E36 (1991 - 1999)
Old 02-07-2012, 10:09 PM
bmwspecialist bmwspecialist is offline
Mein Auto: e36
1995 e36 1.8l auto
Having an issue rev limits at 3000 rpm in drive or parked anyone encountered this in the past? ? Throws a code for cam sensor but its been replaced
Sent from my DROIDX using Bimmer App
Old 02-08-2012, 05:03 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Throttle position sensor changed too? Both are supposed to be changed at the same time.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 02-08-2012, 10:04 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Really? I've never heard the TPS should be changed when replacing the cam and/or crank position sensors. I didn't on Bebe when her CPS died, but I did replace the cam PS since I was "in the neighborhood" and figured it was a good idea. 5k miles later she's still purring.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 02-10-2012, 08:38 PM
Mein Auto: e36
I replaced dme, tps throttle body cam sensor crank sensor knock sensors plugs wires fuel pump injectors fuel pressure regulator fuel filter but the dme is cutting the pulse what controls the injector pulse????
Old 02-10-2012, 10:03 PM
D'oh, You Kids!
The cam and crank position sensors feed the position data to the DME, which controls both the ignition pulses and fuel injector pulses. If it's chopping the ignition pulses, you still have problems with one of the three. New parts, or stuff from the wrecking yard?
Quotes to live by:
BMW-CCA #441426
Old 02-10-2012, 10:06 PM
Mein Auto: e36
Then its probably the crank position sensor cuz now that remember the crank was not replaced only the cam sensor and dme and the problem persisted I will replace tomorrow and repost
Old 02-10-2012, 10:07 PM
Mein Auto: e36
Btw my boss didn't wanna invest more money into the car so he gave it to me
Old 02-10-2012, 10:10 PM
D'oh, You Kids!
Good luck. I would always replace both position sensors at the same time, since it's so much more convenient to do both at once, rather than tearing the thing down again if the first one replaced doesn't fix the problem. Sensors are cheaper than my time.
Quotes to live by:
BMW-CCA #441426
Old 02-10-2012, 10:12 PM
Mein Auto: e36
But the cam sensor was replace because it was throwing a code for that one
Old 02-10-2012, 10:26 PM
D'oh, You Kids!
When the cam sensor went out on my 318 (and I mean WENT...it died right in the street) it never threw a code, but tested bad. The cranks sensor tested bad, too! The only code stored was for a broken knock sensor.
Quotes to live by:
BMW-CCA #441426
Old 02-10-2012, 10:30 PM
Mein Auto: e36
I had the same thing I only had codes for knock sensors but I will replace the cam sensor tomorrow for sure I hope that's the problem
Mein Auto: e36
But the car never died
Old 02-15-2012, 10:24 PM
Mein Auto: e36
Crank sensor it was
Old 02-15-2012, 10:44 PM
D'oh, You Kids!
Quotes to live by:
BMW-CCA #441426
