Old 02-02-2012, 09:38 PM
JPEG23 JPEG23 is offline
Mein Auto: E63
Error code: camshaft position actuator timing over-advanced...most likely culprit
Anyone?
6 series - Sapphire Black w/ 22" Beyern Mesh wheels
Old 02-02-2012, 10:57 PM
Mein Auto: E63
Solenoid or cps?
Sent from my HTC Glacier using Bimmer
Old 03-02-2012, 08:15 PM
Jtodd4594 Jtodd4594 is offline
Mein Auto: Bmw 650
Replaced module today killed me on labor 603 part 123
Old 03-05-2012, 06:44 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
You might try replacing your camshaft position sensor, it shouldn't be too expensive, nor difficult.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 08-02-2012, 06:11 PM
mustoboy mustoboy is offline
Mein Auto: 2004 bmw 745il
Hello
where is the camshaft possition actulactor located on a 2004 745li, I have 2 codes 0103 - 001
THANK YOU
Old 08-03-2012, 09:24 AM
petriej's Avatar
Probably similar location to my old 6er.
Sorry, this was for crankshaft, not camshaft.
http://www.bimmerfest.com/forums/sho...d.php?t=512974
GGC BMW CCA #443004
Join the BMW CCA!
Old 08-04-2012, 04:07 AM
645/333's Avatar
645/333 645/333 is online now
Michael
Mein Auto: BMW 640i SE Convertible
Hi! 645 and 745 are the same engine!!! so it will naturally be in the same location
Always said I would go back to a 6 series
Old 08-04-2012, 06:09 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
Originally Posted by mustoboy View Post
Hello
THANK YOU
CPS is an easy job and a typical failure at your cars age. NIKE (just do it)
By code 0103 I guess you mean P0103? That is a MAF (Mass Air Flow) sensor error. Did you change your air filter lately? Maybe you yanked on it? Check the connection to the MAF (sensor right next to the air filter box) and you may want to consider getting some MAF cleaner from the local auto parts store. A new MAF is very expensive compared to the cleaner. Takes 5 minutes. Two hex screws, pull it out, spray and replace.
As far as the 001 code, I'm not sure what you mean. P0001? I couldn't find that code for our cars.
'07 650i Coupe - Black Sapphire Metallic
M6 bumpers, skirts & wheels
BMW M Cross Spoke Composite 101 Rims 20"
HUD, Comfort Access
Old 08-04-2012, 08:04 AM
Hello 645/333
thank you for your help, Ill give it a try
Thank you
