Old 03-06-2015, 03:10 AM
mareks mareks is offline
Mein Auto: BMW E65
EDITED
For upgrade we need:
* Facelifted display MMI LCI
(if car before - 03.2005)
part number 6582 6960096 and more
* Module TCU 1.5 MOST ECE or TCU EVEREST ECE after 09.2005
* 54-PIN connector and fiber optic 2-PIN connector (cars before 3.2003)
* NCS EXPERT
* TOOL32
FA change
$ 638 - CAR TELEPHONE PROFESSIONAL
or
$ 630 - CAR PHONE WITH CORDLESS RECEIVER
to
$ 633 - PREPARATION, MOBILE PHONE, BUSINESS
My is 12.2002 but I didn't change production date in FA
MMI change
Remove grille by pulling it up and unscrew the 3 bolts on top of display
After replacing you need coding the MMI by NCS Expert
Then make active functions:
ECE_TELEFON --> active
HARDKEY_ASK--> active
TEL_BLUETOOTH --> active
BLUETOOTH_HANDY --> active
Remove the old TCU module and instal TCU 1,5MOST ECE or TCU EVEREST ECE after 09.2005
SIEMENS Module up to 03.2003
TCU module 1.5 MOST ECE (sample photo)
If you have a car between 03.2003 - 09.2005 you only need to replace TCU EVEREST to the TCU 1.5 MOST ECE or TCU EVEREST from cars between 09.2005-03.2007
First 4 from the list
ITS EVEREST AND WORKING!!!
Connectors will be the same, only one little change can be necessary to rework Need to crop the 54-pin connector (red marks on photos)
Before March 2003 with the old module SIEMENS you will need repin two connectors 12-pin and 26-pin to one 54-pin and separate 2-pin fiber optic connector
Best to cut them out from E65 or E60
Replace them in the following way
Connector 12-pin --------------> 54-pin
1 black insulated -------------> 21
4 red & black -----------------> 15
7 white ------------------------> 1
8 brown & white --------------> 19
9 gray -------------------------> 31
10 cream -----------------------> 50
Connector 26-pin --------------> 54-pin
13 red & green ---------------> 17
17 blue & red -----------------> 12
18 red -------------------------> 13
26 brown & black -------------> 36
If you have bought a connector cut from some E65 54-pin cable colors certainly will be the same
Replace cables from connectors 12-pin and 26-pin to 54-pin
fiber connector easily remove out from the 2-pin connector and insert into previously purchased 2-pin cover of connector
COVER PART NUMBER connector 54PIN
BMW 61 13 6 920 068
DICE INTERNAL PARTS NUMBER PIN 1-36
BMW 61 13 6 920 062
DICE INTERNAL PARTS NUMBER PIN 37-54
BMW 61 13 6 920 064
Red marks on photos its place where need to crop connector 54-pin
Below original facelifted E65 LCI connector 54-pin with original cables
Just replace cables from 12-pin and 26-pin connectors to the same colors in 54-pin connector
After replace rest of cables leave with connector. I'm not sure but I think they are from the phone in a drawer
Replaced cables below
That is rest of telephone cables with connector 26pin which you have to hide somewhere
Connect antenna cables by colors of stickers on the module
Bluetooth antenna cream to cream icon on TCU
Black to black
Run Tool32, then File, load SDGB, group file and find TELE60_3.prg enter the VIN with the last character by using the FG_Schreiben function, Start Job Once Only
Code your new module by NCS Expert
BORDNETZ
e65_bordnetz
BACKUP_ANTENNA
nicht_aktiv
BACKUP_LOUDSPEAKER
nicht_aktiv
On display in the SETTINGS choose PHONE option then turn on BLUETOOTH, and then PAIRING
On your phone, the display shows the new device BMW ***** , click, connect
Then the PIN number from the sticker on the TCU module
We have a connection, contacts imported into our car
Done
It's best to raplace telephone out and buy a rubber insert in the drawer like in facelift E65 (less unnecessary deburring)
by the way we gain one more storage
On the module are two additional stickers that sticks in selected locations, like on the door pillar to have easy access to the pin
Old 03-06-2015, 09:25 AM
B11NOV B11NOV is offline
Mein Auto: E65 730D
Is that the actual TCU that you put in your car and giving you problems?
I had the exact same one before, and couldn't get it to work properly, and realised that it's too "new" for the car, had to buy an older one and no more problems.
Old 03-07-2015, 04:31 AM
Mein Auto: BMW E65
Yes that is my TCU
Part number is 9174261 Prod date 07.08.2007
Maybe if i will change FA?...
Old 03-07-2015, 04:54 AM
Mein Auto: E65 730D
Oh sorry, the TCU on your second photo is different, part no. 9224422, that's the one I was talking about.
Also I remember having to change the chassis from E60 which was the original car the unit was fitted to, to E65. Check your trace file.
The car production date was temporary changed to a later date when installing the TCU, just to get the right coding data file. I think mine was changed to 0906, but don't do FA write!
Old 03-07-2015, 12:05 PM
Mein Auto: BMW E65
Chasis E60 was changed to E65 by coding with empty .man so its ok
I will try FA with the same date like in my TCU and then empty .man
Old 03-07-2015, 03:47 PM
Mein Auto: E65 730D
Coding with empty man file is not a good practice from what I read, I usually just use Expert profile and code the unit with default setting based on the FA. Give it a try.
Old 03-07-2015, 03:50 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
Old 03-08-2015, 05:03 AM
rippjd rippjd is offline
Mein Auto: '05 745i / '10 X5 35d
* 54-PIN connector and fiber optic 2-PIN connector (before 3.2003)
* NCS EXPERT
* TOOL32
EDIT
Nice write-up! Not to get off topic, but is that a fire extinguisher mount? Looks almost factory.
For those that don't like modifying their 54 pin housing, you can purchase the 'Z-code' version which connects to all ECUs. They are typically 'Blue Water' color plastic.
The below picture has part numbers for the old ELO contacts in the top (used on E38 7-series) and the MQS contacts in the bottom used in our E65/E66 7-series.
Not sure if I ever posted this pic in the past...
Name:	54 PIN connectors.jpg
2005 745i Individual
E65/E66 Parts for Sale:
Alpina Type 743 Front Spoiler complete retrofit kit (new in box) $1200
Old 03-08-2015, 05:49 AM
Mein Auto: BMW E65
Yes that is a fire extinguisher mount, its best place
Ok maybe someone can tell me what exactly I have to change in the ECU and on which ECU
Code 00A376 - TCU: Communication with telephone handset disrupted
Telephone number can't be selected via the telephone control panel
Just this fault
Rest working fine
Question to all guys who made this retrofit
Yours Telephone control palel is working?
Old 03-09-2015, 04:11 AM
Mein Auto: E65 730D
Just this fault
Rest working fine
Not sure what it means by telephone control panel. But yes i can select contacts to call from idrive, or enter the number through keypad.
Old 03-09-2015, 01:03 PM
Mein Auto: BMW E65
Telephone control panel (keypad) next to ASK
All working well just I can't select number by keypad
In Ista i have also faults
My language is not good enough to understand everything in these 23 pages of forum
Do you have any guidance for coding, which functions TCU what exactly you changed in the TCU and other ECU
Maybe in fact empty .man file is not the best solution
Thanks for helping
Old 03-09-2015, 03:26 PM
PAPER's Avatar
CRISP & CLEAN
When you say select number , what exactly
Do you mean ?
Can you push a number & it pops up on the
Top of the MMI { can you dial a #? }
Old 03-09-2015, 04:56 PM
Mein Auto: E65 730D
Code the TCU with Expert profile, and then post the trace file here, maybe someone here can offer more help.
Old 03-09-2015, 10:04 PM
Mein Auto: BMW E65
I can't enter the number through keypad, buttons are inactive
I push a number and nothing pops up on the top of the MM
Here is my .TRC
Code:
TRACK_WIDTH
	standard
DSP_ACOUSTIC_PROFILE
	wert_12
BACKUP_ANTENNA
	aktiv
SIM_IN_TELEMATIK_READER
	aktiv
TELEMATIK_SIM_ENABLED
	aktiv
TELEMATIK_ENABLED
	aktiv
E_CALL_COUNTD_DELAY_TIMER
	wert_01
AIRBAG_TRIGGERED_E-CALL
	aktiv
SPRACHE
	deutsch
TIMER_SMS_NACK
	wert_01
WAKE-UP_BY_E-CALL
	nicht_aktiv
E-CALL_HARDKEY_FITTED
	aktiv
NON-TELEMATIC_E-CALL
	aktiv
ACK_2_AIRBAG
	aktiv
ALIVE_SIGNAL
	nicht_aktiv
CAS_KEY_DATA_METHOD
	wert_01
PAY_TMC_CONTROL
	aktiv
GATS_SMS_DESTIN_BACKUP
	atxeu_prod_d1
	atxeu_prod_prefit_sim_d1
	atxeu_tvs_d1
GATS_SMS_DESTIN_DEFAULT
	atxeu_prod_d1
	atxeu_tvs_d1
NON_TELEMATIC_E_CALL_NR
	nummer1
RDU_CONTROL
	nicht_aktiv
SVR_CONTROL
	nicht_aktiv
PHONEBOOK_PRIORITY
	wert_02
ENABLE_UNICODE
	nicht_aktiv
MINIMUM_PULSE_FREQ
	standard
SORTING_VARIANT
	standard
AUTO_SRVC_CALL
	aktiv
BORDNETZ
	e65_bordnetz
BT_ENABLE
	aktiv
CCM_FILTER
	wert_03
INTERNAL_GPS
	nicht_aktiv
INTERNAL_NAD
	aktiv
MOST_CHANNEL
	most_async_channel
USED_MICROPHONES
	wert_01
AIRBAG_COMM_TEST_DELAY
	wert_01
AIRBAG_INTRFCE_ERROR_DUR
	wert_01
FIRST_POLY_COEFFICIENT
	null
SECOND_POLY_COEFFICIENT
	null
THIRD_POLY_COEFFICIENT
	null
WSPEED_SIG_ERROR_DUR
	wert_01
WSPEED_SIG_TEST_DELAY
	wert_01
BACKUP_LOUDSPEAKER
	nicht_aktiv
VR_EQUIPPED_TCU15
	nicht_aktiv
A2DP_AUDIO_STREAMING
	nicht_aktiv
AACN_DATA_SEND
	aktiv
AVAIL_SERVICES_REPORTING
	short
BEAMFORMING
	nicht_aktiv
ECALL_TERMINATE_REDIAL
	nicht_aktiv
GATS_SMSC_BACKUP
GATS_SMSC_DEFAULT
HANG_UP_E-CALL
	aktiv
HIGH_POWER_MAX_TIME
	5_minutes
IN_BAND_MODEM
	nicht_aktiv
KEY_DATA_FETCH_BCALL
	aktiv
KEY_DATA_FETCH_HOTLINE
	aktiv
MAX_RS_ACTIVATIONS
	wert_30
MOST_WAKEUP_LINE
	nicht_aktiv
MULTIPLE_CALLS
	nicht_aktiv
NAD_ALWAYS_ON
	nicht_aktiv
NAD_ALWAYS_ON_MAX_TIME
	3_weeks
PARK_CONSUMER_TYPE
	wert_01
POWER_FLLW_UP_THRESHHOLD
	5_minutes
POWER_MONITOR_TYPE
	none
POWER_SUBNETWORK_TYPE
	nicht_aktiv
RINGTONE
	ringtone_1
TCU_POWER_SOURCE
	kl_30
TELEMATIC_AKD
	aktiv
TELEMATIC_B-CALL
	aktiv
TELEMATIC_DEALER_CALL
	aktiv
TELEMATIC_E-CALL
	aktiv
TELEMATIC_FCD
	aktiv
TELEMATIC_HEATING_CONTROL
	nicht_aktiv
TELEMATIC_HORN_CONTROL
	nicht_aktiv
TELEMATIC_HOTLINE_CALL
	aktiv
TELEMATIC_LIGHT_CONTROL
	nicht_aktiv
TELEMATIC_MY_INFO
	aktiv
TELEMATIC_RDL_CONTROL
	nicht_aktiv
TELEMATIC_TRFFC_BY_VOICE
	nicht_aktiv
TELEMATIC_VENT_CONTROL
	nicht_aktiv
VCARD_OVER_MOST
	nicht_aktiv
SMS_TCU
	nicht_aktiv
GET_POSITION_TIMEOUT
	0_minuten
INBAND_MODEM_TIMER
	nicht_aktiv
I was sure that will be enough if the empty man automatically changed the body from e60 to e65
Old 03-09-2015, 10:36 PM
PAPER's Avatar
CRISP & CLEAN
Here is my .TRC
Code:
TRACK_WIDTH
	standard
	wert_12
BACKUP_ANTENNA
	aktiv
	aktiv
	aktiv
TELEMATIK_ENABLED
	aktiv
	wert_01
	aktiv
SPRACHE
	deutsch
TIMER_SMS_NACK
	wert_01
WAKE-UP_BY_E-CALL
	nicht_aktiv
	aktiv
	aktiv
ACK_2_AIRBAG
	aktiv
ALIVE_SIGNAL
	nicht_aktiv
CAS_KEY_DATA_METHOD
	wert_01
PAY_TMC_CONTROL
	aktiv
	atxeu_prod_d1
	atxeu_tvs_d1
	atxeu_prod_d1
	atxeu_tvs_d1
	nummer1
RDU_CONTROL
	nicht_aktiv
SVR_CONTROL
	nicht_aktiv
PHONEBOOK_PRIORITY
	wert_02
ENABLE_UNICODE
	nicht_aktiv
MINIMUM_PULSE_FREQ
	standard
SORTING_VARIANT
	standard
AUTO_SRVC_CALL
	aktiv
BORDNETZ
	e65_bordnetz
BT_ENABLE
	aktiv
CCM_FILTER
	wert_03
INTERNAL_GPS
	nicht_aktiv
INTERNAL_NAD
	aktiv
MOST_CHANNEL
	most_async_channel
USED_MICROPHONES
	wert_01
	wert_01
	wert_01
	null
	null
	null
	wert_01
	wert_01
BACKUP_LOUDSPEAKER
	nicht_aktiv
VR_EQUIPPED_TCU15
	nicht_aktiv
	nicht_aktiv
AACN_DATA_SEND
	aktiv
	short
BEAMFORMING
	nicht_aktiv
	nicht_aktiv
GATS_SMSC_BACKUP
GATS_SMSC_DEFAULT
HANG_UP_E-CALL
	aktiv
HIGH_POWER_MAX_TIME
	5_minutes
IN_BAND_MODEM
	nicht_aktiv
	aktiv
	aktiv
MAX_RS_ACTIVATIONS
	wert_30
MOST_WAKEUP_LINE
	nicht_aktiv
MULTIPLE_CALLS
	nicht_aktiv
NAD_ALWAYS_ON
	nicht_aktiv
	3_weeks
PARK_CONSUMER_TYPE
	wert_01
	5_minutes
POWER_MONITOR_TYPE
	none
	nicht_aktiv
RINGTONE
	ringtone_1
TCU_POWER_SOURCE
	kl_30
TELEMATIC_AKD
	aktiv
TELEMATIC_B-CALL
	aktiv
	aktiv
TELEMATIC_E-CALL
	aktiv
TELEMATIC_FCD
	aktiv
	nicht_aktiv
	nicht_aktiv
	aktiv
	nicht_aktiv
TELEMATIC_MY_INFO
	aktiv
	nicht_aktiv
	nicht_aktiv
	nicht_aktiv
VCARD_OVER_MOST
	nicht_aktiv
SMS_TCU
	nicht_aktiv
	0_minuten
INBAND_MODEM_TIMER
	nicht_aktiv
Have you double check your wiring ???
Maybe start from scratch again & check
your wiring .
Old 03-10-2015, 03:39 AM
Mein Auto: BMW E65
Wiring ok
The same like stuartjohn24 wiring scheme
and same like in orginal facelifted E65 54-pin connector
Old 03-10-2015, 08:09 AM
Mein Auto: E65 730D
This is my trace file, see if it's of any use to you.
Would there be any chance that the TCU is not compatible with E65? Just a thought.
Code:
TRACK_WIDTH
	standard
	wert_12
BACKUP_ANTENNA
	nicht_aktiv
	nicht_aktiv
	nicht_aktiv
TELEMATIK_ENABLED
	aktiv
	wert_01
	aktiv
SPRACHE
	englisch
	japan
	koreanisch
	china_trad
	russisch
TIMER_SMS_NACK
	wert_01
WAKE-UP_BY_E-CALL
	nicht_aktiv
	aktiv
	aktiv
ACK_2_AIRBAG
	aktiv
ALIVE_SIGNAL
	nicht_aktiv
CAS_KEY_DATA_METHOD
	wert_01
PAY_TMC_CONTROL
	aktiv
	atxeu_prod_d1
	atxeu_tvs_d1
	atxeu_prod_d1
	atxeu_tvs_d1
GATS_SMSC_OR_AMPS_BACKUP
	atxeu_prod_d1
GATS_SMSC_OR_AMPS_DFLT
	atxeu_prod_d1
	nummer1
RDU_CONTROL
	nicht_aktiv
SVR_CONTROL
	nicht_aktiv
ENABLE_UNICODE
	aktiv
MINIMUM_PULSE_FREQ
	standard
SORTING_VARIANT
	standard
TRAFFIC_BY_VOICE
	nicht_aktiv
AUTO_SRVC_CALL
	aktiv
BORDNETZ
	e65_bordnetz
BT_ENABLE
	aktiv
CALL_SRVC_CENTER
	nicht_aktiv
CAR_PHONE
	nicht_aktiv
CCM_FILTER
	wert_03
INTERNAL_GPS
	nicht_aktiv
INTERNAL_NAD
	aktiv
MOST_CHANNEL
	most_async_channel
USED_MICROPHONES
	wert_01
	wert_01
	wert_01
	null
	null
	null
	wert_01
	wert_01
BACKUP_LOUDSPEAKER
	nicht_aktiv
VR_EQUIPPED_TCU15
	aktiv
PHONEBOOK_PRIORITY_C12
	wert_01
Old 03-10-2015, 12:57 PM
Mein Auto: BMW E65
Thanks B11NOV for .TRC
Its a bit different but i made the same settings in my TCU like your
I have more functions
Your TCU is TCU15MOS.C12
Mine TCU is TCU15MOS.C13
I will code tomorrow my TCU with new settings and let you know
If somebody have TCU15MOS.C13 with functional keypad send me .TRC please
Old 03-10-2015, 01:43 PM
Mein Auto: E65 730D
You are welcome.
On your file, related to some of the errors you are getting, are the backup_antenna, and the backup_loudspeaker. Don't activate the backup_antenna unless you have it. And I understand that E65s don't have backup_loudspeaker, so that needs to deactivated as well.
Good luck with sorting out the keypad problem.
Old 03-11-2015, 12:01 PM
Mein Auto: BMW E65
Still nothing... coded like your TCU .trc
B11NOV have you the same wiring color scheme like in my post?
We are in europe so have to be the same
Old 03-11-2015, 12:11 PM
Mein Auto: E65 730D
No I was lucky, didn't need to change the plug or anything, just replaced the old TCU with the new one, same plugs.
Have you tried coding the TCU with Expert profile, it will set the unit to default based on your FA, no harm trying it.
I searched your TCU part number, it seems that it's from E90, not sure if it's fully compatible with E6x .
Old 03-11-2015, 01:24 PM
Mein Auto: BMW E65
TCU photo in my post is sample photo, it's not my TCU
Mine is 84109174261 13.03 2008 mounted just in E61 E63 E64 E70
Maybe that is the problem?
I checked TCUs for facelifted E65 at realoem.com
I think that just these on the list will be ok (EUROPE)
Old 03-11-2015, 03:30 PM
Mein Auto: E65 730D
I think that might be the cause. I originally bought a TCU with part number 9224422, took quite a while and couldn't get it to work, checked and found out that was for E70, so I searched for another one based on the info from RealOEM, and bought one with part number 9149615, and it worked straight away. If you can find another for reasonable price, I would say go for it.
Old 03-12-2015, 02:10 AM
Mein Auto: BMW E65
Your part number 9149615 is on the E65 LCI TCU list
Thanks for confirmation
I will post you when i get one of them from the list
Will be in touch
Old 04-27-2015, 01:40 PM
ins1dez ins1dez is offline
Mein Auto: 320d
Hello
does the '06 TCUM module work on '02 E65?
I retrofitted one, added option $633, then deleted $630, i can see the TCUM in the list of modules, and I can code it, the problem is when I code MMIGT it doesn't show the bluetooth menu, it shows the old menu for $630 option menu..
Maybe the MMI it's too old and doesn't have a bluetooth menu for TCUM ?
What can I do?
