Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 06-02-2012, 07:53 AM
TDIwyse TDIwyse is offline
Mein Auto: 4 diesels
Well, needed to run some errands so I stopped off and downloaded some data.
This is one of the best of the remap only runs (pwr results varied from ~224-230 on multiple runs) compared to the single runs of the remap w JBD at 0% and 65%.
2011 335d Sport Package/Cold Weather Package
2004 Ram Cummins with lots-o-mods
1990 YJ Repowered with modified Cummins B3.3T
Old 06-04-2012, 05:24 AM
A couple more pulls were performed after getting some local fuel back in the tank (~1/2 tank added after long drive the previous night). Think the other fuel was less than optimum based on these results.
Temp was more than 10F warmer than previous testing. Below shows comparisons of the remap stacked with JBD at 0 and ~65%. The "Main" and Run 1 are 0%, Runs 2/3 are 65%. Again, was being careful not to give full fuel at low rpm's . . .
Also showing some of the "speed" data which is interesting. For these 3rd gear pulls the full fueling is occuring between ~45-75mph. The 50-70 times are thus right in the main thrust of the test. The reported times are nice.
Also, still not seeing any engine parameters that are over stressed. Although the pulls happen so fast that this is somewhat expected. If you were continuing this kind of stress (towing or racing for example) it would likely be a much different story.
ID:	327803   Click image for larger version
Old 06-04-2012, 07:02 AM
Concentric190 Concentric190 is offline
Mein Auto: Turbo M3
this is some very interesting data. I'd really like to see what these tranny's can be pushed to.
///Andres
09 335d evolve tuned - 327whp / 490wtq -- 13.0@105
95 M3 Turbo - Built 3.0l s52, PTE74GTQ, AEM EMS & CDI
Old 06-04-2012, 10:07 AM
hotrod2448 hotrod2448 is online now
Mein Auto: E70 X5, E90 335d
Thanks for gathering all this data. To avoid making potentially wrong assumptions on this chart which run is which? Also, I didn't see the info in there and maybe you don't want to disclose it out of courtesy to Evolve but, would you mind throwing up a plot of stock boost and remap boost vs. RPM? If not that's cool too but, could you at least clarify if it is a significant increase in boost or only a few PSI? I'm not sure if using that low of a gear will even give accurate boost numbers but, I just like to see data.
Old 06-04-2012, 11:27 AM
The owner has had some interaction with Evolve and they haven't said to not share any of this info. They, by the way, have been good to work with. Same for VS. And to be clear, they do not recommend stacking the JBD on top of their tune.
The boost info is back here: http://www.bimmerfest.com/forums/sho...8&postcount=49
The JBD run is the same boost as stock. It does not touch boost (one of the previous posts has stock/JBD and verifies that). These numbers are absolute pressure (normal atmosphere + boost). Converting hPa to PSI and subtracting 1 atmosphere brings the numbers to ~ 26psi stock and 30psi remap.
The BT data is on a different computer and it can be plotted vs rpm. Will try to do that tonight. But the boost response is unbelievably fast and occurs right away even at low rpm's. Most likely due to how BMW has executed the twin turbo setup. Just lovely.
I agree the naming of the Gtech data has been poor. When the Gtech gets powered up it defaults to Jan 17 2017 and the time seems to be random. And I haven't been good at going in and re-formating the dates/times/conditions etc . . . I tried to correct that starting on post 52 which shows multiple runs with the remap and JBD stack. The plot you showed is Run1 = Evolve (2nd best of multiple runs), Run 2 Evolve+JBD 0% (only 1 run on this combo that day), Run 3 Evolve + JBD 65% (only 1 run on this combo and the last run).
A note on the Gtech data. It includes more losses than a 2 wheel dyno: 4 wheels are turning instead of 2 (more rolling resistance), wind losses (~20 hp at top end of run based on Cd and frontal area), and the pulls are in 3rd gear so there's more drivetrain loss than a ~1:1 gear ratio). And it's subject to variations due to road surface roughness, flatness, the accuracy of the weight, etc . . . But it's been very usefull over the years for testing relative impacts of mods.
From the Gtech data that's been gathered it appears the remap is acting similar to the JBD at ~65% but with better EGT's and IAT's and lower peak rail pressures. The remap with JBD at 0% is similar to the JBD at the max before it throws a limp mode.
Oh, and the owners reported hand calculated mileage for the last two fillups with the remap covering ~300+ mls, including all these full fueling runs, has averaged 39.2 mpg. This is at least 5% better than pre map for similar driving conditions.
Old 06-04-2012, 02:35 PM
Here's an example of the remap boost response. The BT sample rate is only about once per second. The "torque" value is from the ECU "Internally Calculated Torque". This is included to show when the full fueling hits. So somewhere between 1787 and 2251 rpm's (that's the limit on the time step resolution for the BT data) the boost is already at its max value.
If Evolve would like all this info removed it will be done. However this type of data would seem to be valuable for an informed decision . . .
Old 06-05-2012, 10:07 AM
Originally Posted by TDIwyse View Post
One of the plots didn't upload . . . this is the time of the main injection pulse * the injection angel (start of injection). Kind of a way to show the impact of increased duration and timing. Since the JBD fools the ECM into making more pressure, for those situations where the JBD is utilized, for the same injector opening duration, more fuel goes in due to the rail being at higher pressures.
So being new to diesel tuning, I'm assuming injection angle references crank position and by beginning injection earlier is not only adding fuel by increasing duty cycle but, it is also similar to adding ignition timing in a gasoline motor, right?
My next question is do we know if the ECU has some type of detonation protection that retards injection timing like a gas car would pull ignition timing if something were to see ridiculously high loads or something go wrong?
Old 06-05-2012, 02:46 PM
This place has some good info on tuning turbo direct injected engines and what's involved. It goes into injection timing, boost, EGT's, etc.
http://www.myturbodiesel.com/1000q/T...-chip-tune.htm
Yes, the injection angle data is for the "main" injection event. Up to a point, increasing the start of injection can improve thermal efficiency, power, at the expense of some emissions like NOx.
The car actually has 5 injections it uses. 2 "pre" injections, 1 "main", and 2 "post" events. The "pre" injections tend to fall off and stop at higher rpm's. The "post" events seem to mainly be used for DPF regens to maintain the correct temp in the burn-off. Interestingly I was once driving my car in a heavy downpour on the interstate when it tried to execute a DPF regen. Based on watching the EGR rate and instantaneous mpg gauge it was unable to do it correctly and kept trying for over an over until I reached my destination. Next time it got drove the weather was dry and it immediately went into regen mode and completed successfully. Worst mpg tank by far. This is something to consider if people start venturing into water injection stuff . . .
Old 06-27-2012, 07:54 PM
Some interesting data collected today on a local 335d with an Evolve remap stacked with JBD on 0 and post IC/pre IAT water/methanol injection. Temps were 98F and ~41% Relative Humidity. Setup utilized a 200psi pump, 550ml/min nozzle, -20F washer fluid (~30% Methanol/70% water), and a Snow 0-5V MAF based controller fed with the MAP sensor. The Map sensor puts out ~1-5V based on intake pressure so the injection response is boost-based, even though it‘s using a MAF controller.
Very significant impact to intake temps during full fuel runs, as well as significantly reduced temp recovery time post runs. Also good impact to HP based on OBD acceleration data and Gtech results (will try to post Gtech plots tomorrow). Max EGT’s measured were 544C with and 537F without injection. Still well below temps seen during DPF regens.
Old 06-28-2012, 05:22 AM
Here's the plots. Was careful at low rpm's and didn't start full fuel until just above 2k on the rpm's. Kind of neat how around the same rpm point that the IAT's in the plots above start to diverge (injection starts), so too the HP diverges. Not a substantially higher amount of HP at these settings, but a lot more area under the curve.
From the looks of the recorded data at these hot conditions, and the safe readings on the EGT's, DPF pressures, etc. it looks like there's more room. . .
Old 06-28-2012, 11:13 AM
Mein Auto: Turbo M3
thats some good data you have there. these cars really get heat soaked bad when on the track or back to back runs. This would yield a huge improvement in those areas.
///Andres
Old 07-08-2012, 01:48 PM
There was time spent today fine tuning the controller settings. Turns out the MAP sensor voltage output range is peaking at ~3.3V with the remap. So the controller was adjusted for its “max” setting to be closer to this value instead of the 4.5V it was initially set at. Also increased the “start” point to closer to ~2.6V so it doesn’t inject unless the vehicle is really being pushed. This may be reduced a bit pending further data.
Attached is a comparison of the “new” vs. “initial” settings in regards to post intercooler “boosted air intake” temps and EGT’s for the same Remap/JBD 0% stack. Care was again exercised to avoid full fueling at low rpm’s.
The 90F temps today were not quite as hot as the 98F day’s data (~4.5 deg C lower) but the impact to IAT’s and EGT’s is quantifiably substantial with the additional injection at higher boost levels. In fact the IAT’s with the new setting are seen to actually be reduced to just below the starting value during the pull, and are kept to within 2C of the starting temps at 4200 rpm where the peak hp of the engine is typically found. Also the EGT’s are substantially lowered at this rpm point from 503 to 477 ( 937.4 F to 890.6 F).
The owner also put a switch in play so the injection can be disabled during DPF regens.
On a separate note, looking into ways to minimize low rpm torque but extend high rpm torque of the stack. Think there might be a way. It would involve making an RPM variable resistor to use instead of the manual potentiometer on the JBD. It would involve using a Freq to Voltage converter (something like this: https://www.national.com/ds/LM/LM2907.pdf) where one takes the tach signal (lower right pin on the OBD port has a beautiful tach signal) converting this to voltage that adjusts the variable resistor in the JBD (something like this: http://www.vishay.com/docs/70598/70598.pdf). And all of a sudden one gets the ability to add in the JBD rail pressure increase that is a function of rpm which would reduce the problem of too much low end torque. The circuit to be setup so at rpm’s below ~3k nothing above JBD at 0% is utilized, and then from 3k to ~4.5k the JBD distortion increases to the final desired level. The distortion adds to the remap only above ~3k and at increasing values to compensate for the torque roll-off. Now we have a torque curve that is essentially flat out to nearly 4.5k and could stay at/below the ~700Nm/520 lb-ft rating of the tranny.
Also including some pics of the place in the pipe the probe is located and how it fits in the chassis. It‘s tight in there . . .
ID:	332136   Click image for larger version
ID:	332137   Click image for larger version
ID:	332138   Click image for larger version
Old 07-13-2012, 01:20 PM
TurboEddie TurboEddie is offline
Mein Auto: 2011 335d
TDIwyse,
I am actually doing what you are talking about now and am installing my water meth kit starting this weekend. What I did is used an AEM FIC to intercept the TPS, Rail pressure, Boost and MAF sensors, I have RPM as well. I can control the water meth pump and nozzle solenoid using RPM and boost pressure. I understand your concerns with too much torque in the lower rpms. It’s also my goal to limit the torque down low but get as much power/torque as I can in the upper RPM. Using the AEM, I have been able to fine tune the fuel pressure to push the power as much as I can for all RPM and loads while not getting knocks or any codes. FYI, max rail pressure you can push is 1800bar or 4.5v from the rail sensor. Anything over that and the rail bypass valve returns it to the tank. Great work!!!
-Ed
Old 07-15-2012, 08:40 AM
Originally Posted by TurboEddie View Post
TDIwyse,
-Ed
Thanks.
And I really like your approach with the AEM FIC and enjoyed your thread. Also appreciate you sharing results with the community. Please keep sharing!
The OBD pin 9 tach output to voltage circuit is made and verified its performance (Voltage out to RPM). Hoping to interface with the JBD this afternoon. It will linearly increase the JBD from 0 to 70% from 2500 rpm to 4100 rpm. Depending upon measured data the top end can be increased further.
Old 07-15-2012, 03:00 PM
Actually only needed one IC and a bunch of R's and C's.
The LM2917 version with the op-amp and npn work for the "variable resistor".
Will try to get some GTech data from the above car soon.
Old 07-16-2012, 04:33 AM
Comparison of Evolve/7030H2O/progressive JBD with post #60 data with JBD fixed at 0%. The progressive JBD mod data looked good so the top end was increased. This run was with the top end set to ~90% on the total JBD capability. Also, this new data was on a heat soaked vehicle with multiple full fuel runs on it in ~91F humid ambient conditions. The owner wasn't being very cautious with low rpm full applications for the new runs to test the low rpm torque curve characteristics.
The mod definitely helps extend the top end torque/hp and gives more area under the curve. Also helps minimizes peak low rpm torque for non-careful applications of fuel (see post #27 for example where normal peak torque for 3rd gear pulls occurred ~2100 rpm ).
Old 08-30-2012, 03:11 PM
Some interesting data regarding pre/post EGR recal data for differences in EGR Duty Cycle and exhaust gas temps for my drive to work. There's a big difference in these characteristics. Not sure I like the extra EGR utilization to increase average DPF temps. Thought perhaps the recall added some post injection to increase DPF temps, but it appears it's just more EGR . . .
ID:	339656   Click image for larger version
Old 08-30-2012, 04:19 PM
KeithS KeithS is offline
Mein Auto: '11 335d, '00 540iT
As you suggest the elevated temperatures may not be only from EGR. Looks like the EGR is being operated more like an on/off device instead of modulating. This would be one way of reducing the soot build up as I would expect build up to occur more during the partial opening than full open or full closed.
The elevated temperatures may be by design to reduce fouling of the intake from EGR, not so much for the DPF. I suspect the eleveted temps are from late power cycle fuel addition, which could be a cause of the reduced economy some are experiencing.
Regardless, very interesting for us engineer types.
Old 08-30-2012, 04:38 PM
The EGR goes to 0 under certain conditions like costing in gear or full fuel situations or during DPF regen events. The data points with 0 EGR Duty cycle in the above plots are for coasting are heavy acceleration situations.
The 2 "Post Injection" events have the same behavior pre and post recal. Once the coolant temp hits 140F they end, except for DPF regen events when they are used to maintain DPF temps sufficient to regen.
The only major differences I see in the data pre/post recal is heavier utilization of EGR and slightly increased DPF temps. I really wished they didn't increase the EGR utilization. That's a major cause of intake carbon buildup.
Old 08-30-2012, 04:47 PM
That's what is most puzzling. The EGR recall was due to soot/fouling. As I was trying to say before, possibly keeping the EGR flow rates and temperatures up reduces fouling.
Old 08-31-2012, 05:18 AM
It is puzzling. I don't understand why more EGR would help with that issue...
Old 08-31-2012, 06:22 AM
cssnms cssnms is offline
Mein Auto: '11 335d
As far as I know BMW has not come out and said the recall was the result of the carbon build-up problem some are experiencing. I know I speculated that was the case, as have some others, but the evidence seems that you have gathered seems to suggest otherwise.
Old 08-31-2012, 06:54 AM
62Lincoln's Avatar
62Lincoln 62Lincoln is offline
Mein Auto: 335d
When I had my recall performed, I got the SA to print a copy of the Technical Service bulletin for me (not sure if he was supposed to, so no names to protect the innocent). This quote might help the discussion:
"Under certain driving conditions, the High-pressure (HP) EGR valve may become restricted with excessive soot. This restriction impedes the emissions performance of the HP EGR valve."
and
"An optimized EGR valve has been develped to limit this soot buildup."
Interesting that what BMW wrote seems to be contradicted by what TDIwyse is finding.
Old 08-31-2012, 07:02 AM
Mein Auto: '11 335d
and
Good stuff Joseph; first time I've seen something from BMW that specifically states the reason for ther recall. Although I find it interesting they only mention soot build-up as it relates to the EGR valve.
I wonder what impact this partially restricted EGR vavle had on soot build-up in the combustion chamber and more specifically the build-up that some members stated lead to the replacement of the heads in several cars.
Old 08-31-2012, 07:33 AM
I had assumed everyone was aware the soot was the root of the recall, my SA had read me the details of the TB. And they way I figure it, it was those who drove a lot and accumulated lots of mileage quickly, ending up needing a head replacement are the ones that triggered the redesign/recall. I believe the soot just plugged up everything (EGR, Intake and heads). So we can thank these road warriers for preventing the problem from occuring for the rest of us, although at an apparent loss of fuel economy.
I asked the SA about walnut blasting the heads to clean them. He said while that would work, it was still less expensive just to replace, rather than clean the head and intake.
HTML code is Off
