Coolant Smell - Bimmerfest - BMW Forums
Old 02-14-2013, 05:46 PM
10Go 10Go is offline
Welcomed to the 'Fest
Mein Auto: E65 745i
Coolant Smell
While at idle or at a light I can smell coolant. I light smell. Its almost like something is hot. I have checked for leaks in the front around the main hose. The only thing I visibly see is dried coolant around the reservoir.
Any advice is welcomed. I'm starting to feel so paranoid about my 7 now. It hasn't been two years with it yet.
Regards,
Ten
745I
Slate Green Metallic___
Old 02-14-2013, 06:59 PM
Ultimate745i Ultimate745i is offline
Ultimate745i
Mein Auto: 2004 745i
Yes the Reservoir is a common leak. Mine was cracked right below the small hose going to top of radiator so it was hard to
figure out where it was. it's a very easy DIY repair and the reservoir itself was under $50. Look here for excellent OEM pricing:
http://www.rockauto.com/
Fun Doesnt Come Cheap!
Old 02-14-2013, 07:22 PM
Mein Auto: E65 745i
Thanks.
If I were looking for that "weep hole" leak, where would I look?
Regards,
Ten
745I
Old 02-14-2013, 07:28 PM
Ultimate745i
coolant would primarily be on the passenger side of engine underneath.
You would probably see evidence of it right around your a/c compressor area.
Should be a pretty steady leak. (under hood, facing engine it would be to your bottom left side.)
If you have coolant leaking "high" on the engine, it's probably not the "weeping leak".
Old 02-14-2013, 07:32 PM
Ultimate745i
Take a flashlight and check around the reservoir area. The only other main leak would be the water pump which would be the very top pulley wheel on the left side of engine.
Old 02-15-2013, 06:49 AM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
BMW cologne.
Old 02-15-2013, 07:33 AM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 328GT/740LI/750LI
If you remove the 6 bolts on the engine cover there is a little "T" valve in front of the throttle body check there an make sure its not leaking also.
13 740LI W/Msport package. Executive Package
DRIVER ASSISTANCE PKG, HUD,
OYSTER; NAPPA LEATHER SEAT TRIM,
Lane departure, blind spot detection,
Collision Mitigation,
Side & Top View Cameras
Aftermarket Rear entertainment
