E46 (1999 - 2006)
Old 01-26-2012, 02:01 PM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & JB4+ 335i
E46 BMW Ignition switch DIY
Symptoms of a bad ignition switch.
1. Turning the key and holding it on the on position without the car starting for a few seconds. ( the car will make no sound of any sort, until it starts ).
2. Sunroof will work on and off.
3. Headlights, fog lights and turn signals will not work. You also might get a rear tail light out warning lights on the dash sometimes and they go off when you flick the switch for fog lights on and off. This is also a problem with your ignition switch.
4. Side view mirrors won't work.
Finally if you have all of those symptoms it's definitely your ignition switch.
Tools needed:
Flat head screw driver
Philips head screw driver
Micro flat head screw driver ( you will need this to remove the actual ignition switch ).
Steps:.
1. Remove floor panel under the steering wheel that also goes around your peddles. There are two clips under the steering wheel itself you remove with a flat head screw driver. Then a plastic clip on the right side of the floor area and two screws across from that. You can't miss them.
2. Once you've removed this piece you'll have to remove the lower part of the steering column. There are two plastic round clips on the bottom. Press the two plastic clips in the center with the micro flathead screw driver and the column should pop right off.
3. Now you'll see a wire harness. Unplug the wire harness. There is a clip on the side you will want to pull towards the headlight switch direction. You can use a flat head screw driver for this.
4. Now look under where the ignition switch is. You'll see two micro screws w/ flathead ends mine were painted red but I've seen others were not so who knows. You want to unscrew this not completely but just lose enough to pull the ignition switch off. Plug the new ignition switch in and repeat steps backwards for re-install.
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
Old 01-26-2012, 03:46 PM
John@SAtlBMW John@SAtlBMW is offline
BMW Parts Guy
Mein Auto: e39/e38/austin healey/jag
parts list
here's the e46 ignition switch PN# 61326901961
also the grub screws are in the diagram should you loose one... (don't take them all the way out!)
http://parts.bmwofsouthatlanta.com/p...326901961.html
Old 01-26-2012, 05:26 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Allow me to say great job ob the DIY. And what a weird batch of symptoms......?
Old 01-26-2012, 05:31 PM
TheMalibuMafia
Thanks man. Lol yeah the symptoms are awesome. I will post that crappy video soon when I'm home.
TheMalibuMafia.com
Old 01-26-2012, 10:55 PM
TheMalibuMafia
Video is up.
TheMalibuMafia.com
Old 03-05-2012, 08:55 PM
LOUDLIQUID LOUDLIQUID is offline
Mein Auto: 03' BMW 330i
That was perfect well done. Great job but I tried that switch is good. Thanks tho
Old 03-06-2012, 08:40 AM
GCoop's Avatar
GCoop GCoop is offline
Mein Auto: 2004 325xi
Thanks for the Video!
Old 05-12-2013, 05:41 PM
martin3197 martin3197 is offline
Mein Auto: BMW 330I 2001
Hey. I have a 330i 2001 and my car wont start. I turn the key and get nothing , no crank. So i pulled everything apart and ive noticed that when ever the green cable in my ignition switch has a current its when the car starts. Sometimes i turn the key really quick and it starts also. Anyway do you think it could the ignition switch or key ignition cylinder?
Old 06-26-2013, 08:21 AM
mazinxd mazinxd is offline
Mein Auto: 2004 E46 330Ci
I have a 2004 330Ci and yesterday I couldn't get mine started at all. I turned it on just like usual, drove it for abut 5-10mins, then I stopped and had to wait for about 5-10 so I turned the ignition off and listened to some music on the radio. Then when I tried to then it on at the first try It sort of cranked but just a little and died. Then i get nothing when I try to turn it on, just this sound that sort of sounds like...a button or something...a small click when turn it the key back to ON. I get nothing at all when I trying to ignite. At first I tought that it was the battery since I've been having battery problems but all the lights and radio and everything seem to work. Please help. thanx a lot
2004 330Ci
w/ Premium Package and :Alpina Rims:
Old 06-26-2013, 04:29 PM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
Sometimes if you hold the key in the start position for like 90 seconds it will eventually start. If this does work then it's your key cylinder for sure.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 06-26-2013, 04:49 PM
hmm...I'll try it. I just hope its nothing expensive, not the time for any expensive repairs.
2004 330Ci
Old 06-26-2013, 11:46 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
Post again when it's time.
We like best to suggest the expensive solutions.
Old 07-01-2013, 11:31 PM
Re: E46 BMW Ignition switch DIY
k so I just got it fixed now, it was the starter. Cost $370 for the part and labor together....
2004 330Ci
Old 08-17-2013, 03:58 PM
computerwhiz1 computerwhiz1 is offline
Mein Auto: 2000 323i
Just did this to my own car. Took me about 15-20 minutes. Was not hard at all. Hopefully this will fix a no start issue that I have been intermittently having and chasing around over the past few months.
Old 08-18-2013, 12:28 PM
So you just replaced the starter in under 20 minutes?
I want you for my pit crew at Indianapolis.
Old 08-18-2013, 12:47 PM
Sorry for the misunderstanding, I replaced the ignition switch in under 20 minutes. When I did the starter it took me all afternoon.
Old 10-01-2013, 10:19 PM
Gaza77 Gaza77 is offline
Mein Auto: Burbank, CA
Is their a way to test the ignition switch with a voltmeter or some other test strategy?
Cheers,
William
Old 10-01-2013, 10:42 PM
Cheers,
William
I never got around to actually testing it, but according to the wiring diagram inside the Bentley manual I think it was pin 8 that was related to triggering the starting circuit. I would try and locate a wiring diagram for the starting circuit and ignition switch and see if you can't figure out whats what. Then use a multimeter to test for continuity between whatever pins are relevant.
Old 10-02-2013, 08:20 PM
Okay I'll try the multimeter and let you know if I have any luck. I already went ahead and ordered an ignition switch from www.oembimmerparts.com. I get 98% of my parts from there.
Cheers,
William
Old 10-02-2013, 08:43 PM
Cheers,
William
Thats a very good place to buy parts. Honestly you're going to have to pull the ignition switch out to check it so I would go ahead and replace it with the new one. Test the old one just to see if you can find anything for the sake of science.
Old 10-14-2013, 10:54 PM
retronoodle retronoodle is offline
Mein Auto: 2003 325i
That IS a strange set of symptoms. Is that from personal experience or is that documented somewhere? I have #1 and #3 - the part where you get the tail light out notification that goes away.
Old 05-12-2014, 07:03 PM
marlin1881 marlin1881 is offline
Mein Auto: 2003 330i ZHP
Once you've done this, it really is a fast DIY project. I took my switch out and took it apart. Yes, there was one contact that was dirty, so I filed all of them for a fresh surface. After putting the switch back together, I put it "gently" in my bench vise and tested each of the 6 circuits for continuity. They tested perfectly, and the closed circuits went to 0 ohms. You can also use a large flathead screwdriver to test all switch positions and continuity changes in the 6 circuits. Just like using the ignition key...
I wished this would have fixed my starter problem, but no luck. I do trust the switch now, so I'm good to go after I replace the starter. My order is placed with Max at oembimmerparts.com, and I should have it here in a couple of days. Updates to follow...
Thanks to MalibuMafiaV for the detailed post and video.
Old 05-12-2014, 09:05 PM
Glad you figured out your problem, but sorry to hear it was the starter. I'm not sure which method you are planning on replacing the starter. I have never done it myself, but I know a lot of people do it from the bottom. However, I feel like it might be easier to pull the air box, intake hoses, and throttle body out and that might allow you to get it out . If nothing else, I think that would give you much easier access to the bolts that hold it in without too much effort to take the intake related parts out.
Old 01-06-2016, 11:07 AM
johnniewalker91 johnniewalker91 is offline
I know I'm bumping an old thread here, but I wanted to say thanks for the DIY and also ask a question.
I did this DIY with a new ignition switch from oembimmerparts.com and now the car will crank but won't turn over. The first time I started the car it ran fine. Then it sat overnight and it turned over the next day with a very rough idle, any cranks after that wouldn't turn over at all. The car at least would start and exhibit odd warning lights before with the old ignition switch. Any thoughts?
The only thing that was odd to me when I installed the ignition switch is I had to adjust the position of the plastic receiver inside the ignition switch so that the metal piece from the ignition cylinder shaft would fit in. Everything else went really smooth.
Old 01-06-2016, 01:49 PM
TheMalibuMafia
Does the car do a quick clicking? or one clank upon attempting to start?
Quick clicking is either battery or fuel pump related. One clunk means your starter is bad.
TheMalibuMafia.com
