Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 04-22-2012, 10:16 AM
leejak leejak is offline
Mein Auto: 2012 640 ED, 2011 M3,
Rear Fog Lights
Does any know if the E92 M3 have built-in rear fogs as the E92's seem to have?.....E92ers have discovered that they have rear fogs, but no switch because BMW does not provide this choice in US spec cars, but by simply hacking the switch, they have rear fogs...is this the same for the e92 M3 despite no front fogs?....just curious....
Old 04-22-2012, 11:32 AM
kscarrol's Avatar
kscarrol kscarrol is offline
Mein Auto: 2011 E90 M3 + 1997 Z3 2.8
It is, have seen threads on other forums with a DIY on activating the rear fogs for US spec cars...
Edit: Here you go... http://www.bimmerfest.com/forums/sho...light=rear+fog
Old 04-22-2012, 04:09 PM
rdollie rdollie is offline
Mein Auto: Mostly Euro sedans
Do yourself a favor and do it right. You should only activate the fog light on the driver's side of the car. The reason why Volvos, Saabs, Benzes, etc. came with a single operating fog light was due to some safety research I read many years ago. I don't remember all the specifics but essentially what it showed was when someone runs up on you in bad weather and needs to swerve to avoid you (and really this is the only value of a rear fog light because if the person behind you can make out your tail lights already the fog doesn't add anything) they will pull to the inside of the single fog light (the presumption is that you have road on that side.) Two fog lights negates the effect (probably increases the odds you get rear-ended but I don't have the study handy to verify.) Euro manufacturers have two lights back there due to different side drive configurations but they only activate one light. I remember several years ago a premium Japanese or American (can't remember which) was proud of their dual rear fog lights (Speculation was they felt they were one-upping the competition by adding more content... )
Old 05-23-2012, 10:26 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK/335d
Yes, you can do the fog light mod on an M car. N4S
