E46 (1999 - 2006)
Old 03-08-2013, 09:35 AM
JakuLuka JakuLuka is offline
Mein Auto: E46 316ti
Was thinking if A4driver has jammed eccentric shaft and it plays around like ours the problems must be in vvt... I will get ECU for testing next week and if it doesn't work might get vvt control unit too.. How is the relay supposed to work next to vvt unit? any idea?
Old 03-10-2013, 12:21 PM
A4driver A4driver is offline
I did open my cover once more to verify the spring. Is has no function at all. And the shaft (with motor removed) is hard to move with only hand. I did loose up all carriers a little, but it didnt help any. I did replace valvetronic motor half year ago. Do anyone here use a DIS tester? Each time I use my own to reset valvetronic motor limit, I get some strange error messages, and I cant hear any sound like it relearns the limits.
Old 03-10-2013, 12:25 PM
Originally Posted by JakuLuka View Post
this is mine...
i didn't open vanos units yet coz don't really have time for that yet .. have to get bmw to everyday use first....
This is the same end stop as mine.
Old 03-10-2013, 01:51 PM
I have bmw scanner and INPA cables... Does they help connecting DIS? or do you need DIS cable?
Old 03-10-2013, 02:17 PM
DIS is the oem BMW diagnostic. So yes it need cable. I have a "virtualpc" version, works perfect on everything to do with diagnostic, tests and livedata. But the valvetronic reset dont work. Can you do this reset with bmw scanner or inpa? I have both. Bmw scanner 1.4.0 and a inpa from 2005. Cant do the relearn with my versions(not an option).
Old 03-10-2013, 02:20 PM
BMW scanner can't connect on vvt unit. Don't know if this is fault or is it supposed to connect... INPA cable should work with DIS or so i read.. Have to try.
Old 03-10-2013, 02:26 PM
I use the same cable for dis, progman and and inpa. It all came with in a kit from ebay.
Old 03-27-2013, 03:41 PM
Well new DME didn't help.. I was wondering if n62 had similar problems because it kinda has same head that n42 has... Well couple of things found :
"my service facility told me it sounds like sludge. not enough oil pressure on cold start to operate the CCT properly causing the cam to move enough to cause the misfires."
(This was for multiple misfires on cold start)
That is something that i could believe.. Especially when cold oil is thicker than warm. I was thinking that my head casket sealer was glued and mayby some glue is somewhere stuck.. But another interesting :
They had some kind of problem with intermediate levers with bad tolerance... But if bad tolerance causes cold start miss fires why wouldn't normal wear...
Yes.. They are just misfire problems on n62 but it has 2 heads... so the compression lost wouldn't probably show...
Just losing my mind with this and searching everything i was thinking i will take vanos adjustment units off friday and see if pipes from solenoid valves has something stuck..
Today i found with my pal that my vvt motor turns even if compression is gone so i dont think that could be the proplem..
I just can't figure out how they would slowly give compression back but i'm really losing my mind and just want to check everything... I would really need this car to work..
Old 03-28-2013, 02:55 AM
I fixed mine 2 weeks ago. The fix was to sell the car for a price off total loss...
After one year I got enough.
Old 03-28-2013, 02:58 AM
Mine previous owner did that fix... i was the sucker he sold it to..
Old 04-03-2013, 04:15 PM
Erki Erki is offline
Mein Auto: E36 318is
Similar problem there. This person went to BMW dealer and they reprogrammed the ecu. Maybe this helps.
www.youtube.com/
watch?v=15TRrCpMbRw
Old Yesterday, 05:56 AM
HATCHET HATCHET is offline
Mein Auto: bmw 16ti se compact 2002
Exclamation excentric shaft sensor /HELP where is this,where do you unplug it?
Originally Posted by chansta View Post
thats good to hear
btw the learning procedure you carried out was for the valvetronic motor not the vvt (which is vanos for bmw's). There are no relearning procedures in scanners for vanos.
hi mate,i have the same problem on my bmw 1.6ti,i have the codes p1062 and p1031,saying vvt,someone said its the excentric shaft sensor,where is this to unplugg it mate,but he could not say 100% if this is the problem?help
Old Yesterday, 11:45 AM
mmm.. Here is a pic you can see the plug
http://www.impee.co.uk/sparkplug_cha...tion_coil2.jpg
in that pic you can see the plug in between ignition coil and oil filling hole.
