Operation .5 liters per cylinder. - Page 2 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 01-27-2012, 10:03 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
I gotta say it won't work Chip.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 01-27-2012, 10:06 AM
miles_trail's Avatar
miles_trail miles_trail is offline
I like pie.
Mein Auto: 01 325xit
I didn't see anything in there about M50TUB25 heads, maybe I should have been clearer, as of now I'm only replacing the rotating assembly.
Originally Posted by E36 Phantom View Post
How do you outcrazy a dude that lifts his engines without a hoist?
Old 01-27-2012, 10:09 AM
I like pie.
Dang it, the S54 cams are so much cheaper than any of the S50 cams I've seen, and I don't have to wait around to find a set .
Old 01-27-2012, 11:55 AM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
S50 cams are often $250-300 on Bimmerforums. Just be patient and keep an eye on the classifieds.
As far as the impact, you'll have to get a very good strong one. My impact wasn't able to get the crank bolt off my S52 block. It's not that strong of one, but it is rated for 300+ ft lbs (it probably doesn't do that much). Btw, what are you using to hold the crankshaft in place?
-CJ
Old 01-27-2012, 12:10 PM
cmybimmer's Avatar
cmybimmer cmybimmer is offline
IM DA BES
Mein Auto: A rental
good stuff man.. subscribed
-Usama
"The American Dream only makes sense if you're sleeping" - Lowkey
Old 01-27-2012, 12:55 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
From what i read Chip, is that you can use m54 cams
think you have to grind/cut one of them (exhaust?) so it fits into the M50TU head
-Dino
Old 01-27-2012, 02:15 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
yeah, i seem to think that i saw this on here as well. can't remember where, though. maybe in one of the links on hakkenTT's thread??
i also did some research on the m50/s50 and the head is the same part number, so i would assume that the cams would have the same journal specs and fit, just stick out farther on the exaust side where the vc & timing cover won't match up.
if the timing chain will line up, just grind down the rest of the camshaft nub to fit.
seems to make sense to me...
df
Old 01-27-2012, 02:27 PM
I like pie.
I jammed a pair of tongs and a rail road spring clip that I forged out flat through the flex plate and then tied them to the block with a peice of 1" tubular nylon webbing rated at 21KN, so far it's held.
I guess I might try to find some M54B30 cams since they're probably the cheapest option.
Sent from my FroyoEris using Bimmer
Old 01-27-2012, 02:32 PM
cj.surr's Avatar
some kid
Damn, that's a little more complex than just sticking a branch in there.
-CJ
Old 01-27-2012, 07:50 PM
I like pie.
And I finally got that damn bolt out, had to go to Sears and get a Craftsman breaker bar, tried hitting it with a 4 lbs sledge, didn't work so I put it back on the porch and built the 2X4 frame back, then I put the 10' pipe on the breaker bar and jerked it a couple times and it came loose.
Old 01-27-2012, 07:52 PM
cj.surr's Avatar
some kid
Damn, that thing must have been on there really freakin tightly.
-CJ
Old 01-27-2012, 07:59 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Chip, you can take the busted bar back to HF and get another one (or maybe your money back?). I recognize the design of it...got one just like it.
A note about removing stuck fasteners: The way you finally got that bolt out is the right way to loosen almost any stuck fastener. As long as the wrench fits tightly, a quick snap with as much force as you can muster works a lot better than an extended pull.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 01-27-2012, 08:37 PM
I like pie.
Yeah, I'll take it back to Lowe's in the morning, just like I did with the last one I broke.... on tuesday..... .
Old 01-27-2012, 08:42 PM
jonesin's Avatar
The Canadian Prick.
I truly don't miss the days of working on farm equipment needing 3/4" or 1" drive tools. That needed a lot of four letter words.
Old 01-27-2012, 09:35 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
The first time I took the wheels off my e36, I needed a 3/4" impact to get a few of the lugs off. That's normal, right?
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 01-28-2012, 03:50 AM
'ouch'
'oops'
'uh-oh!'
'nooo!'
'help!'
yep, thems all four letter words alright...
df
Old 01-28-2012, 09:36 AM
e39munoz e39munoz is offline
Mein Auto: 2003 BMW e39
Subscribed I'm very interested on your results best of luck
Old 01-28-2012, 10:14 AM
I like pie.
Tonight I'll have the M54 completely disassembled, now the only thing holding me back is my inability to get my truck started .
Old 01-28-2012, 11:54 AM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: big turbo hellrot sedan
good luck with the truck.
And yes we took a branch and jammed it on the crank LOOL
came right off with 2 people holding the block and 3 people pulling the bar in top of the craftsman half inch ratchet.
Turbo lag is just a headstart because the chase is more exciting than the win - Abraham Lincoln
Old 01-28-2012, 07:41 PM
I like pie.
Alright, every thing is apart, bagged, tagged and drenched in WD-40 waiting to go in the M50.
Pics:
Who knew that an M44 head lines up perfectly with the first four cylinders of an M54
Old 01-28-2012, 07:43 PM
cj.surr's Avatar
some kid
Nice. Do you think you could measure the diameter of the rod journals for me? I can't seem to find the specs for the crank online.
-CJ
Old 01-28-2012, 07:54 PM
I like pie.
Yeah man, just as soon as I get a micrometer .
Old 01-28-2012, 08:02 PM
cj.surr's Avatar
some kid
Cool, thanks.
-CJ
Old 01-28-2012, 09:27 PM
D'oh, You Kids!
Chip, are you shopping for mics? I would suggest pawn shops for used. There are tons of them out there these days. The machinist trade took a huge hit when the economy went sour (ask how I know). Stick with Brown and Sharpe, Starrett or Mitutoyo for used ones. The ones Harbor Freight sells are OK, too, believe it or not. I have two sets of those, one set of Starretts and one set of Mitutoyos. The HF Chinese-made ones hold accuracy just as good as the higher priced name-brand ones (didn't use to be that way).
Quotes to live by:
BMW-CCA #441426
Old 01-28-2012, 09:48 PM
cj.surr's Avatar
some kid
I just got one at HF on sale for $15. It was not the lowest quality one they had, and it seems to be pretty good so far, but how would I know?
-CJ
