Old 01-29-2012, 11:32 AM
johnd1976's Avatar
johnd1976 johnd1976 is offline
Mein Auto: 2007 530xi
Headlight housing removal
Does any 1 know the steps how to remove the complete headlight housing for the 2000 e39 does the front bumper cover have to come off or just the plastic under the housing come off. we all know after 10 plus years they yellow and get moisture inside I was planning to get depo or some kinda angel eye ones from ebay. People also say aftermarket ones usually don't fit right also gotta say I love thi site really nice people and helpful here so far I love the e39 great car
Sent from my SPH-D700 using Bimmer App
Old 01-29-2012, 11:41 AM
1999 BMW 540i 6 1999 BMW 540i 6 is offline
Mein Auto: 1999 540i m 6spd
on mine its 4 bolts under the hood no plastic removal took me less than 1 minute to remove headlight
Old 01-29-2012, 11:43 AM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
Look on the bottom back side of the light housing and you'll see the bottom two 8mm hex heads like there are on the top.
Old 01-29-2012, 11:56 AM
NoWayJose's Avatar
NoWayJose NoWayJose is offline
Mein Auto: 00 528ia Sport
here you go.
http://www.bmwdiy.info/non-celis-front/index.html
00 BMW 528ia Sport
M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, Euro Lens, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza Orion halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks with H&R Sport Springs, 19" M6 Reps, Full LEDs.
Old 01-29-2012, 04:08 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
If you have a small piece of body colored plastic below the headlight assembly, the strip hooks into the fender at the outside corner. So rotate the inboard side out first, pivoting around the outside corner until the plastic trim releases.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 01-29-2012, 09:36 PM
MikesE39's Avatar
MikesE39 MikesE39 is offline
Mein Auto: 03 530i Loaded
the removal of the headlight is very easy. but the problem is opening it. idk about the non xenon headlights but on the xenon ones i spent an hr the otherday trying to open the headlight and finaly quit after an hr.
Old 01-29-2012, 11:13 PM
My 2001 HID assemblies were sealed with black, sticky material that I think is butyl rubber glue. I was able to open the housing by baking it for a few minutes. I think the 2002 and forward models were epoxied.
But the OP just wanted to know how to remove the assemblies so he could replace them with aftermarket assembiles.
Steve
OSRAM CBI
Old 01-29-2012, 11:21 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
For reference, a quick /headlight F3 in the bestlinks revealed these of interest:
- How to physically remove the BMW E39 Hella headlights (1) & how to open the headlights to make your own headlight adjusters (0) (1) (2) (3) and a summary list of all your options when your headlight adjusters are broken (1) & headlight autopsy photos (1) (2) (3)
Old 01-30-2012, 05:12 PM
MikesE39's Avatar
The problem with mine is the glue, the clips come off but the glue is amazingly strong.
Old 01-30-2012, 05:27 PM
If you're trying to open the assemblies to replace the adjusters, you may be able to cut a hole in the top of the case to replace the adjusters.
Steve
OSRAM CBI
Old 03-15-2012, 08:08 PM
EconoBox EconoBox is offline
Mein Auto: 2001 530i (E39) 140k
2003 can't be opened.
2001 can be baked for 5 mins at 200 degrees.
Old 03-15-2012, 11:19 PM
ilian007 ilian007 is offline
Mein Auto: BMW 530i 2002
Yep i tried to open mine 2001 it is black sticky thing. I couldnt just with screwdriver... Didnt think back then to bake them. Lol
Old 05-14-2016, 11:42 PM
e34vibes e34vibes is offline
Mein Auto: 1994 BMW 530i Base 3.0L
I have a 1994 530 that i i just purchased brand new angel eye headlights for but I have never replaced headlights so i m confused on how to go about removing my old ones and installing the new headlights when they officially get delivered. I read that I might have to use a t quarter box wrench to remove them because they have the t torx bolts on them but I dont know for sure. I was just wondering if would be the same as your 99 540i?
Old 05-14-2016, 11:47 PM
Brandon002's Avatar
Brandon002 Brandon002 is offline
Mein Auto: 2002 530I Sport
You have an E34... Entirely different than hour E39s.
Old 05-15-2016, 06:33 AM
amancuso's Avatar
amancuso amancuso is offline
Send a message via AIM to amancuso
Mein Auto: Z3 2.3iA/5MT 528iA VW GTI
You can still buy new headlight adjusters.
https://www.ecstuning.com/ES172070/?...FegaAoVq8P8HAQ
