Old 01-21-2012, 07:16 PM
ConspiracyCrazy ConspiracyCrazy is offline
Mein Auto: 1998 BMW540i
Please I need some help with Code P0170 and P0173
I have a 1998 BMW 540i just change all 4 Oxygen sensors,Purge Solonoid which is the Fuel Tank evap Breather Valve since I had a code for that also so I drive around and I get P0170 and P0173 2 codes I trign to get the light to come off is been driving me crazy I had it a while now so if anyone has any help let me know cause Oxygen sensors where a lot of money and the fuel valve so if I can get any help on this is my last resort
Old 01-21-2012, 07:38 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
The light won't go off by itself - your scan tool needs to clear it.
Report the short term fuel trim percent numbers. If positive at 10%+, you have a vacuum leak.
Old 01-24-2012, 03:22 PM
SO i cleaned the Mass air flow and reset codes and ran and came back with all these codes
P0300
P0301
P0303
P0305
P0306
P0320
P0173
Now I'm lost and over 600 dollars in parts I replace good thing I did the labor so if anyone has any info they can share to help me solve this my self please share thank you
Old 01-24-2012, 05:29 PM
pleiades pleiades is offline
Mein Auto: '99 5-spd
Those P0170 and P0173 codes are for six-cylinder e39s (I thought). Sometimes indicative of failed sensors (if the sensors are new).
The P030x codes are for multiple cylinder misfires.
What brand sensors did you install and when cleaning the MAF, what cleaner did you use, and did you check the air intake boot afterward for any leaks?
Old 01-24-2012, 05:54 PM
doru's Avatar
doru doru is online now
Mein Auto: 2003 530iA
Once the injectors start flowing below 90% (10% or more obstructed) you can also have "misfires" - here
Old 01-24-2012, 09:32 PM
I used Bosch Oxygen sensors and I use Mass air flow sensor cleaner from auto Zone and I found a Leaked of air when I turn off car, I can hear a air sound only when I turn off car so I check and is a house connected to a box I move it while car is off and makes a escape air sound it is located in the back but I don't know what that part is so here is the picture of what is leaking air
Old 01-24-2012, 09:34 PM
Oops Wrong Picture
Old 01-24-2012, 09:41 PM
The First Picture is for the Fuel Breather Valve that was for another post 2 to next pictures is where the air leaked is coming from the one I found I have check the Coils by starting the car and removing the clip connection and see if drop and change and yes they all drop the engine down so I just Purchase New Bosh Iridium Spark Plugs to see if that changes anything I will put them on tomorrow. I did purchase some spark plugs a year ago I do not remember if they where Iridium I have never change the Coils on this
Old 01-24-2012, 11:34 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
Originally Posted by pleiades View Post
Those P0170 and P0173 codes are for six-cylinder e39s (I thought)...
P0XXX codes are generic.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 01-25-2012, 04:20 AM
uncmozo uncmozo is offline
Mein Auto: 2002 530i 5 speed
DUDE!!!! You've got to use punctuation! Periods and commas. Reading your run-on sentences gives me a headache. And no, I ain't no English major.
1995 525i 5 speed - sold at 225,000 miles
2002 530i 5 speed - 187,000 miles
Old 01-25-2012, 10:06 AM
I believe that but Bentley's has them organized into sets by e39 engine and the M62 list doesn't include the 170 and 173. Probably not important here.
Old 01-25-2012, 10:18 AM
You didn't report your fuel trim numbers, as I requested above. P0173 is fuel trim bank 2. That means that bank 2 is either running to lean, or too rich. That's why I wanted you to measure and report STFT.
P0300, random multiple misfire, can be caused by clogged cats. How many miles on them? If more than 100k, they are suspect.
Are you sure it's P0320, and not P0302? There is no P0320 on the Bentley list for your MY.
Old 01-26-2012, 12:05 AM
Yes it is P0320
Well I just Installed New Iridium Bosh Plugs and the old plugs look bad,they where bosh platinum Fusion 4 Prongs. I reset the computer and going to drive and see today the codes I get after new spark plugs. Also I don't not know how to test the pressure on the air yet.My cats are about a year or 2 but there not original, so they might need replace since I had the misfire for a while now, I guess I will drive and see what codes come back, There is a air escaping sound when I turn off car is that normal is like SSSSSS ,sounds like is coming from inside the manifold. Also the hose on the back when I turn off car and move hose makes a fizzing sound of escaping air is the hose on the second picture I don't know what is called so I can even get a new one lol
Old 01-26-2012, 12:51 AM
Well I just Found the Diagram For the Intake manifold system for a 540i here it is http://www.realoem.com/bmw/showparts...81&hg=11&fg=40
Old 01-27-2012, 05:46 AM
OK I put in New Spark Plugs and reset chk engine and ran till chk light came back with 5 codes P0170 and P0173 and P0300 P0305 and P0307 only five Well next I'm planing on doing a Intake Manifold over haul with and valley Pan, I notice a leaked of Coolant down there hopefully that will take care of the check engine, this is costing a lot now, good thing I have been doing the work myself
Old 01-27-2012, 05:50 AM
And thanks to bimmerfest
Old 04-24-2012, 01:05 PM
stevenhussey stevenhussey is offline
Mein Auto: 97 540i B/B
Hey did your intake manifold and valley pan overhaul work? I keep getting the p0170, p0173 codes myself.
Old 12-18-2016, 08:25 PM
yasky yasky is offline
Mein Auto: 1998 328i Sedan
Results?
Geez, how are we to learn when the OP doesn't ever say what the fix was. No conclusions, leave us hanging why don't ya? ... Please post whether or not you fixed the problem and how...
