Old 02-06-2012, 07:44 PM
CathysDome CathysDome is offline
CathysDome
Mein Auto: 2002 Z3 BMW Convertable
Red face My 2002 Z3 stalls at every stop... :(
Hello, this the first message I have sent, but I have really enjoyed reading everyone elses. My baby car stalls at every stop sign or red light! If I turn the AC off and riv the motor up, it will usually start running right, until the next stop. Some people think im trying to race them, but im just trying to keep it cranked. Has anyone else had this problem? My son has tried several things, but it's still acting up. Someone said it might be the gas cap. I'm going to order one tonight and see if it helps? Any ideas would be Greatly Appreciated. Thanks.... Cathy in Georgia
Old 02-06-2012, 08:12 PM
alandelucia alandelucia is offline
Mein Auto: 2003 Z4 3.0i
Do you have any warning lights on "Service engine soon", etc...?
Old 02-06-2012, 08:49 PM
brianrparker brianrparker is offline
Mein Auto: 1997 BMW z3
Check anything that has to do with idle and oxygen. throttle Body, air intake, O2 sensor. that kinda stuff.
Old 02-06-2012, 09:27 PM
Reptor Reptor is offline
Does your car idle after you start it and before you drive? Does the AC on and off make a difference?
Is it a standard or automatic transmission?
Z4 3.0I Sterling Gray Metallic/Dream Red
Old 02-06-2012, 09:28 PM
CathysDome
Thanks for your replys. There are no warning lights. I will have these things checked out, thanks so much. Cathy
Old 02-06-2012, 09:35 PM
CathysDome
Hello.....It's a standard stick. Yes, it idles when I start it and before I drive. Yes, if the AC is on, it will shut off at every stop, unless I turn off the AC before I get to my stop and push down on the gas. Thanks for your help.... Cathy
Old 02-07-2012, 04:31 PM
nfunk nfunk is offline
1998 BMW Z3 2.8L
Mein Auto: 1998 BMW Z3 2.8L
I would check all vacuum hoses to make sure there are no leaks and properly connected.
Old 02-08-2012, 05:38 AM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
It could be a a vacuum leak from any number of places. It could be a faulty idle air control valve:
http://pelicanparts.com/bmw/techarti...leshooting.htm
or a faulty VANOS: http://www.beisansystems.com/faq.html
There may be even more possible causes. It's going to take some troubleshooting, but none of these problems are too hard to fix. The VANOS will be a few hundred dollars in labor.
2002 z3, stalling
