E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
Fan blade replacement issue
I recently repleced the water pump, water pump pulley, and fan blade on my z3. i decided to do this myself and it wasnt too difficult but the fan blade is alot louder than the OEM one i had on before. is this normal or could it have to do with the fan blade itself??
possibly on backwards?
2000 Imola Red M Coupe Dinan suspension, M rotors /Axxis pads Eurosport Cam Kit 1, touch lane change Zaino polish, Beach Sand Garys mirror adapter, S54 Oil Cooler seat tilt coupling nuts, spare tire "life's to short to drink cheap beer"
no that ws one of the first things i looked at. but its on the correct way. im actually working on it right now to see if maybe i put on the fan blade t the fan coupling wrong, but it looks fine. perhaps its just the fan blade itself. cheap plastic.
It sounds like a faulty fan clutch. These fans are LOUD when the clutch locks. The clutch should freewheel when cold, and stay "open" until the engine reaches high-normal operating temperatures. In your case, your fan clutch might be engaged permanently or engaging prematurely. When the fan clutch is operating properly, it is possible (with great care!) to stop the fan with the engine idling at cool to normal operating temps, but it is not something I would recommend doing if there is a chance it won't stop easily...
-Kyle
1999 Z3 Coupe, Arctic Silver/Tannin Red & Maple |
so the fan clutch is the fan coupling, correct? cause i dont think it was damaged when the water pump broke. i replaced the water pump, along with the pulley and fan blade. any recomendations on what i can do with the fan clutch?
Best thing to do when you are there is replace as much as you can afford.
"One good curve deserves..........another" Modified Boston Grun 2.8 Z3 Garage Queen 5 vintage 60/70 Volvos & a 1 of a kind '62 morris Minor pickup Clearwater Beach sand Daytona Beach sand SC Homecoming Red Clay Deals Gap Dust in the Wheel wells Maggie Valley Fall leaves in the Trunk Florida Love bugs stuck in the Grill Islamarada/Pigeon Key crushed coral chips Mojave Grass seeds in hardtop window Mane from sorrel 'Leo' quarter horse, a congenital Californian |
So it looks like it is the fan clutch. The strip that appearently reads the tempature was off the clutch. i tried putting the strip back on but still doesnt work. i was looking up some fan clutches and it looks like there is thermal and non- thermal. would either be fine on my z3?
I had no idea non-thermal viscous fan couplings were in existence. What is the difference?
'Non-thermal fan clutches operate based on the water pump shaft speed. When the water pump shaft is spinning at low and idle speeds, the clutch will spin the fan at about a 1:1 ratio. During high speed rotation the silicone fluid within the fan clutch reduces its ability to spin the fan at full speed and the energy transferred from the water pump shaft, through the clutch to the fan is reduced. The result is less load on the engine as the fan almost free-wheels'. I dont even think they make non thermal clutch fans for the Z3 but they dont seem to have an advantage on the thermal clutch fans anyway.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
