BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great! |
Speedometer calibration
While on a recent trip to West Texas, traveling along with another car, we discussed how fast we were driving and my buddy following me said that I was driving 3-4 mph slower than my speedometer was indicating. In other words, at 80 mph indicated, i was actually traveling at 76 mph.
I thought maybe it was his speedometer that was off some, but after verifying with a very accurate GPS, on a long straight stretch of roadway, our 335d was in fact running about 4-5 miles per hour slower than indicated. Being a stickler for accuracy, I want my speedometer to read exactly how fast I am traveling and don't want to have to constantly make a mental adjustment. Can anyone tell me what could be causing this, and more importantly, can it be easily corrected? I know it's not caused by the tire size because I am running the same size and type of tires that came originally on the car, which is a 2010 model. Thanks for any help! Last edited by Runnerman2; 02-08-2012 at 03:13 PM. |
I think I read some previous threads on this which indicated that BMW deliberately sets the car in this fashion. Try searching and you may find some info on a fix.
It's the way it is because of an intersection of US/CA/EU laws & regulations: has to read fast, etc. There is no way to get it changed. If you have iDrive, you can somehow get the actual instantaneous readout in digital form, I believe. |
Here is the one I was thinking of. http://www.bimmerfest.com/forums/sho...d.php?t=579643
All BMW's are 3mph fast.....when indicating 65mph, you're really doing 62. I've verified mine with GPS and radar.
Previous BMW's: '79 530i, '93 325iC, '97 740i, '99 540i, '00 M5, '03 X5, '05 645i, '09 335d, '11 335d |
http://forums.bimmerforums.com/forum...1266637&page=2
Has the service bulletin text. |
My speedometer ran about 3-4 mph fast.I've read that it's because there's a German (or European) law which heavily fines a car maker which builds a car featuring a speedometer that's even a tiny bit slow so,to avoid the fines,they deliberately set them a bit fast.
Currently:2011 MB E350 Bluetec / Palladium Silver / Nav / Active Cruise / HarmonKardon Logic7 Formerly:2009 335d / Monaco Blue / Beige Leather / Nav / iDrive / Xenon / Sirius / HD Radio
Runnerman2: Same here for my 335d...seems to be off 3-4 mph, but in my testing it seems the odometer is pretty much dead on. If you change your tire diameter, then you will mostly likely throw the odometer off( in your favor, for once).
Thanks guys for all the input! Sounds like I will just need to keep the difference in indicated vs. actual speed in mind in the future. We do have iDrive, but haven't looked at that to see if there's a way to show current speed all the time on the screen. May be a possibility as well.
Sent from my MB525 using Bimmer App |
For example, if the speed limit says "55" I set my cruise control to "65", then bump it down one MPH. That is really close to the maximum legal speed. If you are feeling particularly feisty you could leave it at 10 MPH above the speed limit. |
I just tend to always speed and if my radar detector goes off then I hit the brakes to whatever point on the speedo is the speed limit. I am not going to worry about if I am truly doing something like 77 in a 65 instead of what I think is 80 in a 65.
--Aaron |
What really bugged me was on the West Texas run I mentioned, set it on 120 for about 40 miles (wide open spaces, you know). Just kills me to know now that I was "only" going 116. Will have to go back and do it again.
On a non sport 335d, go to 245/45 - 17 and your speedo will be very close to dead on. Your odometer will be about 3% under.
Now comes the question: Are the front wheels or the rear wheels driving the speedometer/odometer? I suspect the rear wheels as Odometer is usually driven off the Transmission, but since I changed tires my indicated speed seems to be closer to my GPS. |
Regarding swapping to a different size tire, thanks for the suggestions. But having just purchased a new set of "non-run-flats", that's not an option for at least another few thousand miles. I'll just live with knowing there's a difference in actual vs indicated speed. Thanks all!
That would help explain Flyingman's observation. |
But explains why I'm seeing a slight closing of the gap between indicated and actual.So why would speedometer and odometer read different? i.e. if I go down the highway at 60mph and the odometer says I actually did 63 miles in an hour. My OBC is notorious for saying my mpg is around 27-28mpg but when I calculate my actual fuel consumed vs miles driven (odometer), I always get the fuelly value below, which is some 1-1.5mpg better. ![]() Regardless, after over two years and some 34k miles, my smiles/miles are still up there! |
The easiest comparison which is accurate is to borrow someone's portable GPS unit and use it's speed measurement. GPS speeds are typically extremely accurate.
To a certain extend the ECM does not have to really know precisely the absolute volume of fuel it is injecting, as it simply uses feedback from the exhaust gases measurement to adjust the fuel trims to provide the right amount... a little bit like nudging the water faucet a little bit to increase or decrease the flow of water out of the garden hose without actually knowing the precise flow rate. If the "nudging" required to get the correct sensor readings gets to be too great, you get a MIL and an error code for fuel trim out of range or at the limit. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
