7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners |
#576
HI
unit works fine before update so I think VO is set fine Tried changed production date but no change at all I have $633 in my VO Stuart do You know where are hidden settings for keypad? Keypad lost backlight as well How to put back old software??? anybody know? tool 32 before update ![]() and after update ![]() cheers Last edited by masa52; 09-15-2012 at 02:30 AM. |
#577
As my car is a face lift I had it a little easier since I only needed to replace the TCU and flash the MMI, but I'll comment on the software. I don't believe there is anything Dashsoft can do that you can't do using a cheap OBD cable and the "free" (*) software available on the net. I have been using NCSexpert, NCS Dummy, Tool32 and WinKFP with great results. As for power supplies, I am convinced BMW's 70A requirement is wildly exaggerated; I use a 50A ham radio power supply (see my earlier post in this thread) that cost me 118 euros and it works great. (*) I am actually a little bit concerned about this; I work in the software industry and I have lots of friends in the music industry so I am always careful to respect copy- and intellectual property rights. I doubt BMW intended for their software to be distributed and used the way we do now. Not that it keeps me awake at night but I think it deserves consideration. And even though I use the software on occasion, I will not re distribute it. I've been meaning to find out exactly if my use of the software actually is in breach of IP rights but have not gotten around to it yet. |
#578
Hello guys.
I want to upgrade to Bluetooth ( I currently have the cordless handset in the front drawer). I know I will need some coding but do I just replace my Siemens AT with a Bluetooth TCU from any E65 as long as it has Bluetooth ( I have facelift mmi and ask) Thanks very much |
#579
Thanks very much. Will any make do (Everest / continental etc)?
Thanks again |
#581
Will a tcu from an e63 fit or must it be from an e65. The part number I have seen for sale is 8410917775402
Thanks |
#582
heres 1 http://www.ebay.co.uk/itm/BMW-TCU-MO...item3cd0c60480 http://www.ebay.co.uk/itm/BMW-TCU-MO...item3cd13cfa8b |
#583
Thanks very much for your help. I've bought the unit. Hopefully they'll post it to me.
Thanks again Phil |
#584
HELP
My Bluetooth unit has arrived but when I have removed my old Siemens unit the connectors are totally different. ![]() ![]() To ![]() ![]() Any ideas please??? Thanks |
#585
Re: How to Retrofit a Bluetooth TCU to your car
Phil not been funny but u need to read this thread from the start it will explain exactly what to do from start to finish especially where to get the proper connecting plug from and how and wat wires to change over etc and how to code it ,it is quiet easy to do but a lot to explain .wat I done was had the page open on my laptop that shows Stuartjohns post on how to do it in this thread .
Sent from my HTC Sensation Z710e using BimmerApp mobile app |
#586
Thanks irish745, sadly you will have to do some reading! You will need the new connector, I got mine from an audi dealer, BMW didn't stock that connector for some reason.
To give you a hint start with post 243, I listed all wiring for a UK Siemens to Bluetooth TCU conversion. The next page shows the installation and coding process. I did list the part number for the connector too on one of my posts around there. Stuart |
#587
Sorry guys. I was just keen to get it done and panicked a bit. I'll read through properly first
'Best to remain silent and appear stupid than to open your mouth and remove all doubt!!' I'll let you know how I get on Cheers |
#588
#589
No problem at all mate. I didn't take it the wrong way and appreciate all advice given
Cheers |
#590
Excellent thread!
Really wish I read this thread sooner, then I would have kept my TCU from my 2007 e90 after upgrading to combox. To add insult to injury, through the combox upgrade, I had to reconfigure the 54 pin tcu plug to the 26 pin plug the combox used. Ironic isn't it, we went from 26 pin to 54 pin and now back to 26 pin... Anyway here is the part# for the 54 pin if you want to order from BMW instead of Audi: 61136920074 EDIT: Just heard back from Evan@Tischer: Quote:
.: Hi! I am AoshichanX, how may I be of service to you today? :. ![]() meow | Bluetooth Retrofit Guide | Homelink DIY Last edited by AoshichanX; 05-14-2013 at 09:58 AM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
