E36 (1991 - 1999)
Old 03-05-2013, 12:03 PM
Shigeta's Avatar
Shigeta Shigeta is online now
Old Soul
Mein Auto: '96 328is
Old 03-05-2013, 12:15 PM
cj.surr's Avatar
cj.surr cj.surr is online now
some kid
Mein Auto: 1995 318is
Originally Posted by miles_trail View Post
........ Ken..... you ass hole......
I just realized that all the pictures I took too help remember where stuff goes was on my old phone, which is on the side of a road in E bumblefuk-nowhere'sburg West Virginia.
Sent from my DROID2 GLOBAL using Bimmer App
We know where everything goes. Just post up a picture if you get confused
Sent from my SCH-I405 using Bimmer App
-CJ
Old 03-05-2013, 01:43 PM
miles_trail's Avatar
miles_trail miles_trail is offline
I like pie.
Mein Auto: 1993 BMW 325IS
So I should have read through the bently manual more thoroughly because I don't have an E8 torx socket.
Guess I'll just spend the rest of the evening cleaning 20 years of grime off of my vanos unit.
Originally Posted by E36 Phantom View Post
How do you outcrazy a dude that lifts his engines without a hoist?
Buy stuff!
E36 parts: http://harrisonburg.craigslist.org/pts/3696167489.html
E36 5 speed swap: http://harrisonburg.craigslist.org/pts/3696120610.html
E46 parts: http://harrisonburg.craigslist.org/pts/3696151076.html
Old 03-05-2013, 01:45 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
You should get the lisle torx socket set. Like $15 and it has every E torx bit you will ever need for BMWs.
I have this.
But it looks like there's a better one.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by SCJon View Post
Jared is king of ambiguous comments.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 03-06-2013, 11:00 AM
I like pie.
So today I've been snowed in so I couldn't acquire the E8 torx socket, but I was bored so I decided too mess around with camshafts
In his oh so detailed write up, Hakentt gave the incredibly helpful information that if you decided to use an M54B30 intake cam you would "need to grind it a bit" I wanted too compare cams to see what the offending extension was, but as I don't own the removal tool had been planning to wait until the head was off so I could secure the valves open and safely remove the cam, but then I thought "well, the resale values of an M50 cam with 1/4 of a million miles on it is probably pretty low" and decided to try loosening it slowly. By loosening the 14 nuts 1/4 turn at a time I was able to remove the cam without cracking it.
Turns out the Vanos gear is 7 or 8 mm longer, but it's not actually milled out of the cam casting, it's threaded in and can probably be removed with a giant F-in torx bit.
Pictures:
top M50TUB25 intake cam, bottom M54B30 intake cam
Difference in Vanos gear.
ID:	365073   Click image for larger version
Buy stuff!
Old 03-07-2013, 09:35 AM
I like pie.
Does any one know how/ if these gears can be removed?, I like the idea of swapping them a lot more than grinding but I don't even know if they're normal or reverse threaded.
Buy stuff!
Old 03-07-2013, 09:36 AM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: 1996 328i
are those M54 cams? if so I'm pretty sure that those are integrated with the cam.
insert witty signature quote
Old 03-07-2013, 09:47 AM
I like pie.
Left is M50, right is M54. I just thought maybe they weren't because I couldn't imagine why they would have the Allen/ torx heads if they weren't a separate piece
Buy stuff!
Old 03-07-2013, 09:49 AM
Kdoherty's Avatar
maybe they can be... i know my Schricks don't have any gears on them and they're for the m/s52
Old 03-07-2013, 09:51 AM
I like pie.
How is the vanos supposed too work without that gear? that's does the intake cam have any threading in the front end?.
Buy stuff!
Old 03-07-2013, 09:55 AM
Kdoherty's Avatar
i think on the 52 series engines the gears on both cams are removable. i know the M52TU cams are different and have some sort of helical gear.
Old 03-07-2013, 09:58 AM
Kdoherty's Avatar
Just snapped this 45 seconds ago, no gears.
wow that lighting is terrible. just for clarity there's threaded holes on both to mount the timing gears and VANOS gear.
Old 03-07-2013, 10:08 AM
I like pie.
Cool, that seams to me at least too indicate that my cam gears come off, after all, why would they go to a removable gear for the M52 engines and not do the same on M54s?.
Buy stuff!
Old 03-07-2013, 01:55 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
Originally Posted by hornhospital View Post
That looks like a publicity still for Amish Mafia.
clop clop clop clop *BANG* *BANG* *BANG* clop clop clop clop....
amish drive by shooting....
so post up pics with that vanos cam gear threads and let us know!!
btw, pm sent...
df
Old 03-07-2013, 03:15 PM
I like pie.
So I was productive today, also quite glad I'm not married.
Buy stuff!
Old 03-07-2013, 03:52 PM
I like pie.
I was way too excited to not try putting the new crank in.
Buy stuff!
Old 03-07-2013, 03:57 PM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is online now
still learnin'
Mein Auto: 1998 328i Hellrot Red
Good progress!!
How were the cookies?
Patrick ///98 328i hellrot///BMWCCA#465139
Old 03-07-2013, 04:04 PM
petriej's Avatar
"get that engine out of my kitchen"
"ok fine it's going in the bathtub, then"
GGC BMW CCA #443004
Join the BMW CCA!
Old 03-07-2013, 04:07 PM
I like pie.
Originally Posted by TheFinanceGuy View Post
Good progress!!
Buy stuff!
Old 03-07-2013, 04:32 PM
cj.surr's Avatar
some kid
I like where this thread is going
-CJ
Old 03-07-2013, 04:51 PM
CoolStanceBro CoolStanceBro is offline
I6 feels good
Mein Auto: POS
Originally Posted by Kdoherty View Post
maybe they can be... i know Brad's Schricks don't have any gears on them and they're for the m/s52
Fixed
Old 03-11-2013, 08:55 AM
I like pie.
I'll just leave this here:
http://imgur.com/a/j1ftm
Warning, not resized DSLRish content.
Buy stuff!
Kdoherty's Avatar
http://trailspice.imgur.com/all/
they're not public....
Old 03-11-2013, 09:00 AM
I like pie.
Better now?.
Buy stuff!
Old 03-11-2013, 09:01 AM
cj.surr's Avatar
some kid
Still broken.
-CJ
