Old 01-29-2012, 03:44 PM
Ben Alvarado Ben Alvarado is offline
Mein Auto: BMW X3 3.0
BMW X3 3.0 will not start.
BMW X3 3.0 will not start due to a weak/low battery.
Replaced with new battery, still will not start. all tyou hear is click when you turn the ignition key.
Still will not crank or start. Isthere a reset key or switch in the related systems? How does one get it to start?
Ben Alvarado
Old 01-29-2012, 05:24 PM
noego noego is offline
Mein Auto: '06 X3, 1997 Chevy truck,
make sure your connections are clean and free from corrosion. make sure your connections are good and snug, but don't over tighten and break the hard to find and expensive terminal bolt and nut. is your new battery fully charged and does it have the CCA (cold cranking amperage) to turn the motor over and start.
good luck, Ben.
Old 01-30-2012, 01:13 PM
bobbyjoe bobbyjoe is offline
Mein Auto: 2008 X3 3.0si
Battery might be newly purchased, but is it new? To make sure it's not the battery, measure with a voltmeter/multimeter. New battery with car off should be ~12.5V. For me, the lowest voltage I've ever measured and got my car to still start is 11.9V. Could definitely hear that it wasn't a happy start at that point though.
Original 2008 BMW X3 3.0si battery has 720CCA, 90Ah and 160RC. Check to make sure your replacement battery has 720CCA (or whatever CCA your model/year OEM battery has)
Old 02-06-2012, 06:54 PM
BMW FAN95 BMW FAN95 is offline
Mein Auto: 2007 BMW 335i
Ben Alvarado
My bluetooth computer was draining my battery,,, check yours out if you have one
Old 02-06-2012, 07:38 PM
shendrick shendrick is offline
Mein Auto: 08 M3, 05 e46 zhp, 07 X3
BMW FAN95 could you explain. We just lost our battery after just 12 months - but that also coincides with when we linked a phone to the car. Kinda thought it was just a new BMW battery with a bad cell - but it sounds like there is more to this - at least from your experience.
Old 02-07-2012, 05:08 AM
darkrider darkrider is offline
Mein Auto: x3 2005
Hello from Prague!
X3 2005 - 3.0d
-20 degree Celsius (that is not much in degree Fahrenheit)
and the car will not start ... starter runs and empties the battery, it smells like Diesel not burned, but only few "brom brom" as the car would start and will not...
After putting a heating system under the car for 30mn, + starting my wife's car and plug to a brand new battery (bought yesterday evening) - then the car will start....
The first minute you can feel that not all 6 cylinders are working/exploding - after 1 minute, then it is fine: the car keeps the slow RPM just above 800tr/mn and no problem at all.
However, 1 night in the cold and it is over ... even with a brand new battery.
Need to check the starter and the candles...
cheers,
Old 02-07-2012, 07:56 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
The candles for sure! Good luck and I am jealous you get a diesel and we do not.
Old 02-07-2012, 09:01 AM
ghpup's Avatar
ghpup ghpup is offline
Glfbggy
Mein Auto: 07 X3si, 14 535xd, 00 MZ3
cheers,
My personal experiences with Deisel in the cold is that there may be troubles as the fuel becomes less liquid and becomes almost like gelitine. You may want to look into a fuel additive that helps keep it more liquid. This doesn't sound like a battery issue so much as a cold weather and fuel issue.
GLFBGGY
'00 MRoadster, '00 528 now in other hands, '07X3si, '14 535d XDrive
Old 02-07-2012, 03:20 PM
timfitz63's Avatar
timfitz63 timfitz63 is offline
MT = Doppler Shifting
Mein Auto: 2007 X3 (MT)
... -20 degree Celsius (that is not much in degree Fahrenheit) and the car will not start ... starter runs and empties the battery, it smells like Diesel not burned, but only few "brom brom" as the car would start and will not...
However, 1 night in the cold and it is over ... even with a brand new battery...
"darkrider," I agree with "ghpup." According to this source -- and depending on the blend of diesel and amount of water contamination -- it could start to gel at a temperatures as 'high' as -9.5C/+15F. So if yours is getting cold-soaked to -20C/-4F, there's a very good chance your fuel pump is just trying to push waxy diesel sludge through your fuel lines/filter...
X3 w/6-speed & Sport Package:
A sports sedan disguised as an SUV...
Old 02-09-2012, 09:42 AM
ghpup's Avatar
Glfbggy
Originally Posted by timfitz63 View Post
"if yours is getting cold-soaked to -20C/-4F, there's a very good chance your fuel pump is just trying to push waxy diesel sludge through your fuel lines/filter...
I once got stranded late at night (ok early morning) in the mountains north of Bormio, Italy when the tempurature droped towards -15C*. We were 5 teenagers in a VW Golf. Eventually we received a tow from a Merc e450. The next morning after warming up, no problem....
GLFBGGY
Old 02-09-2012, 10:31 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
Ben Alvarado
Coming back to the original poster problem....If the battery and connections are good, I'd bet it's the starter.
"If everything seems under control, you're just not going fast enough"
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
Old 02-10-2012, 04:39 AM
Mein Auto: x3 2005
Thank you all for your feedback.
I was already adding additive:
few days back, car with "reserve" light on, I went to buy additive i put in the fuel tank, then 1/2 of the fuel tank of Shell Diesel V-Power and still same issue, the car with a new battery is not going anywhere.
I noticed as well that the new battery needs recharge after 3 days trying to start (about 8-10 starter kicks)
that leads me to think the starter is weak and is over consuming energy and not turning fast enough
so for me, next step, changing starter and pre heating candles
