Old 10-08-2012, 08:49 AM
naseeb naseeb is offline
Mein Auto: E39
'01 E39 Auto Transmission "Jerky" downshift
Just had the transmission serviced. However, it continues to have "Jerky" downshift while slowing down. Has anyone encountered this situation, and any ideas on how this might be fixed.
Thanks!
Old 10-08-2012, 09:49 AM
e39540iv8 e39540iv8 is offline
Mein Auto: 2000 BMW 540iA
Transmission mounts or motor mounts, check them if you haven't already.
Old 10-09-2012, 09:53 AM
BadBrad BadBrad is offline
BadBrad
Mein Auto: 2003 540iA M-Sport
Very common problem for our cars. One simple solution is to run your car with the gear shift in "Sport" mode. This forces the transmission to downshift a little earlier (higher RPM) when coming to a stop avoiding that jerkiness when downshifting to 1st. Another option is to have the dealer raise the idle speed about 100 rpm. Many forum members have had success with that method also.
The underlining problem is that the transmission control valve assemble contains a lot of small o-rings, solenoid valves and hydraulic ports that accumulate wear deposits (In spite of the filter) that hinder the smooth operation when like new. This coupled with the relatively low idle RPM causes the abrupt shifting when coming to a stop. Nothing short of rebuilding the valve assembly will totally cure the situation.
BTW, in Europe, ZF Transmissions offers this rebuild service for about $500 as they consider it part of the required maintenance. They recommend that it be done every 60-70,000 miles. By all accounts it is well worth it.
Old 10-09-2012, 10:41 AM
4given 4given is offline
Mein Auto: 1999 BMW 540i auto
I had the same problem and it helped when I unplugged the battery for about 10 mins and drove it in sport mode for 2 weeks. Sounds weird but its been a couple of months and it hasn't done it yet.
Old 10-09-2012, 11:51 AM
champaign777's Avatar
bingo
this is because you cleaned transmission settings
The new here is you said you drove it in a sport mode for 2 weeks
2 weeks is the time when a new setting applied
REALLY INTERESTING
I NEED TO TRY SIR
Old 10-09-2012, 06:58 PM
josemedeiros007 josemedeiros007 is offline
Mein Auto: 1998 528i 4Dr
Can I ask by what you mean to having your transmission serviced? Did you replace the Transmission Filter and use a Synthetic Transmission Fluid?
auto transmisions, downshifting
