Old 01-29-2012, 10:13 AM
angina angina is offline
Officially Welcomed to The 'Fest!
Mein Auto: 2007 X3
Replacing Coilpack
My X3 engine shudders when I accelerate, and I am 90% sure its a bad coil pack. I had the same thing happen to me a couple months ago, and it was due to the coil pack. I'm even more sure about this because the car smelled like rotten eggs a couple days ago, and that happens when a coilpack goes bad.
Anyways, the last time it happened, the dealership fixed it but it was way too expensive. I've replaced coilpacks on my old VW, so I know its pretty easy. However, never having done it on the X3, does anyone have a DIY or instructions on how to replace?
2007 X3 3.0si Minivan / Alpine White / Black Leatherette / Brushed Aluminum / Steptronic Transmission / Navi / Xenons / Premium Sound / 18" 205-Style Wheels / Ordered 4/4, Production complete 4/16, ED Pickup 5/15, ED Dropoff 5/24, Arrived on Integrity 6/17, VPC 6/19, Released to Carrier 7/9, Re-Delivery 7/12!
Old 01-29-2012, 12:43 PM
brewder brewder is offline
Mein Auto: 2011 328i xDrive
Help me understand your "shudder"... I think my 2008 has a similar issue. Under "heavy" acceleration, mine feels like it shudders... Most normal city driving you can't feel anything, but heavy acceleration is feels like it's "mis-firing" or something. Curious if this is what you are describing...
The harder part is then figure out which of the 6 coil packs are bad.....
//Brew...KCCO
('11 E92 328i xDrive - Deep Sea Blue | '07 E92 328xi - Space Gray)
Old 01-30-2012, 08:39 AM
Mein Auto: 2007 X3
the engine "shudders" when I go above certain RPMs, and it is really bad. I am pretty certain it is the coilpacks, because I had the same issue before.
The coilpacks sell for about $50 online, but to get them replaced at a shop, it costs nearly $200 (with the part). I know the job itself is real easy on most cars, but just not familiar with replacing it on a BMW...
Old 01-30-2012, 08:45 AM
Check out this excellent video for the DIY...
http://blog.bavauto.com/10523/diy-vi...o-m54-m62-n62/
//Brew...KCCO
Old 01-30-2012, 09:06 AM
Mein Auto: 2007 X3
thanks!!!
Old 01-30-2012, 02:05 PM
Mein Auto: 2007 X3
so does anyone know if it is safe to turn on the engine with a coilpack removed? I don't know exactly which coilpack is bad, so I figured I would remove one, and turn on engine and see if the car shakes/shudders even more. This would help determine if the coil I removed was good. If the one I pulled was in fact already bad, I shouldn't expect the engine to shudder even more than normal.
this is the process I used to test/replace coilpacks on my previous Volkswagen and hoping it would be fine to do on the BMW....
Old 01-30-2012, 02:39 PM
John@SAtlBMW John@SAtlBMW is offline
BMW Parts Guy
Mein Auto: e39/e38/austin healey/jag
if you drive it and try to force the shuddering situation, you should get a SES light come on... check the code and it will tell you which cylinder is misfiring. I'm not sure how the computer will like running with the coil pack unplugged. I wouldn't recommend it.
Old 02-01-2012, 07:07 AM
Mein Auto: 2007 X3
do you know where I can go to check the code without having to go to a dealership and pay $100 for a "diagnostic" fee?
Old 02-01-2012, 07:31 AM
BMW Parts Guy
yeah... you can always go buy a hundred dollar code reader!
Old 02-02-2012, 06:01 AM
Mein Auto: 2007 X3
so i went to autozone, had them look up code, found out it was the first cylinder misfiring, and replaced the coilpack. That was definitely it, as the car drove fine afterwards. However, the "Service Engine Soon" light remained on.... I drove it around and it didn't go away, and then I disconnected the battery, but the light remained on. What gives?
In addition to that, after I disconnected the battery and reconnected it, the "4x4" and "Brake" lights turned on! I had an issue before with the actuator motor, but I had that fixed, and the car drives fine. Why would those lights come back on after disconnecting battery?
Old 02-02-2012, 06:24 AM
Hi - I don't have an answer for you but wanted to ask something to clarify... Was your Service Engine Soon light ON when you asked AutoZone to read the codes??
//Brew...KCCO
Old 02-02-2012, 07:13 AM
icuc's Avatar
icuc icuc is offline
Mein Auto: 2012 X5, 2012 MINI ALL4
Go back to autozone and erase the code. It should have gone when you removed the battery.
BMW (Remote) Coding for E Series, F Series and G12 Models - www.bmwminicoding.com
Old 02-02-2012, 09:47 AM
Mein Auto: 2007 X3
can they erase codes?
Brewder: Yes, the service engine light was on when they scanned it. The light came on when I started having issues with the coilpacks a couple days ago.
Replacing the coil definitely got rid of the shuddering issue, and the car drives fine now. Except I still see the SES light. ignore my comments about the 4x4/brake lights coming on. they went away...
Old 02-02-2012, 10:28 AM
icuc's Avatar
Yes you can delete the code. Just ask them...
Old 02-02-2012, 11:43 AM
Mein Auto: 2007 X3
blah.. they just told me they aren't legally allowed to clear codes... i'll have to find an ODB scan tool myself.
Old 02-02-2012, 11:51 AM
timfitz63's Avatar
timfitz63 timfitz63 is offline
MT = Doppler Shifting
Mein Auto: 2007 X3 (MT)
That's been my experience too...
Often times a latched SES will eventually clear, if the fault has been corrected; it just requires a certain number of engine starts without the fault reoccurring before the computer clears the SES. Try giving it a bit of time...
X3 w/6-speed & Sport Package:
A sports sedan disguised as an SUV...
Old 02-03-2012, 07:28 AM
icuc's Avatar
O'Reilly sales person once told me, how to delete them. Go to a different store to do it.
Old 02-09-2012, 08:15 PM
Mein Auto: 2007 X3
ok, so after a couple days, the SES light went away! guess i just needed to wait
Old 04-19-2013, 02:47 AM
ncord ncord is offline
Mein Auto: 2006 X3
I have same problem with shuddering (misfire) when engine under load @ 3000 rpm.
There was oil in plug #2 so I replaced VCG & plug gasket .new plugs, 2-pre cat.O2 sensors,&
new coil pack in cyl.with oil leak.
I STILL HAVE THE DAMN MISFIRE WHEN I BOOT IT... What Next???
PS; I have never had a Check Engine light . 88K miles
