BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great! |
The Dreaded SES Light Happened to Me
After 16K fault free miles, the SES light on my d came on today on my way home from work. No diminished engine power and no other signs of problems, just the light. Called my dealer and they said to bring it in on Friday morning and they will check it out. I'll wait an hour or so and if they can fix it quickly I'll just drink their coffee and chill out. If they need parts, I'll take their loaner car for the weekend. If the DEF was low I would get a warning message, right? I just had the car serviced at 13K miles in November and they supposedly topped it off so I don't think this is the problem. I did notice last night that when I shut it down in my driveway it was in the middle of a particulate filter burnoff because I could hear the fan running and smell it. I'll update this thread on Friday evening when I am told what the caused the light to come on.
Colonel (Ret) US Army / Hagerstown, MD 2010 Z4 s30i Alpine White/Beige PP/SP/CWP/6MT/CA/NAV/ipod/USB ED 1-29-10/Redelivery 3-8-10 (weekend car) 2013 Audi A6 Quattro (daily driver) 1985 M635 Euro 2011 335d (Ret) 2009 335i vert (Ret) 2007 335i vert (Ret) 2000 740iL (Ret) 1998 328iC (Ret) 1990 535i (Ret) 1988 635CSi (Ret) |
Once SES light came on when I got into my car after work. I remembered I shut it off when it was in middle of its cycle. So took it out for drive (15miles) in addition to drive back home and next day morning it was gone. I say give it sometime they usually correct themselves.
My SES light came on while traveling in another state over Christmas. Out of state dealer wanted to keep the car to diagnose and repair, but said it was OK to drive. Next morning light went off and stayed off till I got dealer to look at it a week later at home. Dealer found code 4035 stored for metering valve per SIB110210. Tech cleaned metering valve and reset light. Covered under warranty. No problem since; now at approx. 4500 miles.
2011 335d M-sport 2008 535xi: now in lease heaven |
If it goes out I will cancel my Friday appt. Nearest dealer is 50 miles away so I am not looking forward to taking it in and missing 4-5 hours of work. I turned off the engine last night while in a burn off cycle and my commute is about 60 miles so I had driven it to work this morning (30 miles) when it came on this afternoon as soon as I started the engine on my trip home. Would be nice if it stayed off tomorrow morning when I start it up to go back to work.
I got the SES light on my '09. The DEF injector was clogged. They replaced the part with an updated design. Happened around 20,000 miles.
Previous BMW's: '79 530i, '93 325iC, '97 740i, '99 540i, '00 M5, '03 X5, '05 645i, '09 335d, '11 335d |
mine lit up a couple weeks ago, it was a wheel speed sensor that went bad, they reprogrammed it and told me if it went on again to call and they would replace it, a few days later it did and they did, no ses light since
11 335d 2010 S1000RR 08 K1200GT 08 WR250R |
It is times like this when the Garmin Ecoroute is real handy. You can read what code has tripped and reset, if it is resettable.
You do not get an SES light if your DEF is low. You get a specific warning about the DEF itself being low.
--Aaron |
I do not think that though will let you see the shadow codes. Which is why I got the BT cable back when I thought the dealer was lying to me and I wanted to run codes myself.
--Aaron |
Almost every time I show up at the daycare in my car, it is in the middle of the cycle. I have shut it down countless times in the middle of a cycle an never once had an SES afterwards.
--Aaron |
Maybe so. I'd recommend buying some sort of code scanner then you can have a better idea for next time. They even make ODBII scanners that run on phones, friend has one for his android based phone.
--Aaron |
Does anyone have experience with installing the Execuhitch on the 335d? Mine is 2009 E92 I believe. Dean at Execuhitch says it is OK but would like to talk to someone who has installed.
24K miles and no problems. Just fun. |
So I get SES again but this time it is not willing to clear on its own. Came on Wed evening. Everything runs pretty much same except for climate, we had first snow storm in last 2 days. I am going on extended vacation starting next weekend so I will see if I can get appointment.
Good luck, most likely an issue with some of the emission equipment. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
