7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners |
#176
I don't think you can edit that file directly but I may be wrong. I feel strongly at this point that this is our next course of action. Hopefully one of us will be brave and try this to see if it moves us ahead. Read this PDF for editing VO using NCS expert: http://www.m5board.com/vbulletin/att...ng-20ncs-1.pdf If you look at step 12 you will see the production date #0905 at the top of the list. I believe you need to highlight that line (in your case it would be #1001) and hit the delete button. Not sure if you should add the new VO first or after the removal. But this is where our next test needs to take place. Jeff Last edited by JML6278; 03-15-2012 at 06:13 AM. |
#177
Have you guys tried putting your old MMI in & reading it with NCS ?
I would try that before trying to edit the production date of your car . Sent from my GT-I9100 using Bimmer App
If you need a Custom 2013 DVD Navigation Map East or West for your E65 E66 PM me for price . Or if you Need an AUX Plug for your car hit me up |
#178
Since the coding index of the old MMI was 02 and the new MMI has a coding index of 04, I assume this has to at least be part of the problem. I didn't write it to the CAS or LMA, but I was able to remove my production VO (#0503), but when I tried to add (#0906) I got an error (forgot what the error message said). When I kept my VO production AND also tried to add the #0906 to the VO, I got an error saying that $216 wasn't valid for my VO. Again since I never coded the newer production VO (#0906) I don't know if I would have been able to read the MMI ECU. I pulled back to get more info. Might have to hook my MMI up to a 750 code my options and preferences and then re-install it in my car. At least then I would have my Navigation and iPod list showing up rather than CD 1 through CD 6. Anyone else making headway? Jeff |
#179
Hi guys,
Just tried changing the date in the VO.... BIG MISTAKE! The CAS was happy but the LM has thrown its toys out, it has now gone into failsafe and I only get headlights, no other lights work! the lights come on automatically with the ignition. ![]() I have tried writing the original FA code back but its not having it, error is: COAPI-2060: coding faulty LM_60,FA_AUFTRAG: ERROR_ECU_SUBFUNCTION_NOT_SUPPORTED_INVALID_FORMAT when taking backups from the car it was LM_E65.C06, it now thinks its a .C05 I guess thats the problem, when trying to code the unit i get: COAPI-2041: wrong ecu coding index A_E65LM: CODIERINDEX = FFh Im annoyed this looks to have bricked the LM module, trying to read information from it using tool32 throws errors. Does anybody have any ideas how to get myself out of this mess? I would be most greatful! |
#180
If you only did the CAS then that's why your getting the LMA error Sent from my GT-I9100 using Bimmer App
#181
Hi Paper,
Yes the CAS took the new FA/VO number but when i went to program it to the LMA it gave that error and I now cannot write or read the FA number, I cant read the coding file either. Tool32 does talk to the unit and it gets the information etc... but actually trying to get values back like the VIN, FA etc... all return errors. I will try and re-flash the unit using WinKFP and try and treat it as a new unit and hope that works. All I done was change the 1001 code to 0903 to see if that worked. When i try coding it back to 1001 it wont code it. This is turning into a nightmare! |
#182
Jeff |
#183
Hi Jeff,
No worries! I can see where it was progressing and I convinced myself this is the correct way to go, on the E90 forum they also change the production date in the VO to retrofit the CIC kits. I did read the LMA unit can be sensitive, I followed instructions in a pdf, guess i was unlucky! I will have a go tomorrow and try to code the unit using WinFKP hopefully I can revive it, otherwise its looking like an excuse to do an LM2 retrofit so I can enable welcome lights! Will keep you lot posted, looks like it may be easier to program this MMI in another car! what a pain! I still think the production date change in the VO is the correct route, i was just unlucky! One thing i was going to ask, is dashsoft able to code the MMI when its in this situation? Cheers! |
#184
how it was before .
#185
Any news on our issue? Would love to hear from someone who has successfully used NCS Expert to code a facelift MMI.
Stuart, Did Paper's suggestion get you back to where you were before trying to update the production date? Jeff |
#186
Hi Jeff and Paper,
no, I had already tried the expert profile, that's what I used in the first place. INPA will not communicate with the module either it's looking like its dead. To re-cap I cannot update the FA using any profiles, I cannot read or code the LMA. Tool32 and INPA are unable to communicate. The only thing left is WinFKP, I am having trouble setting this up, I haven't allowed enough space on my virtual machine (as I'm coding the car using my MacBook) so will do a fresh xp install later tonight when the kids are in bed and start from scratch. Jeff I have seen on other forums that you can fool NCS into thinking you have a different production date. Go and read the FA from the CAS like normal, click enter FA and change the hash bit with the date click ok but DON'T CODE IT TO THE CAS! you will notice now in NCS under FA that the code has changed. Try reading the MMI again now. It might work. However I have noticed my LMA is throwing an error about the coding index is wrong I would guess the MMI would be doing this of it was the case? Let me know how you get on! Remember don't actually code it, or you may end up like me! Stuart |
#187
sorry to see your still having trouble . I did a little research But didn't find much on your problem with the LMA beside people saying to work with the VO to get it back . I will keep looking for you .
#189
not take any production date over 2004 . I was told to have you try this . READ IN EXPERTMODE ( VERY IMPORTANT ) 1) delete the entry starting with a # (eg # 0101) (Del key on the keyboard) 2) Add a new entry: # 0904 ( DO NOT WRITE TO CAR ) After you changed the FA you click on the "back" button so that it takes the changes # Xxxx is the way the production date. There are perhaps other values ***8203;***8203;as # 0904 but with this it worked in my VFL. So take that! When I was # 0101 in, although my car is from 01/2002, so it can be that there are only certain values, where there has been a "restructuring" of the control devices. Maybe start with the program as # 1004 # 0904 instead of nothing.
If you need a Custom 2013 DVD Navigation Map East or West for your E65 E66 PM me for price . Or if you Need an AUX Plug for your car hit me up Last edited by PAPER; 03-16-2012 at 10:44 PM. |
#190
Hi Paper,
Thanks for looking, I haven't found much on sorting the LMA out, only retrofits in the E60 etc... If you look in the folder DATEN\ and find file E65AT.000 make a copy and open it with notepad or something, in the top third of the file is what look like the production dates #1001, etc I think if you choose one from this list you should be ok. You will also see lists of files for each date. This looks to be the .C0x coding levels it's expecting to see for that particular production date. My guess is the LMA module has been replaced in the past and I'm now using the wrong files. I will dig out the link but there is a reference to it here: Using latest tips from 4711, I "simulated" change of ZK from #0606 (which my E91 has) to #0307 in NCS-EXPERT. In the ECU-list FRM then changed to NFRM and I was able to do proper coding. This is where a newer FRM module was upgraded on an E90. Have you tried coding the MMI with the edited production date? |
#191
Jeff |
#192
Sent from my GT-N7000 using Bimmer App
#194
#195
Ok I'm going to bed! !!
#196
Just want to say that the willingness to help each other out everyone is showing here is impressing the h*ll out of me!
I'll probably be needing to call someone when I have swapped TCUs and coding bricked the engine
#197
Thanks, Jeff |
#198
![]() call me now
If you need a Custom 2013 DVD Navigation Map East or West for your E65 E66 PM me for price . Or if you Need an AUX Plug for your car hit me up Last edited by PAPER; 03-17-2012 at 06:10 AM. |
#199
Hey guys! I hear you have solved it!? What production date did you use??
#200
03 / 04 ( #0304 )
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
