Old 01-25-2012, 06:40 AM
crewdog843's Avatar
crewdog843 crewdog843 is offline
Mein Auto: '08 Z4 3.0si Roadie
Z4 (08) Grille removal
I've looked at the write up on how to remove the front grilles on the Z4...but mine seem to be intransigent....how the heck do you get these things out without destroying them. I want to paint the vertical slats so that they don't appear so 'toothy'....
Any ideas gratefully welcomed....
jake
Old 01-25-2012, 07:10 AM
Mikey48 Mikey48 is offline
Mein Auto: BMW Z4 3.0
Check out the FAQs and How- tos section. Tells you how step by step.
Old 01-25-2012, 09:14 AM
GA Z4 GA Z4 is offline
Mein Auto: 2004 Z4
I just popped mine out and installed my new black ones last night. The first time I took them out a few months ago for something else I had to use a small screwdriver and carefully pry them loose. The tabs that hold them in are quite small so you don't have to move them much to free them up. like he said check out the how tos section but it should be pretty easy.
Old 01-25-2012, 11:35 AM
barryb97 barryb97 is offline
Mein Auto: 06 M Coupe, 01 X5 4.4i
Lift up as you pull the bottom out.
CDV delete, clutch stop, strut bar, stainless brake lines, radiator hole cover, brake duct stop removal, Gunmetal M3 reps, RAD wheel locks, M strut caps, roundel under hood, Intravee II ipod adapter, Homelink garage opener, air bag sticker delete, first aid storage under seats, Bumper plugs keyhole cover, painted reflectors, Headlight washer disable, Mstache front lip, Autosolutions SSK,…
Old 01-26-2012, 03:35 AM
crewdog843's Avatar
I saw the tech write up and tried it, but not with too much success. Maybe I am not using enough force, or maybe I am just getting weaker.
Thanks,
jake
Old 01-27-2012, 03:51 AM
STIHLBOLTS STIHLBOLTS is offline
Hat's On, Tops Down!
Mein Auto: 2008 Z4MR
Firm upward pull and the bottom comes out first.
Happy Motoring
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 01-28-2012, 05:33 AM
crewdog843's Avatar
Still no joy. Maybe I need a good pair of leather gloves....I'll get it one of these days...but if not, I'm sure my local mechanic will be more than happy to take 'em out for me. I just want to paint the slats...
Love this car.
jake
Old 01-28-2012, 10:12 AM
OK
1. Find the middle of the grill, grip the bottom of the strakes and firmly pull upward.
2. While pulling firmly upward gently pull towards you.
3. It's now out.
Install
1. Put top in place first
2. Pust firmly on the bottom and slide in.
3. Make sure you hear "Snap" as the 4 clips engage.
Your done.
Can't make it any simpler. If they have never been out I am sure they will be a little tougher to get out but they should come out just with hand pressure. Maybe I need to post a video. LOL
Happy Motoring.
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 01-28-2012, 06:39 PM
crewdog843's Avatar
Hahahaha, no need for a video. I will give it another shot on Monday ('cause as a workin' man, I have little time to do much else except work, eat, and sleep).
I want to make the front end look like yours, but with a Bright Red car, I want to retain the chrome, but blacken out the slats. If I don't like the chrome ring, I can do something with it later.
Again, thanks.
jake
Old 01-28-2012, 10:07 PM
chickdr chickdr is offline
Mein Auto: '06 M Roadster Imola/Blk
Again, thanks.
jake
Do you want to buy my old stock grills cheap? The OEM Z4M grills sound like exactly what you want:
Old 01-29-2012, 05:42 AM
I was going to suggest the same thing Doc. Find someone's old M Kiddneys instead of doing all the painting that won't stick anyway. Or buy a set. Several places that have them. Stealth Auto, Roastersolutions, others.
Happy Motoring.
I have mine, but they are not for sale. In case I ever want to put the car back stock.
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 01-29-2012, 07:39 AM
He could also buy the full blackout grills as you and I have done and then move the chrome ring from his OEM grills to the new grills. The ring is separate from the grills.
Old 02-01-2012, 09:48 PM
crewdog843's Avatar
Will the fit the '08 and if so, how much do you want for them?
jake
Old 02-01-2012, 10:23 PM
jake
Yes- the grills are the same from 06-08. I would take $35 shipped for my OEM's. I have the box my blackout grills came in to ship them in. Shoot me a PM if you want them.
Old 02-10-2012, 07:05 PM
rguess rguess is offline
Mein Auto: 2007 Z4 30si Coupe
Grills
I'll take your grills if he doesn't want them.
richguess61@aol.com
