Old 01-21-2012, 12:32 PM
poolman poolman is offline
Mein Auto: 525i station wagon
Vacuum leaks revisited I-6 Engines
Since my original post on Batteling vacuum leaks disappeared a few months back--figured now is the time to just list all of the spots that owners need to address.
#1--Air duct between the throttlebody and idle control valve--the ribbed section will
develop holes over time and cause all sorts of problems.
#2 DISA valve, where it hooks to the intkae manifold--as the part goes through heat cycles
the 0 ring will allow unmetered air into the intake--cause lean conditions.
#3 CCV System--there are 4 hose's on this system and can be somewhat of a bear to replace unless you read up on the how too's--there are many posts covering the replacement of these parts--
#4 The distribution unit that sits on top of the itake manifold and hooks into the CCV system. There are 6 small 0 rings that make the seal to stop air from leaking by. Whne doing the CCv system--I suggest that these 0 rings should be replaced and a good cleaning of
the distribution unit be done at the same time. I just remove the part and then fill with gasoline and let it set for an hour or two the blow the part out with compressed air.
#5 Valve cover gasket--if you have any oil seeping out from the passenger side of the valve cover and puddling, you have a vacuum leak as well--replace the valve cover gasket and all will be well again.
#6--there are a 3 hoses back behind the intake manifold on the driverside of the car that control the secondary air injection system. Too se what all is going on back there , you will need to remove the cabin air duct on that side--unhook the duct from the filter housing and then turn the duck upwards at a 90 degree angle from the fire wall and the part will disengage
Then with a small mirror and flashlight you can see the hoses that will need to be replace--while there--inspect the vacuum caps on the intake--I have found those to split and leak air after they get old.
#7 The hose going from the jetpump to the brake booster--there will be two of these--one goes to the jetpump from the intake manifold and is a real bear to remove without removing the intakE --(BUT I did it once)The other half goes from the jetpump to the brake booster.
#8 There is an 0 ring at the base of the oil dipstick--if you replace your CCV system
you will need to replace this 0 ring as well.
#9 Fuel injector 0 rings, after reading Doru's post about this problem, that will be my next venture when warmer weather reappears.
#10 I guess the gaskets for the intake manifold can or should be counted in this write up, but, I haven't heard of this happening very often--
Hope others can list other spots to be checked and also hope this helps some with their problems
Old 01-21-2012, 01:26 PM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
This is probably one of the most useful posts ever.
BMW--giving new meaning to the phrase "disposable income."
Old 01-21-2012, 02:45 PM
Fudman's Avatar
Fudman Fudman is offline
+1, this is probably THE most common problem on E39s, and the frequency of this occurance is increasing as the rubber and plastic hoses and gaskets age and crack. Nice, Poolman!
Old 01-21-2012, 04:06 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I just got my smog-only inspection notice in the mail so now I MUST get my P0172, P0174 lean-condition misfire fixed.
I'll be checking, one by one, EVERYTHING, in this thread, since I absolutely hate to throw parts at a problem.
Old 01-21-2012, 05:28 PM
cn90 cn90 is online now
Great post.
Also, it is important to point out the newbies that the Vacuum Hoses are different for:
1996-1998 I6 vs 1999-2003 I6 year models.
Old 01-21-2012, 06:06 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
You might want to include the fuel tank breather valve to intake hose, the hose from the "F" connector to the fuel pressure regulator, and the ICV grommet on the intake manifold.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 01-22-2012, 05:09 AM
Blackpan Blackpan is offline
Mein Auto: 1999 528 I
Hi new to this forum .just got a 99 528 dealing with vacuum issues too. I could hear a whistle from the back of the manifold at the seam .I temporarily jb welded it .it got better (rough idle when cold )then I found a pin hole just above where you connect the vacuum hoses .very hard to get in there so I got some of that flex seal (as seen on tv)sprayed it in there. Now it runs great all the time .found a manifold on craigslist. Guess I'm doing that tomorrow
Old 01-23-2012, 02:07 AM
gsbmw gsbmw is offline
Mein Auto: 2000 323i
A very common fix for lean codes for both banks is the easy replacement of the cracked (often broken in two!) oil vent hose that connects the bottom of the oil separator to the dipstick tube. It is easy to get to and replace -- and it's cheap (~$11 at AutohausAZ). This easy DIY will show you where to look, etc:
http://forum.e46fanatics.com/showthread.php?t=773551
Just takes a few mins to clip on one end of the tube to the oil separator and friction-fit the other end to the dipstick tube (no need to remove any parts, although you may want to tilt the pwr steering reservoir toward the car's left fender to give more room (without disconnecting any steering hoses).
This could definitely be the problem, except perhaps for those who replaced the entire cvv and hoses already. Read the DIY -- lots of help for the newbie.
Old 01-24-2012, 07:31 AM
Thanks for the kind words and input --would be nice if there is a way to update the list when new spots are indentified. From what Steve530 added, looks like most of the spots are covered.
Old 01-24-2012, 11:40 AM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
This is what i remember
#11 Throttle body gasket
#12 MAF big o-ring
#13 SAP Valve gasket
#14 Small vacuum hose from SAP Valve to secondary air injection system
#15 Hose from SAP to SAP Valve
Old 01-26-2012, 03:30 PM
Here is another post I found that may help some people. It shows some realoem.com diagrams of the hose-related vacuum system and some how-to info as well:
http://www.bimmerforums.co.uk/forum/...-leaks-t40634/
Seems like most causes of leaks are covered here, but if nothing here works for anyone, just googleing "BMW vacuum leak" will give you many options, some of which may offer new information to help fix the problem. Of course, searching all of the BMW forums should help, but BMW forum threads (as well as YouTube videos) are covered in google. Good luck all!
Old 01-30-2012, 06:19 PM
JamesO JamesO is offline
Mein Auto: '06 330Ci Vert. '03 M5
I have been working on this post on E46Fanatics for the normal BMW cold weather misfires, CEL, rough running and idle.
I think this is pretty comprehensive and might be helpful as well.
http://forum.e46fanatics.com/showthr...1#post14032549
Old 01-31-2012, 12:10 PM
Blight67 Blight67 is offline
Mein Auto: 2002 530i Sport Pkg
Code 245 / 246 - Secondary air system
I just experienced the broken vacuum hose to the SAP valve this morning. I was expecting to need to replace this hose soon since I noted that it was brittle a few weeks back when the valve was replaced. What I didn't know was that this is accompanied by codes. If you see a code 245 / 246 (Secondary air system Bank 1 / 2), there is a good chance it is this hose.
A quick stop at O'Reilly Auto on the way to work for $0.50 of vacuum hose was all that was needed to fix the problem.
The code is thrown after engine is started (when SAS in use). I'm not sure what sensor is used to monitor for the leak but report details indicate: "SL-Flow rate to littel".
Detailed report:
E R R O R M E M O R Y R E P O R T
Date: 01/31/12 08:54:02
ECU: MS430DS0
JobStatus: OKAY
Variant: MS430DS0
RESULT: 2 errors in error memory !
246 Secondary air system Bank 2
Error frequency : 2
Logistic counter: 40
TCO_ST 22.23 Grad C
TIA_ST 22.97 Grad C
N_32 1024.00 rpm
VB 13.67 V
aufgetreten vor (rel. BZ) 0.80 h
Error to relevant
Error debounce
Error currently available
stat. Error
Errorcode: F6 78 02 28 5E 5F 20 86 68 39
245 Secondary air system Bank 1
Error frequency : 2
TCO_ST 22.23 Grad C
TIA_ST 22.97 Grad C
N_32 1024.00 rpm
VB 13.67 V
Error to relevant
Error debounce
stat. Error
Errorcode: F5 78 02 28 5E 5F 20 86 68 39
Old 01-31-2012, 12:25 PM
This is a great list. Lately, I've been checking off the list of expected vacuum leaks. I've already experienced most of the leaks and knowing this list ahead of time allowed me to do some preventive maintenance and/or anticipate and quickly diagnose the issues if they occur.
I am familiar with all the issues except #7 - The hose going from the jetpump to the brake booster. Would that be hose #10 in the diagram below?
Old 01-31-2012, 02:38 PM
Yes, that would be the hose from the brake servo to the top of the suction jet pump. There is also a hose that runs from the top of the F connector to the suction jet pump and and another that runs from the bottom of the suction jet pump to the intake manifold behind the throttle body.
I the photo below, you can see the top two hoses as they are arranged on my 2001 530i.
Name:	Brake Servo 2.jpg
Steve
OSRAM CBI
Old 01-31-2012, 04:56 PM
Thanks for the clear annotated photo! I'll have to check both once I get home.
Old 12-09-2012, 04:57 PM
bluebee's Avatar
I had forgotten about this thread, so I just wish to update what the cause of 'my' lean misfire codes were:
- Does the order of the misfire OBDII DTCs diagnostic trouble codes actually matter (1)
After identifying & replacing all the visible hoses I could:
- How to locate all problematic (between 1/8" & 9/32" ID) 3.5x1.8mm, 3.3x1.8mm & (between 17/64" & 9/32" ID) 7mm ID vacuum tubing (single material), vacuum hoses (multiple material), 3.3mm OD curved vacuum pipes (rigid tubes), 3.5mm & 7mm ID vacuum endcaps (closed end) & 7x3mm manifold o-rings (1) & 7.52X3.52mm and 9.2X2.8mm fuel injection o-rings (1) & gaskets (1) on the M54 engine & where in the USA to get new vacuum tubing & vacuum caps (1) & what SAE sizes to get for all the metric M54 engine vacuum tubes, hoses, pipes, and caps (1) & correcting the F-connector errors in the realoem diagrams (1) & finding the ends of hard-to-locate vacuum tubes (1) & sorely needed clarification on how the M54 CCV vacuum port works on the M52 CCV valve connection to the fuel pressure regulator connection (1) & how to make, borrow, or buy lean-condition misfire test tools to test for vacuum leaks & lean conditions (1) (2)
I STILL had multiple lean misfire codes, so I checked the fuel system:
- How does the E39 fuel injection work (1) & what are the most often recommended fuel pump & fuel filter brands (1) (2) & a DIY for replacing the fuel filter (0) (1) (2) (3) (4) (5) (6) & a quick test for fuel pump operation (1) (2) and a DIY for replacing the fuel pump (1) (2) (3) (4) (5) & how to replace and service your BMW E39 fuel injectors (1) & details on replacing the 7.52X3.52mm and 9.2X2.8mm fuel injector o-rings (1) & the location of the K96 fuel pump relay (1) & where is the fuel system pressure test Schrader valve for the I6 (1) & where is the fuel pressure test point for the V8 (1) (2) (3) & where is the location of the fuel pump relay K96 (1) & cleaning (1) (2) & replacing the fuel sensor (1) & resolving blown fuses due to a stuck fuel filler door solenoid (1)
But I still had lean condition misfire codes; so I checked the DISA:
- Where to get a proper DISA valve repair kit (1) & how some jury-rig 'repair' a rattling DISA unit (1) (2) (3) & how the DISA valve operates (0) (1) (2) (3) (4) & how to test DISA operation (0) (1) (2) (3) (4) & a simple DIY to install an M54 DISA (1) & a nice DISA autopsy (1) (2) & a great DISA group buy (1) & how the disa valve o-ring fails (1) (2) & how it can reputedly cause all sorts of cold-engine rough idle problems (1) (2) & where to get just the DISA valve o-ring (1) & why you want to check the DISA at 100K miles or whenever the airbox is removed (1) (2) & why the DIfferenzierte SAuganlage ("Differential Air Intake") valve flap breaks (1), sometimes with parts sucked into the intake manifold (1) (2) (3) (4) (5) (6) (7) (8) & a well documented example of how a broken DISA flap can ruin your engine (1) & yet another seemingly complex set of misfire codes reputedly traced to a broken DISA valve (1)
But I still had lean condition misfire codes; so I had to run a smoke test:
- How to make your own smoke machine (1)
The smoke test located a badly broken CCV lower vent hose:
- How to test the crankcase ventilation (aka CCV, CVV, PCV, CPV, & OSV) pressure regulating valve system (1)
Which also enabled me to unclog the wholly clogged dipstick tube:
- How to test, clean, & redesign the original BMW dipstick guide tube to prevent CCV vent clogs (1)
A subsequent smoke test located a bad lower boot connected to the throttle:
- How to diagnose a BMW E39 engine misfire (1)
With the final result being a passed California smog certificate:
- Results of California smog emissions tests (1)
Old 02-22-2014, 10:05 PM
alex5er's Avatar
alex5er alex5er is offline
Mein Auto: e39 1997 528i
Thanks for posting all the details ... Need to pass Cali smog next month, will spend my Sunday looking for leaks...
Old 02-23-2014, 04:19 AM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530
Poolman, if you don't mind, I'd like to reference this thread in the "So You Just Bought an E60" doc in the E60 forum.
Being newer, we're not seeing as many vacuum leaks and codes yet. But as the similar components age on the M54, N52 and N54 engines, this will be great info for those seeing the beginnings of the problem in newer models.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 10+ Years
Old 02-23-2014, 06:22 AM
Feel free to use the thread anywhere it will help someone--I have started a new Thread and called it --Vacuum Leaks-- and the only thing that's mentioned is the link to this thread--One needs to type in the wording precise to find the thread that we are reading on--sometimes too hard to find it.
Just had a thought,,I'm terrible with posting pic's--sorry that's just how it is--If someone would take the list and make pictures to each of the points listed--that would help many down the road
with finding and also maintaining their engines.
Old 08-16-2014, 12:07 PM
bluebee's Avatar
I agree that we need a single canonical thread, on vacuum leaks, and this is as good as any to "declare" canonical (for one-stop shopping).
The canonical thread builds over time, incrementally, until it has EVERY cause of vacuum leaks listed.
For my part, I'll post here, relevant pictures of "my" vacuum leak saga, from this thread:
Here, my secondary air pump hose and plastic pipe both disintegrated in my hands:
Here, you see my F-connector hoses were worn:
Here, you see that my dipstick guide tube outer ring, which has a rubber line attached to it from the CCV, is completely clogged!
Here is a huge hole in the rubber boot of a bimmer explained in that canonical misfire thread:
Here is another thread where the culprit was the boot on the M54 engine:
> E46 (1999 - 2006) > I'm at the DISA
This is the endcap which was on the back of my M54 engine, the top one of two, near where the SAS meets the manifold on the driver's side:
And here's another CCV hose, broken at the problematic elbow, next to the re-designed tube:
See also:
- Poolman's canonical thread on battling vacuum leaks on the BMW I6 with lean-condition misfire DTCs (1) & where to find all the vacuum hoses, tubes, pipes, and endcaps in the E39 engine bay (1) & where are all the fuel injection o-rings (1) & how to locate all the o-rings (1) and gaskets (1) & where in the USA to get new vacuum tubing & end caps (1) & what SAE sizes to get for all the metric M54 engine vacuum tubes, hoses, pipes, and caps (1) & how do we correct the F-connector errors in the realoem diagrams (1) & where do some of those hard-to-locate vacuum hoses end (1) & what is the sorely needed clarification on how the M54 CCV vacuum port works on the M52 CCV valve connection to the fuel pressure regulator connection (1) & how to make, borrow, or buy lean-condition misfire test tools to test for vacuum leaks & lean conditions (1)
Old 08-16-2014, 12:10 PM
bluebee's Avatar
By way of completeness, this thread today shows, that, what first may appear to be a vacuum leak, is, in fact, no fuel, since the DTC really says "lean condition", you need to suspect either one of the 14:1 air:fuel ratio:
This hard-won observation points out that a lean-condition code could mean either end of the 14:1 air:fuel ratio is off kilter ...
> E39 (1997 - 2003) > How to make/borrow/buy lean-condition-misfire test tools (smoke, vacuum, & pressure)?
Originally Posted by bem-ster View Post
After years of chasing a PO171, PO174 and throwing parts on my car, rebuilds, smoke test, analyzers, blah blah blah, I finally found the infamous mysterious vacuum leak.
First thing about lean condition Codes (PO171, PO174) it's only "assumed" the lean condition is vacuum related. In my case it had nothing to do with a "vacuum leak" it had to do with a faulty fuel pump and fuel filter. Seems to me that bimmer would have thought of a way to code a fuel pump or a fuel filter, being low fuel pressure at the rail is a sign of lean condition.
My car had finally died on me and naturally I bought a code reader. Trying to get my car started, I kept getting that pesky ole PO171, PO174 code which had nothing to do with why my car didn't run. The problem was the fuel pump and filter, brief diagnostic history. I have had the lean condition for several years and was always told by the experts. "you got a lean condition" (((vacuum leak))). But what I didn't realize is that my car with 150k miles had never had a fuel pump replaced or the fuel filter. Actually if the truth were known my pump has been getting weaker and weaker for years.
The fuel filter, Unbeknownst to me had never been changed either. So my lean condition in THE END was a failing fuel pump and plugged up filter. Here's the kick in the head for me, it was something bluebee had said as I recall. Firstly, My fuel pump fuses and relays were all good. Power to the pump was there and the pump motor worked, I could hear it run, I also had spark at the plugs. After much frustration I resolved IT HAD TO BE THE PUMP, just because the pump motor runs doesn't mean the pump pumps. What I discovered was the fuel was recirculation in the tank, that plus the combination of a really plugged up filter created the LEAN CONDITION which was throwing the codes. Once I discovered there was no pressure at the fuel rail and I had spark, everything pointed to the pump and filter. Finally after replacing both pump and filter and getting the car started the PO171 and PO174 went away. So it's not always a vacuum leak that causes a lean condition, it can be low fuel pressure from a plugged filter or failing fuel pump. Anyway that's my 2 cents worth.
Old 06-05-2015, 11:01 AM
bluebee's Avatar
This was posted today...where we share inline engines:
> E46 (1999 - 2006) > DIY - Most Common Vacuum Leaks (Diagnosing P0171 & P0174)
Originally Posted by 50sKid View Post
If you've got P0171 or P0174, you've got a vacuum leak and in this video I will go over all the most common causes for these leaks on the M54 & M52 engines. 95% of you who have this problem will be covered by this video. This is a great place to start if you've got this very common problem.
Hope you find it helpful.
-Jason
EDIT: Jason covered getting OEM sensors, which is covered, in detail, here:
- What brand is the OEM original equipment manufacturer for your BMW parts (1) & what parts & supplies are best to buy OEM, OES, or OE (1)
Jason also covered getting the right DISA o-ring, which is covered here:
- Where to get just the DISA valve o-ring (1)
Jason mentioned his DISA was rebuilt, which is covered here:
Jason mentions the CCV, and all its hoses, which is covered, in detail here:
Jason covered the dipstick guide tube, to follow things through, which is covered here:
Jason covered the valve cover gasket, which is covered here:
- How to replace the I6 VCG (1) & which VCG brand to buy (1) & what VCG lubricants to use (1) & what can go wrong when replacing the VCG valve cover gasket which may cause subsequent plastic engine cover leaks (1)
Near the end, Jason covered the SAP hoses, which fell apart in my hands:
- How to maintain the secondary air system (1) (2) (3) & how to troubleshoot the SAS (1) (2) (3) (4) & how to do an SAS delete (1) & how to replace the (SAP) secondary air pump (1) & how to set the SAS secondary air monitor 2AIR obd (1)
Old 06-06-2015, 05:58 AM
Good post,,Looks like as our cars age, there is a new Vac leak occuring more frequently ,,Brake Boosters are giving up the ghost. When seeing a post about an engine sucking up water from the brake booster, we often tell the OP how to fix the problem, where the water won't enter again. But what is happening,,there is a vac leak happening and needs to be addressed. To tell if your BB is having problems, remove the panel under the dash on the drivers side of the car, crank the engine and set as close to the fire wall as possible with radio and fan off,,,If you have a leak, you should hear it
Old 06-24-2015, 11:39 PM
Codyporter408 Codyporter408 is offline
porterfilmz
Mein Auto: BMW 528i E39
1998 Bmw 528i
I have noticed that the previous owner has sulconed a Gatorade cap into my intake rubber boot. It has 2 connections, 1 small and 1 big diameter holes for Hoses. The big one is plugged with the cap, and the smaller one is ok. Does anyone know what runs into the bigger diameter sized hole on this years intake boot ? ( connects throttle body to MAF)
