How do you touch up deep paint scratches? - Bimmerfest - BMW Forums
Old 02-02-2012, 10:31 AM
ashevillez3 ashevillez3 is offline
Mein Auto: 2000 Z3 2.8 Roadster
My girlfriend's Z3 has some rather large paint scratches/chips. At one time she put a regular tarp over the car with bungee cords which scratched the car pretty good. The car is black. I'm thinking I'd like to get some oem touch-up paint and fill the deep scratches. Never done this. Anyone have any success performing this? If so, can you share any tips or tricks to touching up deep scratches?
Jim
Old 02-02-2012, 12:22 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Jim
Touch up paint will probably be very noticeable. Wet sanding and repainting would be the cleanest option if a compound polish won't remove them (doubtful if you can feel them with your fingernail). Do you have any photos?
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 02-02-2012, 12:53 PM
I'll try to post some over the weekend. I was thinking to fill the deep scratches and build the paint up and then wet sand to even out flush with existing paint. The scratches are noticeable but not enough to justify full paint job. Plus, this is her car. I'm already knee deep in restoring an old vette.
Jim
Old 02-02-2012, 02:04 PM
wifesauto wifesauto is online now
Mein Auto: sloporsche
i have removed finger nail scratches with scratch remover products {mothers etc} but i never had success on deep ones. imo touch up paint can make it look worse. if you have a friend in the body shop biz let them try a powered machine to buff it out
Old 02-02-2012, 05:46 PM
Droptop85 Droptop85 is offline
Mein Auto: 03 Z4 3.0i
Depending on how deep they are. Try wet sanding the scratch out. Then use a rubbing compound with a buffer, anti swirl remover, and then a polish.
Old 02-06-2012, 04:33 PM
Artful Dodger Artful Dodger is offline
Mein Auto: Yamaha
If you see it as or call it a chip, then no buffing, rubbing, or sanding will fix it. Use the touch-up paint to protect it from corrosion. If you can't catch the scratch with your fingernail, then you may be able to buff it out.
Old 02-06-2012, 05:35 PM
WINDonSKIN's Avatar
WINDonSKIN WINDonSKIN is offline
Mein Auto: s54 roadster
Jim, scroll down to detail dept. There's a great write up on your question. I had a pretty deep scratch on my trunk when I bought the car and that article really helped me. Having a black car also I have to look pretty hard to see it. Good luck
God is my pilot - just hold on
Old 02-06-2012, 06:15 PM
tohbi tohbi is offline
Mein Auto: z3 '97 atlanta blue 2.8
i'm not sure if bmw is using the flat paint/clearcoat technique. it seems that's what manufacturers have gone to. if so, buffing can go thru the clearcoat to flat color, leaving a noticeable dull spot.
if you're going to buff, compound or use polishing abrasive, you may find it necessary to clearcoat afterward.
Old 02-08-2012, 06:50 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Watching the factory techs do this at Homecoming, they used standard touch up paint, but used a high quality, VERY thin paint brush. Try craft stores or hobby shops.
Then they filled the chip, ONLY in the chip, in layers until they built it up higher than teh surrounding paint. Then they buffed with compound.
Other have said good things about the Langka system.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 02-09-2012, 07:32 AM
dadmog dadmog is offline
Mein Auto: 98 MZ3
Have had good luck with the Dr Colorchip, but nothing real deep yet. Worked better for me than the Langka.
