy) I will be pleased if you can send me your VIN, I'll send you a PM.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
