E36 (1991 - 1999)
Old 01-21-2012, 03:49 PM
sskogman sskogman is offline
Mein Auto: 1999 328i
Question 328i wont start. Not Battery, Alternator or Starter
My 99 328i wont start and I know its not the starter, alternator or battery because i have had them all tested. I tried jump starting it a couple of times and this seemed to help it turnover athough this could have been a coincidence but i doubt it. It doesn't make any noises when i try to start it, but sometimes it randomly engaged. Now it doesnt engage ever at all. Could it be my clutch safety switch or something electrical?
Old 01-21-2012, 07:15 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
If it was randomly engaging and now it just doesn't, really makes me think the solenoid. I'll assume you have a 5 speed. How about pop starting? If you can't do that with they key on then we can go from there.
How does it run when it is?
You canít spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 01-21-2012, 07:36 PM
Wayne's World Wayne's World is offline
Monkey Wrencher
Mein Auto: 2005 325i Sport 5spd
Faulty ignition switch in the steering column would be my first guess.
Sent from my SGH-T679 using Bimmer
2002 Sterling Gray M5
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Also possible to simply not have a good electrical connection ie: battery terminals (or cables) are corroded, wires on back of starter corroded etc. Start tracing wires, clean 'em up, and coat with dielectric grease.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 01-21-2012, 10:01 PM
It pop starts and runs great, i just replaced the terminals and they have a good connection. Maybe it is the ignition switch
Old 01-23-2012, 12:31 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
check for power to the starter when cranking. if power, then you have a bad solenoid on the starter.
if no power, then check the clutch switch (if present) and ignition switch.
or, park facing downhill so you can pop the clutch to start it...
df
Old 01-23-2012, 12:53 PM
Ok so the mechanic said its the EWS, he bypassed the clutch and ignition switches and problem still persisted.
Old 01-23-2012, 01:27 PM
jonesin's Avatar
The Canadian Prick.
EWS is NOT either the clutch or the ignition switch, so why would he diagnose one thing then 'fix' another?
That is like the doctor saying that you have a sprained wrist, then performing a vasectomy.
Old 01-23-2012, 01:31 PM
did he check the cluch and igniton switches?? or did he call it the clutch/ignition switch?? (as in just 1 switch??)
ews also has a relay, and will kill power to the starter.
it's under the dash.
df
Old 01-23-2012, 01:37 PM
jonesin's Avatar
The Canadian Prick.
I like my analogy better
Old 01-23-2012, 01:38 PM
i could edit mine to say what you did, if you think that'll make you feel better....
df
Old 01-23-2012, 02:04 PM
I believe he said he bypassed the switches and it still did not start therefore he deduced that it was the EWS not working properly
Old 01-23-2012, 02:17 PM
i bed to differ.
if the proper switches were bypassed and it started i would say 'ok'. but bypassing a switch and then declaring a diagnosis is not an accurate test.
was there power to the switch?? if there was and it was properly bypassed, then it should start.
if not, then there is another piece in this puzzle that has not been sussed out properly.
could the problem be ews?? sure. but a proper diag is necessary.
here's a link to ews.
http://www.unofficialbmw.com/images/BMW_EWS.pdf
df
Old 01-23-2012, 02:36 PM
df...they were able to get the car started by bypassing the EWS then they ran a diagnostic and found out that the EWS was accepting power but not distributing power...i hope im explaing this sufficiently
Old 01-23-2012, 02:40 PM
gotcha.
df
Old 01-23-2012, 02:47 PM
diqiu diqiu is offline
Mein Auto: 96 BMW 318I, 95 MB C220
My car has the same problem.
Old 02-03-2013, 02:46 PM
Lendoe Lendoe is offline
Mein Auto: '03 540/6
Resolved??
Old 02-04-2013, 10:00 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
May want to make sure the camshaft position sensor or crankshaft position sensor are not faulted. I know it's way out there, but doesn't hurt to check.
Old 04-15-2013, 06:36 PM
Dustin22 Dustin22 is offline
Mein Auto: 1993 Jeep Grand Cherokee
I have a similar problem with similar circumstances, starter is good battery and connection is good, alternator is good but I dont get any response from the starter when using the ignition and was unsuccessful at pop starting. I used a wire to short the stater and got the engine to turn but was unable to get it to fire. There was a grinding noise in the front when I braked to a complete stop but not sure if its related.
Its a '97 328i 214k miles
Old 05-18-2015, 06:45 PM
adeptwi adeptwi is offline
Mein Auto: 328i
Hello Everyone,
I own a 1999 BMW 328i and it would not start today. The battery is good. My mechanic, who does not work on imports, was able to start it, but feels it is electrical, since the security system flashes when the key is in the ignition. It has been a bit temperamental lately, radio randomly cutting out, cruise not turning on, but I thought it may have been weather related, rain and such. Does anyone have experience with a similar situation?
Old 05-19-2015, 09:28 AM
hornhospital's Avatar
D'oh, You Kids!
Take a peek at the ECU. It may BE weather related if the ECU compartment is flooded. It's behind the thick rubber panel on the firewall on the passenger's side.
Quotes to live by:
Old 05-19-2015, 02:18 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Is there power to the On Board Computer? If not, that's a no crank condition.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 05-19-2015, 03:24 PM
Mein Auto: 328i
Thre radio works and all lights turn on...the security light flashes on the radio when key is in ignition.
Old 07-26-2016, 03:15 PM
ArkticE36 ArkticE36 is offline
Mein Auto: 96 BMW 328IS
So I got the same problem, I would try to start the car and randomly it did not start. All lights came on including headlights. All I heard was a click. We recently replaced the starter and still nothing. What do I check next?
clutch switch, electrical, start, starter, turnover
