Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 01-28-2012, 10:12 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
MUST READ: Help us help you!! Please read BEFORE posting in the E30 Section
This is especially for the newcomers to this forum, but it does apply to some of the established members too!
When asking a question about your car, please provide as much detail as possible. for example
Car: 320i Touring
Year: 1993
Vin number: xx00000
Euro / Jap / US New: Euro
Options ie: Manual... Auto
The list could go on & on ...dependent on the problem you might have
You might like to input this information into your signature as I have done (at time of writing), so you can skip most of this step
By now I think you should get the drift. We need as much info as you can give us
And a description of what the actual fault is or a pic
Questions that are limited to "my car stopped!! what will I do ??? what is it ??? it runs horrible...." Wont get answered.... call AAA if thats all the information you can give us.
We cant help with alot of the problems you have on a forum, especially if the fault needs proper diagnostic evaluation. We can help by suggesting what you should do, or who to go to, depending on tha area you live in.
This is not a rant... we are all happy to help anyone on here where we can . But please help us as well
Please also remember that diagnosing problems is hard on the internet, and members will tend to only think about it for less than a minute before posting, so the real answer may not come up straight away, if at all
and finally, as a general rule, if you have to ask beginner questions about a turbo install/engine conversion/gearbox conversion.. you are not ready to do this to your car. research, research, research. then when you think you're ready but still have a few questions .. research some more. only then ask questions. An answer to anything that falls into this catagory can be found on this site, as well as others.
Old 01-29-2012, 04:39 AM
SWISS's Avatar
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
I have to concur and if you are feeling it I bet mark,steve and others get it too.
And a picture is worth a thousand words!
If you don't know jack about cars and it just stopped running......
Go to a shop, leave us alone.
If you mechanic tells you something that sounds odd, ask us and we'll set the record straight.
Old 04-11-2012, 06:30 AM
skimmbo skimmbo is offline
Mein Auto: retired
help new to forum
bmw 318i 1988 e30 help
hi can anyone help i jumped another car my bm cut out and she has not went since but tries to go i have had valve timming checked , fuel, coil. and sparked plugs they are all ok finaly had ecu unit changed but stil no joy the car is fuel injected and fixed distributer thats the one with the rota arm only had that checked as well and is ok new to forum please help
Old 05-12-2012, 07:33 PM
newBMWdriver94 newBMWdriver94 is offline
Mein Auto: 1987 bmw 325 2.7
hi i have a
1987 325 2.7 l
5 speed automatic
4 door
she was bought in germany
my problem is that i live in arizona now and the a/c doesnt work anymore, theres still preasure in the piping but its just air and not refrigerant, im hoping its just a leak so if you could let me know what a common place a leak could be, and if thats not it what else could it be. what i mean by that is what is more common to break first, like the condenser, ect ect . any help would be great thanks
Old 05-12-2012, 07:36 PM
i also have another problem that i forgot, ok well when im in parrk and rev the engine it calms down then by its self revs up and down, when i put it in drive or reverse it stops and idles normally, could it be the fuel regulator? but if it was wouldnt it continue no matter if it is in park or drive? if you could help me as soon as possible that would be great thanks.
Old 05-12-2012, 07:41 PM
hey sorry about this but i tried to find one online but it directed me to a forum home page, my rpm/mpg gauge stoped working on me and i was wondering if i could fix it or if anyone knew where to find a new or a good used one? the gas gauge, mph and engine temp works fine (thank god) its just the rpm/mpg gauge? can anyone help me?
Old 05-13-2012, 04:19 AM
try to stat your own thread for questions, this is an announcement only not a discussion thread. i should close it really. in anycase.....:
Originally Posted by newBMWdriver94 View Post
hi i have a
1987 325 2.7 l
5 speed automatic
4 door
take it to an A/C shop and get them to pressure test it. they use a dye that comes out of the holes in the lines. you will have to take it to an A/C shop to be refilled anyways so not worth trying to figure it out yourself in my opinion.
thats your idle control vavle. quite a common E30 issue
check the connections on the back of it are secure, and also check to see that the brass earthing nuts on the back of the cluster are done up tight. also could be your Service interval batteries starting to die as well.
Old 05-13-2012, 11:06 AM
Mein Auto: retired
hi i have a
1987 325 2.7 l
5 speed automatic
4 door
hi the ac i dont know anything about,we live in scotland so don need it.all i know about revs going up and down if its fuel it is controled by the ecu unit
Old 05-20-2012, 10:21 PM
onlycheetah onlycheetah is offline
Mein Auto: bmw 325ic
I have a 1989 3251c, car wont start or turn over... no click battery is charged and new? help please.. this happened at a gas station filled up with gas and after car would not start or even turnover and no click at all
Old 05-21-2012, 01:21 PM
Mein Auto: retired
sounds like its imobalised it self get a electrition to check but before that check theres no loose wires on starter
Old 05-22-2012, 05:04 PM
leprechaun leprechaun is offline
Leprechaun
Mein Auto: 1990 325i BMW
Question suspension question!
Car: 325i
Year: 1990
I'm just simply wondering if anyone can help me find or send me links to a good place that sells suspension for my car. I've been looking around and it seems like ever place has a different kinds of shocks and struts that i need. So my majo question is what are the best kind, and please keep in mind I need fairly cheap ones.
Old 05-23-2012, 08:34 PM
e30kid84 e30kid84 is offline
Mein Auto: E30
can i use a honda civic turbo kit for my car?? hahaha JKJKJK
Old 05-24-2012, 08:32 PM
Madman415 Madman415 is offline
Mein Auto: E30 325e
I hate sounding like a moron but in this case the shoe fits... How do I set my signature?
Old 07-12-2012, 05:59 PM
SWISS's Avatar
On Top
No worries, you have to go to the user cp and set it up. Here is the proper forum for these types of inquiries FYI.
http://www.bimmerfest.com/forums/for...aysprune=&f=29
Old 08-18-2012, 04:17 PM
KingKTiger KingKTiger is offline
Mein Auto: BMW 325iX
Is knowing the VIN number necessary
Is showing my VIN number necessary for you to help me with my problem. I am good with following the rules and all but VIN number seems like were overdoing the identification.
Car: BMW 325iX 4 door Sedan 6L engine
Year: 1989
Vin number: WBAAE0303K8147321
US New: Made in USA
Options: Automatic
Mileage:173,586
Old 08-18-2012, 07:43 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
All you need to provide is the last seven digits of the VIN. That can be used to find out your exact build date and what parts fit your specific car. It's not like you're posting your entire VIN.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 04-16-2013, 08:46 PM
Brickenfist Brickenfist is offline
Mein Auto: 1985 325e
Hope this is the right forum!!
I am having trouble removing the starter!! It is a 1985 325e with a manual transmission and it is a 6 cylinder. I removed everything I needed to, and the starter won't come out. I removed the 3 cables connecting to the starter, and I also removed the bracket holding the starter to the engine. I just can't get the starter out.
Old 04-16-2013, 09:00 PM
D'oh, You kids!
I see no mention of removing the two bolts holding it to the bellhousing........
Quotes to live by:
BMW-CCA #441426
