E36 (1991 - 1999)
Old 10-21-2012, 06:13 PM
miles_trail's Avatar
miles_trail miles_trail is offline
I like pie.
Mein Auto: 96 318ti, 93 BMW 325IS
Originally Posted by ZeGerman View Post
Excellent! We need a photo of you standing in the engine bay, though.
I know but the POS eBay battery for my real camera isn't charging so I'm left with my phone and my roommate is always to busy being stoned off his ass and talking about starting a project with his ix to come take a pic for me .
Originally Posted by E36 Phantom View Post
How do you outcrazy a dude that lifts his engines without a hoist?
Old 10-21-2012, 06:16 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Nice job Chip! That engine lift is ghetto as fcuk! What did you strap it to and how are you gonna get the engine down?
-CJ
Old 10-21-2012, 06:23 PM
I like pie.
I made a frame out of 4x4s and put a pulley that used to run on a track in the top of the barn on it and hooked the ratchet strap to that so I could pull it out of the engine bay. You can actually loosen the ratchet a few teeth at a time, takes a while, but it worked.
Old 10-21-2012, 06:25 PM
cj.surr's Avatar
some kid
Ah, now I see the pics quite a few posts back. Cool stuff.
-CJ
Old 10-21-2012, 06:51 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Originally Posted by miles_trail View Post
And there we go:
Sorry for the pic quality, all I have is my phone, and lighting isn't great .
That ratchet strap is bit light duty for my liking. If it's one of these it's only rated at 800 lbs working load......
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 10-21-2012, 07:16 PM
I like pie.
It's one of the heavier ones Lowe's offers, safe (for the strap) working load of 1000 lbs, breaking strength of 3000 lbs, and I made damn sure to keep my toes out from under it.
Old 10-21-2012, 07:24 PM
dc_wright's Avatar
Good deal! Still, keep clear just in case!
Don't want to end up like I did where the copays totaled more than it would have to hire someone to do the job.
Old 01-16-2013, 12:53 PM
I like pie.
..... So guys...... I think I did a very bad thing......
Thoughts?, is this weldable or do I need a new block?.
Sent from my ADR6300 using Bimmer App
Old 01-16-2013, 12:58 PM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
zoomed out picture for area reference?
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 01-16-2013, 01:05 PM
I like pie.
Bottom right of the back of the block, one of the biggest bolts that holds the transmission on.
I was bracing a piece of metal against it to hold the crank so I could together the bolt holding the main fully off, and then this happened.
Old 01-16-2013, 01:15 PM
cj.surr's Avatar
some kid
I would just run it without that bolt. Or try to get it in somehow. The transmission has like 6 or 7 other bolts. It's not going anywhere. Unless someone else can think of some reason that this bolt is essential...
-CJ
Old 01-16-2013, 01:22 PM
I like pie.
That'd be a relief.
Any suggestions for getting that front bolt off?. The M54 block had a shallow hole in the back where you could put a bolt to hold the back of the crank, but I didn't see any thing like that on the M50.
Old 01-16-2013, 01:26 PM
cj.surr's Avatar
some kid
Use bolts on the flywheel with a rod in between. And a breaker bar on the front.
-CJ
Old 01-16-2013, 02:04 PM
dc_wright's Avatar
This^. Mechanical design margin is typically 50% minimum, but more typically 100%-150% when it doesn't affect weight. Running 5 vs 6 bolts reduces your margin by 17% assuming they're all equally loaded.
When you get boosted up to 500 RWHP, that's when to start worrying, but even then you've consumed all the design margin even with all the bolts there so what the hey! One extra bolt won't make a difference then anyway....
All that aside a good shop should be able to weld in the area and redrill and tap the hole if you wanted to but fully bolted up. Cast iron is difficult but not impossible to weld for someone that knows what they're doing.
Old 01-16-2013, 02:19 PM
cj.surr's Avatar
some kid
I doubt that it would be worth it for an M50 block. I've had this on craigslist for several weeks...
http://newhaven.craigslist.org/pts/3506302054.html
-CJ
Old 01-16-2013, 03:06 PM
dc_wright's Avatar
Cool! What do you think the shipping cost to VA might be?
Old 01-16-2013, 04:18 PM
hornhospital's Avatar
D'oh, You Kids!
I was hoping it would fit in a USPS Flat Rate Priority Mail box.......
Quotes to live by:
Old 01-16-2013, 04:47 PM
dc_wright's Avatar
Maybe if someone sits on the top while it's taped closed?
Old 01-16-2013, 04:49 PM
I like pie.
Lol, I once talked to a blacksmith who made swatch blocks and after the USPS introduced the flat rate box he cut an inch off them so they'd fit, said he took a stack of them to the post office and offered to carry them to the back for the lady, but she was armament that it was against the rules... Until she tried picking one up
Old 01-16-2013, 06:25 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
what's a swatch block??
df
Old 01-16-2013, 08:01 PM
I like pie.
It's a type of anvil that just has a bunch of different sized and shaped depressions and notches in it.
Old 01-16-2013, 08:09 PM
I like pie.
Having trouble finding a picture so that could be weird name for it, or I could just be an idiot and forgot the real name
Old 01-16-2013, 09:15 PM
D'oh, You Kids!
Swage block
http://en.m.wikipedia.org/wiki/Swage_block
Quotes to live by:
Old 01-17-2013, 06:09 AM
I like pie.
Or maybe I just can't spell. Thanks Ken :thumb:,
Old 01-17-2013, 09:01 AM
D'oh, You Kids!
If I hadn't had a machinist/blacksmithing background I wouldn't have known how it was spelled, either. (Yes, I've got a forge and anvil and all that crap....)
Quotes to live by:
