Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 02-07-2012, 11:45 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: 745LI
Info on recoding a used key & remote inside's
I decided to open up a used key I bought .
I will post pics to show you a common
problem with some of your buttons
not working . I will also point out the chip
you need to change so you can have the
key / remote Re-Coded for your car .
1st pic - button that broke loose from sauder .
2nd pic - spot button belongs
3rd & 4th pic - housing
5th pic - chip you need to replace so you can have a used key Re-Coded
Sent from my GT-I9100 using Bimmer App
ID:	311491   Click image for larger version
ID:	311492   Click image for larger version
ID:	311493   Click image for larger version
ID:	311494   Click image for larger version
If you need a Custom 2013 DVD Navigation Map
East or West for your E65 E66 PM me for price .
Or if you Need an AUX Plug for your car hit me up
Old 02-07-2012, 11:55 PM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
I'll post the chip # in the morning when I check my notes
Old 02-08-2012, 04:00 AM
mortyx10 mortyx10 is offline
Mein Auto: 745i
I opened mine couple months ago to change the battery...just wanted to mention that no initialization is required after changing the battery....worked straight away.
Old 02-08-2012, 06:45 AM
HerbP HerbP is online now
I was not aware that this could be done? This should be added to the DIY!
Old 02-08-2012, 06:53 AM
Blackbox760 Blackbox760 is offline
Mein Auto: 2003 E66 760Li
wow very good find, how are you going to program the key? and will you be able to program it as key #1 again?
Old 02-08-2012, 01:27 PM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
HERE IS A LINK TO A NEW BLANK CHIP .
http://www.ebay.com/itm/Philips-PCF7...item4ab317907c
Old 02-08-2012, 01:33 PM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
i DON'T HAVE THE PROGRAM OR HARDWARE NEEDED , SO I WON'T BE PROGRAMMING IT .
BUT IF YOU KNOW SOME 1 THAT HAS THE GT1 UNIT I WAS TOLD IT COMES WITH
THE HARDWARE ( KEY HOLDER ) NEEDED . I HAVE ALREADY TALK TO SOME 1 HERE IN L.A.
THAT CAN PROGRAM THE KEYS .& HE SAID HE THINKS HE CAN ADD IT AS KEY 1 .
HERE IS ANOTHER LINK TO A COMPLETE KEY NEW FOR $74.99
http://originalkeyless.com/2005-BMW-...5.qscstrfrnt04
Old 02-08-2012, 01:58 PM
thanx
Old 02-09-2012, 10:48 AM
Kause187 Kause187 is offline
Mein Auto: 2004 745Li
Im in the LA area as well, let me know if he can program the key for you, also- Do i need to buy the key transponder as well, or the second link to the bmw key itself is good enough ?
Old 02-09-2012, 03:12 PM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
Originally Posted by kause187 View Post
im in the la area as well, let me know if he can program the key for you, also- do i need to buy the key transponder as well, or the second link to the bmw key itself is good enough ?
you can just buy the key in the second link .
I am not getting any key's made , i was just
looking into the possibilities of re-coding
a used key . The guy who i have talked to
has done several new key's for a friend .
So im sure he can still do a key for you .
Old 03-12-2012, 08:33 PM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
Bump for those PM'ing me !!!
Old 03-13-2012, 07:35 AM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
BUMP !!!
Old 05-12-2012, 10:46 PM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
Old 05-13-2012, 03:52 AM
***CCCP***'s Avatar
***CCCP*** ***CCCP*** is online now
Major
Mein Auto: 745 li
Thank god i have 3 sets of key fobs
Old 05-13-2012, 09:55 PM
optirobk optirobk is offline
Rob
Mein Auto: 2003 745Li
I need a spare key made and have my original key fixed. The unlock button does not work. It feels like a broken piece underneath the actual unlock button. Can you send me the contact information for your buddy who could/would make a replacement? Thanks for your help!
Old 07-21-2012, 11:15 PM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
Old 07-22-2012, 12:05 AM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 745LI/ F02
Great Find Paper!
Old 07-22-2012, 12:20 AM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
Originally Posted by rookie2008 View Post
great find paper!
this isn't something i found !!!
I figured it out myself & took
apart a used key i have .
I did the same for a friend & he went
& had it coded to his car .
Old 07-22-2012, 12:21 AM
Rookie2008's Avatar
My fault. Great Fix bro!
Old 07-22-2012, 08:09 AM
sirstopher's Avatar
sirstopher sirstopher is offline
bimmerfest Supporting Member
Mein Auto: POS Honda
Do you want me to move this to the DIY section.
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 07-22-2012, 09:32 AM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
Yes , thank you
Sent from my GT-N7000 using Bimmer App
Old 09-14-2012, 05:10 PM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
Bump for that person who for some reason
couldn't find the topic in the DIY section & pm'ed me !!!
HTML code is Off
