E36 (1991 - 1999)
Old 01-25-2012, 12:03 PM
Megatron666 Megatron666 is offline
Mein Auto: 1996 BMW 318i
BMW 318i overheating
Hello guys, I purchased a BMW 318i and drove it home. Didn't notice a problem at the time. I parked it at home and let it run and noticed it started to overheat. I turned the car off later came back and drove it around the block for awhile. The temp gauge stayed in the middle but when I pulled back into my drive way and sat ideling it began to creep towards the red. I then noticed my fan was not coming on. I turned the AC on to check the fan and nothing. I've pulled the fan out connect jumper cables to my battery and touched the speed pins and fan never moved. Is that the problem? Please please help
Old 01-26-2012, 05:38 AM
Time2Fly's Avatar
Time2Fly Time2Fly is offline
Sometimes Out To Lunch!!!
Mein Auto: 1993 318i 1994 325i 1998
Ya Think? If you can't figure that out then sell your BMW before you destroy it. I'm sorry to sound like an ass but, I'm just say-in......Think about your questions before you ask dude some of us can be brutal on noobs like you when you ask questions like that....
Old 01-26-2012, 09:31 AM
hornhospital's Avatar
D'oh, You Kids!
If your car hasn't been altered from original you have TWO fans. One electric in front of the radiator, and one belt-driven through a viscous clutch mounted on the water pump. What you're describing sounds like you have no belt driven fan, the absence of which is sometimes called a "FDM", or fan delete mod. When you drive, enough air passes through the radiator to cool the engine. When you stop and let the car idle, the belt-driven fan is supposed to pull air through the radiator to cool it when there is no airflow from the car moving forward. The electric fan in front of the radiator is there as an auxiliary air mover to push cooling air through, primarily when using the air conditioner. It's function is also to add cooling air when the car is stopped and the ambient air temperature is too high for the clutched fan to cool the engine by itself. It appears your electric fan is DOA, BUT the engine's belt driven fan should have sufficient cooling to keep the engine from overheating almost all the time.
#1: verify you have or do not have a fan behind the radiator. If you don't, get one, along with the clutch, because it is your PRIMARY air mover.
#2: IF you have the belt-driven fan, the clutch has failed. Replace it.
#3: read the stickies (permanent at-the-top-of-the-forum threads) particularly those concerning cooling system maintenance. The ENTIRE cooling system needs to be replaced every 70,000 miles or so. If yours hasn't been replaced in that time period, or you don't know when it was last replaced, do it. Don't argue that it "looks fine", just do it. BMWs do not tolerate overheating, period.
#4 Welcome to the fest!
Quotes to live by:
