E46 (1999 - 2006)
Old 01-27-2012, 10:12 PM
tiffanycoates tiffanycoates is offline
Mein Auto: 2000 3281
hearing air after I take foot off brakes...2000 328i
So... for awhile now theres been this air type noise coming from the brake pedal area... it used to only do the air noise when i took my foot off the brake but now it does it constantly and only stops when my foot is on.
I took it to les scwab and they do not go that deep into the car but the said they did a brake check & said they are fine..
Then, when I was getting my oil changed they guys said I got a big problem and its gonna cost me big bucks to fix.
Any help, suggestions ??
Old 01-27-2012, 10:28 PM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & JB4+ 335i
Make a video of the sound/problem and we can help.
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
Old 01-28-2012, 06:16 AM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Aside from master cylinder seal overhaul (or swap) one thing you might try is to replace or flush the brake fluid.
Aside from that, air is going through some orifice somewhere, so it's kind of hard to diagnose.
Try a good Indy, maybe via www.bimrs.org.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 01-28-2012, 08:03 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
RUN, don`t walk, away from this place....
The road goes ever onward....
(R.I.P. Jever)
Old 01-28-2012, 01:53 PM
here's the video ! hope this works
this is what it sounds like
Old 01-28-2012, 02:01 PM
& Thanks so much for the help so far!
Old 01-28-2012, 02:11 PM
Ok that is most definitely not normal.
Hard to tell but it almost sounds like a disconnected main vacuum line.
Power brakes work in theory by taking vacuum (low pressure) from the intake to a "booster". In effect the brake pedal acts as a modulator or control to this pressure to translate your (weak) foot power to the (strong) vacuum power of the intake. Hence the term "power brakes".
This all happens in the brake master cylinder, which ties the vacuum, the hydraulic reservoir in the engine and the brake lines. In practice this is all fiendishly complicated by abs dtc etc etc but essentially it all works like this.
So, based on the sound, it seems there is a significant leak in the vacuum.
Are your brakes hard to press I e do you have to stomp on the pedal to get good braking?
- J.C. Watts Jr.
Old 01-28-2012, 02:14 PM
danewilson77 danewilson77 is offline
ZHP Mafia Member
Mein Auto: 2/2004 Imola ZHP
Originally Posted by Llando88 View Post
One thing you might try is to replace or flush the brake fluid.
www.bimrs.org.
First Step: do the above with a proper brake bleed.
Old 01-28-2012, 02:17 PM
Concur. It is possible there is some gunk somewhere that shouldn't be.
Good power bleed and suck via the wheel cylinders is never a bad idea.
I always used Ate SL.
OP - how long has it been since the brake fluid was serviced/replaced?
- J.C. Watts Jr.
Old 01-28-2012, 02:18 PM
The brakes work just as brakes should, and I had them replaced at the end of july 11'
Old 01-28-2012, 02:19 PM
Did they flush the fluid?
- J.C. Watts Jr.
Old 01-28-2012, 02:20 PM
I have never had the brake fluid serviced or replaced, so I'm thinking I should start there... just got the new brakes etc put on during this past summer.
Thanks so much for the advice
Forgot to add- if you go out and look at the brake fluid reservoir, what color is the fluid? (hopefully very light/almost clear).
- J.C. Watts Jr.
Old 01-28-2012, 02:22 PM
Ok it's possible to replace brakes (I assume you mean pads and rotors?) and skip the brake fluid.
If you are handy with tools, check the E46 wiki or we can walk you through it (Fast Bob could do it in his sleep I bet lol).
Otherwise get in touch with a good independent BMW mechanic.
- J.C. Watts Jr.
Old 01-28-2012, 02:24 PM
Im going to go check this fluid right now
Old 01-28-2012, 02:34 PM
Its nice and clear
Old 01-28-2012, 02:58 PM
wow thanks for pointing me in this direction, I can't believe I haven't looked at this wiki until now.
Old 01-28-2012, 03:02 PM
Its nice and clear
Hm kind of points to a mechanical defect allowing air to pull where it should not.
At this point you probably need to get the car checked out by someone who you can trust. Given the noise and the fact it happens all the time, chances are good it can be diagnosed and put right fairly quickly.
Good luck.
- J.C. Watts Jr.
2000, 328i, brakes, e46
