Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 02-05-2012, 04:53 PM
BMW645 Germany BMW645 Germany is offline
Mein Auto: BMW645 CI
Question Belt Drive Belt tensioner Climate Compressor missing
Hello,
I want to change all the belt of my car because of 72000 milage and preventive maintenance.
By this way I found out that the belt tensioner for the climate compressor is missing.
It is a second hand car and I don't know what the pre owner did. When I look at the mounting point for the tensioner, then it look like that there was never a bolt in.
I dont know how they got the belt on.
So it look like that I have to buy the tensioner,
Old 02-05-2012, 08:26 PM
Yorgi's Avatar
Yorgi Yorgi is offline
I am pretty sure there is no tensioner on the A/C compressor belt.
This thread has a .PDF with the instructions for both belts.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 02-06-2012, 05:52 AM
Thanks for the link, when I look to the second pdf down the last picture I can see the belt tensioner, maybe for the model later they installed it.
Old 02-08-2012, 08:25 PM
Yorgi's Avatar
I think BMW re-uses pictures from different cars in the TIS. The first and second PDF look like completely different motors. Maybe send brown370 a PM since it looks like he has changed these belts a few times.
'04 M3 - track
Old 02-16-2012, 01:00 AM
brown370 brown370 is offline
Big Mike Brown
Send a message via AIM to brown370
Mein Auto: 07 BMW X5 4.8i
The V-Belts has a tensioner and the A/C Compressor does not. You have to pull the belt off with a rag while turning the crank. You have to use a special tool to stretch the new belt on.
11 Audi A5 2.0T 8 Spd Tripotronic w Sport Pkg, 19" Anthracite Wheels
12 VW CC 2.0T [/B] stock
05 VW GTI 1.8 T 5 Spd, Coilovers, Big Brakes,
(Previous rides)
04 BMW 645 CiC Auto
97 VW Jetta Jazz 5 SPD
06 Mazda 6 Grand Sport Auto
05 BMW X5 3.0 6 SPD
05 Infiniti G35 6 SPD
04 Volvo S60 "R" 6 SPD
99 Nissan Maxima 5 SPD
91 Nissan 300ZX 5 SPD
92 Honda Prelude Si Auto
76 Fiat Spyder 124 5 SPD
Old 02-16-2012, 01:16 AM
Big Mike Brown
You will need a sepentine belt tool w/ a large Torx socket T-55. To remove the sepentine belt first (lest than 10 minutes) Take a picture of the belt before removing it so you know how it goes back on.
Jack up the car and remove the front underbody cover. You use a towel to remove the A/C compressor belt while turning the crank/engine. One you remove the old A/C belt, put the new belt over the crank first, and then install it on the bottom of the A/C compressor and install the tool pictured on the A/C compressor pulley. Turn the crank clockwise keeping the belt tight and the tool will pop the belt on. I had to do it twice because the belt ribs did not line up the first time.
Name:	BMW Tool 2.jpg
(Previous rides)
04 BMW 645 CiC Auto
05 BMW X5 3.0 6 SPD
Old 02-16-2012, 11:31 AM
Thanks for the help, I postpone it in the moment. After changin of the O-Ring for the temp-sensor and changing of transmission oil, I need a rest. :-) Will do that then later, but it i slik u wrote.
Old 05-11-2012, 06:14 PM
abercrombie1958 abercrombie1958 is offline
abercrombie1958
Mein Auto: 2006 bmw 650i cn e64
no tensioner 06?
my 06 650 is missing the a/c belt and tensioner,along with part of the upper oil pan,did the 06 have a tensioner?
Old 08-17-2012, 06:20 PM
daf290 daf290 is offline
Mein Auto: 2007 650 I
AC belt install tool
I am fighting installation of the AC belt. I made a tool to hold the belt and turn the crank over similar to the tool shown in the prior post. Even with my home made tool I am having difficulty.
I need to break down and buy the proper BMW tool to install the AC belt. I cannot find the part number for the AC belt installation tool.
Does anyone know the part number for this tool or where to find it?
Old 08-17-2012, 06:31 PM
Found Part number
Sorry, I found the part number of 64 1 040 but I cannot see any of the online suppliers that list this part number. I guess I may need to try to special order.
Old 10-16-2012, 11:52 PM
mr bm ac6 mr bm ac6 is offline
Mein Auto: 06 bmw 650 coupe
climate tensioner
i had the same problem bro my climate belt cut while driveing i took it to a random independent shop to replace the belt the mechanic told me my tenssioner is misssing but i took it to bmw technition he told me that this cars dont have tenssioner but not any mechanic can replace it the mechanic needs to have this special tool to install the belt so so if i were you ide take it to a bmw specialist shop
Old 10-16-2012, 11:55 PM
does anyone know why my dynamick drive malfunction light is on and how can i fix this problem
