E46 (1999 - 2006)
Old 01-30-2012, 07:24 PM
dtmajor dtmajor is offline
Mein Auto: 325xi, m3
radio antenna
I have terrible radio reception, took my car to BMW and they said it was the antennae in the rear window and the only solution was to replace the window at a cost of $800- $1000 OUCH!!! Any suggestions?
Old 01-30-2012, 07:36 PM
danewilson77 danewilson77 is offline
ZHP Mafia Member
Mein Auto: 2/2004 Imola ZHP
I would check the connections tight in the driver's side C Pillar first.
Sent from the HTC Thunderbolt
Old 01-30-2012, 08:55 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Radio reception on ALL E46s is sh!t, even when brand new....the only *real* solution is to drill a hole in your fender and have a (traditional) antenna installed. Not pretty, but at least they *work*....
The road goes ever onward....
(R.I.P. Jever)
Old 01-30-2012, 09:51 PM
johnrando johnrando is offline
Mein Auto: 2006 330cic ZHP, Cold pkg
Countless stories of making sure everything is tight before you make you next move, as said earlier. That usually helps. Hopefully that will improve it, but yeah, the radio reception on these is poor. However, I've NEVER heard of a recommendation to replace the whole window, that sounds like BS to me.
John "jr"
'06 Cic ZHP, Southern California
ZHP Performance Package, Cold Weather Package, Leather, Jet Black/Black/Black Cube
Active Autowerkes Tune, Sprint Booster, BMW Performance Air Intake
DICE Ipod, Parrot/Connects2 Bluetooth, StealthOne Valentine Module
BMW Performance Strut Bar, Orion V2 Angel Eyes, No-holes License Plate
Old 01-31-2012, 07:26 AM
P_T's Avatar
P_T P_T is offline
Supporting Member
Mein Auto: 323 Ci
As others have said, never heard of replacing the whole rear window and it sounds hinky to me. Check fittings first. Another issue might be the antenna amp. You radio is suppose to match the antenna amp. If your radio was ever changed and it didn't match the amp there would be an even greater loss to an already poor system. Make sure it matches, or you might consider just replacing the antenna amplifier with one from the bone yard.
PT
___________________________________
Old 01-31-2012, 07:32 AM
e46 antennae
Amazingly I had the car at BMW and the tech checked the rear drivers pillar and said everything was tight and it was the tech who told me the only solution was replacement
Old 01-31-2012, 08:20 AM
P_T's Avatar
P_T P_T is offline
Supporting Member
Mein Auto: 323 Ci
So now you have a decision: get a new one; get a used one; put up with it or use a MP3 player.
PT
Old 01-31-2012, 08:30 AM
You said the tech checked, but there are also settings on the radio... it's a long shot, but for instance, it could be set to EURO instead of US. I forget how to do it but I'm sure it's in the manual.
John "jr"
Old 01-31-2012, 04:29 PM
Schneldorff Schneldorff is offline
Where's my avatar?
Mein Auto: BMW 330ci Convertible
Mine works fine. even put a smaller 9" antenna on it and the reception is great. Hard to generalize all of anything when there are so many variables involved like station output power, distance, location, interference, type of antenna, etc.
Old 01-31-2012, 04:56 PM
e46 radio
Thanks for the info I'll check to see if it's Euro or US. I may try a smaller antennae such as the ones Sirius uses attached to the trunk
Old 01-31-2012, 05:52 PM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
Remember, the convertible uses an antenna mounted on the drivers side rear fender. Totally different system. My vert radio is fine as well. Other systems use an antenna mounted to the inside of the rear window. If the continuity of the tracers is broken, reception will suffer. Auto parts places sell a kit to repair the tracers. Continuity can be checked with an ohm meter.
OP: not saying this will def solve the problem, but you may want to try deoxit, a contact cleaner, on all the connections before giving up.
Old 01-31-2012, 06:00 PM
Fast Bob's Avatar
Keeping it surreal
You`re missing The Big Picture here, Sport....which is that you happen to own the only model of E46 equipped with a *real* antenna....all sedans, coupes, and wagons get burdened with the in-the-glass variety, which, believe me, is for sh!t, regardless of location, etc.....
(R.I.P. Jever)
Old 01-31-2012, 06:06 PM
Where's my avatar?
Fast Bob said "ALL E46s is sh!t". He's wrong because mine is an E46 and the radio sound is audiophile quality. I own a McIntosh MR-77 tuner and the radio in my E46 picks as good as if not better. Now had you said E46's with window antenna's that would be a different story......sport.
At to the original poster, if the BMW service center said your antenna is bad I would tend to lean their way since it's not that hard to troubleshoot. You could probably find a dipole of some sort to mount and save a ton of money.
Old 01-31-2012, 06:12 PM
Fast Bob's Avatar
Keeping it surreal
Fast Bob said "ALL E46s is sh!t". He's wrong because mine is an E46 and the radio sound is audiophile quality. I own a McIntosh MR-77 tuner and the radio in my E46 picks as good as if not better. He's certainly entitled to his opinion but I would take it with a grain of salt.
I believe I covered this in Post #12, genius....
(R.I.P. Jever)
Old 01-31-2012, 06:14 PM
Where's my avatar?
I didn't read post #12 Obama.
Old 01-31-2012, 06:16 PM
Where's my avatar?
Obviously not very fast fast bub. How many times have you been suspended here?
Old 01-31-2012, 06:43 PM
SJBimmer's Avatar
Your pushing your luck. 8 posts and you have an attitude? Get with the program or keep walking.
Old 01-31-2012, 06:50 PM
Where's my avatar?
He personally attacks me twice and I have the attitude? Is there a ranking system here where you are allowed to treat people with a lower number of posts like crap? All I did was defend myself. How about a little respect? Treat me as you would like to be treated.
Old 01-31-2012, 07:23 PM
e46 radio
I can't speak for all e46 BMW's but I also have a 2002 M3 and I agree that the convertibles with the small fender antennae get much better reception that the sedans or wagens. I drive both at least once a week depending on the weather and the sedan's radio reception sucks and the convertibles isn't perfect but it's much, much better.
Old 01-31-2012, 07:32 PM
Fast Bob's Avatar
Keeping it surreal
I am a highly-opinionated, heavily caffienated, equal opportunity curmudgeon, I treat *everybody* like crap....get used to it, it`s part of my charm. Now, pull your knickers up and act like a man, for Chrissakes....you`re running with the BIG dogs now....
(R.I.P. Jever)
Old 02-01-2012, 05:17 AM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
And yet we all love you just the same. Go figure...
So if all E46's have the antenna in the rear window, which explains why my radio reception turns to crap when the rear defroster is on, then what the heck is that pointy thing on the back of my roof that I always assumed was the antenna?
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 02-01-2012, 06:56 AM
zQUEz zQUEz is offline
Mein Auto: 325i
- GPS antenna.
Old 02-01-2012, 07:46 AM
new_kid new_kid is offline
Quietly Learning E46
Mein Auto: 2000 BMW 323i
I thought that thingy have something to do with using wireless devices in the cabin, like a cell phone for example. Correct?
ps: Thankfully my radio reception works very well, regardless of location
Old 02-01-2012, 09:34 AM
EWeis EWeis is offline
Mein Auto: 1999 328i
I saw this on BavAuto's blog page. Anyone try this fix yet or think it has merit?
http://blog.bavauto.com/10056/bmw-po...-other-models/
Sent from my EVO
Old 02-01-2012, 10:22 AM
SJBimmer's Avatar
Sent from my EVO
See my post # 11 above.
Yes, it absolutely has merit. I have seen deoxit perform miracles on many types of electrical equipment. It improves connection quality dramatically. Check some of the reviews over at Amazon.com to see for yourself. They sell a small tube over there for around $7. A little goes a long way. Remember to check continuity of all connections, because it won't fix a physically broken connection.
