E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
hard time starting in colder weather?
hi guys, my 320i is having trouble strating on weather colder the arounf 5 degrees. i have to keep it plugged in just so it would start whenever its cold.. this is prolly not energy efficient. you guys have any idea why would my bimmer not start in colder weathers? my 91' honda does NOT have this problem. starts in one click in -37C.
your reply is appreciated. Thanks joel |
How old is your battery?
Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
bout 2 years.
i have tried with gas line antifreeze but i dont think its the problem since i make sure i go to the last 60 kilometers til empty then i re fuel to the top every single refil. i dont know what else to try. and this is my first bimmer.
how do i make a signature? |
The first thing I'd suggest would be to have your battery load tested for free at any auto parts store. Two years isn't very long for a battery, but a number of factors can determine battery life.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
Its now -10 where i am. I had to boost my car with one of those heavy duty pirtable 3000 peak amps boosters just so i can go home. While i was boosting i noticed the CCA of my battery is only 580.. According to a thread that ijacked here bout CCA its suppose to be 650 for factory.. Can it really make a difference in cca? Its just 70cca difference...please pardon my ignorance...
Does this mean more cca the better? I would imagine more cca means more $$$$? Thanks for your reply. Joel |
Yes, the more CCA, the better. There are two things you should consider with batteries. Those things are A) CCAs, and B) reserve capacity (rated in minutes). Still, I'm surprised that you couldn't start your car with 580 CCAs available.
I tried three times and each try is about 10 second in length... I actually think im gonna fry the starter... Even with the boost on i had to try a few times and pump the gas pedal fully, could this be a fuel pump issue? This only happens when cold and start fine during the summer/fall..
Is the car cranking slower than it should? If it cranks normally, but takes longer to start, you probably have issues that are unrelated to your battery.
After the third time it starts to slow down... I was thinking it might be bdischarging the battery by that time..
Try turning the key on for 5 seconds then off then back on for 5 again repeat a few times before cranking/running the batt down.., This will prime the engine and help with starting...
Wait is your car a hybrid or regular? Your description sounds as if it were a hybrid but I might be wrong. As far as not starting in cold weather check battery first..
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
Hey cmon, my E36 is a hybrid. I mean it gets pretty decent gas mileage and some people think I'm gay for driving one! (pretty silver color, probably)
still having a hard time starting with a new battery with 850 cca and 120 rc. what do you guys think?
![]() OP, just food for thought, you might have a fuel system leak. Your fuel system might not be staying pressurized after you shut the car off for a few hours or a day, so when you go to restart it the car needs to build fuel pressure up again. You can have that tested, that is probably what I would do next.
is testing the fuel pressure something an average person can do? im a building operator by trade, wondering what tools will be needed? i have a copy of a manual as well. a brand new fuel pump cos $400 here so im trying to avoid it if its not what i need.
Try Princess Auto. See if they have a fuel pressure gauge. Failing that just order one from http://www.amazon.com (not .ca, but .com).
Edit: Canadian Tire has one, but it's the Equus one and the basterds want $60 for it.
The Evolution of a Lady Quote:
Member of the Non-M Bumper By Choice Club![]() |
Take a look at Bentley, and search around the internet to see whether fuel pressure leaks for these cars match your symptoms.
Did you try this?
In your first post you mention -37c well thats f ing cold no matter where your from.
whats plugged in a battery charger or a dipstic heater. New battery well lock at your connection at the battery and your starter I'm not sure where your battery is in your 320 I assume its in your trunk try to chase the main wire to the starter check for cracks. Anytime a starter went bad for me it was usually winter. you keep giving us bits and pieces of info does the car run alright after you start??? Is this symtom only in the morning???? or after it sits for awhile Help us help you
All the days you don't drive your BMW you don't get back
Worst case scenario, take it to Sheni's Auto Trend 5306 3 Street Southeast Calgary, AB T2H 1J8
(403) 243-3232.
i did try did it more than you said i should. i even tried pressing the pedal while cranking it. it starts after 6 or 7 times of cranking it and once it starts its good until i get to my work place go to work and i have to remember to start it around 1pm then it starts id say in one crank sometimes 2. in the morning after about 6 or 7 times of trying it the cranking slows down i believe i drained the battery too much and thats where the boosting comes in. boost it and prolly about the 3rd time i try it then it starts.
apologies if im not giving anymore information... i just dont know where to look and the manual the i got dont state how to check the pump.. please let me know what else i should be adding here.. joel |
#25
Could be a gremlin fuel relay, due to extremely cold temps
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
